Will not drain, spin or agitate
Replaced coupler, motor, capacitor, lid swtich still only a buzz. pulled motor out and kept plugged into electric and hit switch and only buzz will not turn motor. check outlet its at 120
    Top Expert:
  • Washing Mach... Master
  • 12,223 Answers
Make this test and fix it. God bless you
First you will need to identify if you have a direct drive type or a belt drive. The later is obvious if you have belts under your machine it is a belt drive, if not it is a direct drive. Also there are 2 basic agitator types with some variances among them. The 2 piece and the single.
Agitator Dogs
The agitator dogs are in the 2 piece type of agitator. These wear out over time. They also break and can cause noise. To inspect and replace the agitator dog .
Agitator Coupling / Spline
The other type depending on age of your machine use a spline. Newer GE types have a coupling that gets stripped out and the older GE type has a spline directly on the agitater that gets stripped out. You will need to remove the agitator. The dispenser usually pulls right out. This will give you access to the bolt that holds the agitater down. Remove the bolt, then place your fingers under the agitator and pull up. This can take some force. A belt slid under the agitater can also work. Once off you will see if it is stripped or not.
Belt
If your washer is a belt drive type make sure the belt is tight. Check for black soot from belt wear. Replace if it has excessive wear or broke.
Motor Coupler
This is a fairly common problem with direct drive machines but inexpensive and easy to replace. The Motor Coupler transfers power from the motor to the transmission. The following video will walk you through the replacemente motor coupler.
Transmission
The transmission does not usually fail. To check this on a direct drive remove the motor and then turn tub inside. If it spins freely with no noise the problem is elsewhere. If it is noisy it needs replacing this is expensive and depending on the age of your machine you may not want to replace it. On a belt drive remove the belts and spin tub.
Posted on Jul 25, 2013
jsrock516
  • 5911 Answers
SOURCE: agitated with my agitator and spin cycle
Your problem could be with your transmission, which is located directly above the drive belt pulley under the wash tub. If they go bad, your motor will still function normally, but the wash tub will not spin or agitate. Now, another possible problem could be a nail or screw stuck in one of the wash basket holes pressing against the outer tub. I have personally seen this a couple of times. A dry wall screw or nail will stop the wash tub from spinning and cause the drive belt to smoke as the motor pulley turns, but the belt stays stationary. That could be the source of your smell. If you're a do-it-yourselfer or do a lot of carpentry work, you may have washed some clothes with a nail or screw in them. Inspect all the holes in the wash basket throughly. A nail or screw can easily be missed if your not looking for it. I hope this may help you.
Posted on May 04, 2007
watugot
  • 290 Answers
SOURCE: Kenmore 80 series won't spin
If it is draining then the motor is turning the pump so it is ok.
This washer has no belt so that is not the problem.
Remove the cabinet and bypass the lid switch wires and put into a spin. Watch the clutch to see if it is turning. If the clutch housing is not turning and you know for sure the coupler is not broken then you need a new transmission. If the clutch housing is turning but the basket is not spinning you have something binding the basket or you need a new basket drive and clutch.
If you have only looked at the coupler from underneath you may not be able to tell if it is broken in the center. If it is broken again your transmission is not staying in neutral drain until the water is drained. That means it is going into spin with full load of clothes and water. This puts a lot of pressure on the coupler and causes them to fail prematurely. If this is the case you will need a new transmission.
Post back if you have any questions.
Posted on Nov 05, 2007
  • 512 Answers
SOURCE: GE washer no main motor run so no agitate or spin
This is the electronic washer. Unplug for two minutes, plugin then open and close lid 7 times. This will reset motor. Also make sure belt is not broken.
Posted on Jun 12, 2009
jumptrout51
  • 3361 Answers
SOURCE: Washer will not agitate/spin.
The lid switch is fine. The timer needs to be replaced.
Posted on Jul 22, 2009
aasc
  • 1606 Answers
SOURCE: Won't spin, makes clunking noise, drains fine
If it agitates fine , with normal noise , drains with lid closed , then the problem is probably the transmission .
Posted on Aug 02, 2009
Tip
The washing machine wont agitate?
There are many possibilities for this problem. you will have to check all of them one by one mentioned as follows :--- There is a lid switch in the washer. The washing machine will not start spinning till the lid is closed. In some cases it has been seen that lid is closed still the washer does not agitating. in this cases the lid switch has to be checked. if the lid switch is faulty then the closed lid will not be detected by the washing machine, and it will not start agitate cycle.
But if the lid switch is ok checked, then other possibility can be fault in the motor coupler. Many a times the motor coupler is broken .The motor coupler is plastic/rubber kind of material fitted on the shaft of the motor .Check properly if the motor coupler seems cracked, worn out loose or broken then it needs to be replaced to solve the issue. But if motor coupler is checked ok then other possibility for this problem is the spinning belt. If the belt is worn out or loose or cracked/broken then it needs to replace.
Only for GE washers. In GE model washers, there is a clutch used for proper spin speed. If the clutch wears out, it has to be replaced.But if clutch/belt seems ok. then other possibility is driver motor itself .check if the motor has power if not then the motor is got internally burnt .in this case the drive motor needs to be replaced. but if drive motor is functioning properly then other possibility to be checked for this fault is the transmission shifter and pulley. If the transmission shifter becomes defective, the unit may drain the water but not spin. Replacing the shifter is bit time consuming and tough job. you will require proper tools to deal with this problem.. But if the transmission shifter is properly working then other possibility to check is the Agitator itself.If the transmission is moving properly but the Agitator is getting stuck and not moving properly then its the fault in the agitator assembly that has to be replaced to solve the problem. This will help.Thanks.
on Mar 18, 2010 | Washing Machines
My wm64 hotpoint washer wont spin how can i fix it
There are few possibilities which can cause the no spin problem.The lid switch, agitator couple or motor coupler. First thing to be checked is lid switch.If the lid switch is short or not getting closed, then its the cause of no spin.Check the lid switch on the machine and see if it is broken or bent. The lid switch give the washer a signal that the machine is closed.If the lid switch checks out ok, then its agitator coupler or motor coupler issue.It is composed of 3 pieces and generally costs about $15-20 for the parts. Turn the washer on its side and look between the motor and the transmission. If you see small pieces of plastic and or rubber around the area then thats the problem for sure. --------------- Press the rinse/hold button to see if the machine is paused.
Pull the drain hose out and inspect it for blockages. Remove the drain hose from the machine and look through it.----------------------This are the details to be checked.Thank you for using fixya.
Mar 24, 2011 | Washing Machines
Water will fill (and drain), was agitating - then stopped with a loud buzzing. Water will still fill and drain, but will not agitate or spin. When it should be spinning or agitating, the loud buzz is...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Look in the section for the motor, pump gearcase and you'll see the Motor Coupler.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump. This is likely why the machine drains.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Sep 15, 2010 | Kenmore 25842 Top Load Washer
My portable top load kenmore washer model 110.42722200 won't spin. It drains water and all the light functions work, but it only makes a humming sound like it is stuck when it gets to a spin cycle and does...
I just repaired this exact model this weekend. If the machine will drain but doesn't agitate or spin (you have to put a screwdriver in the lid switch to see), it's usually a loose belt. This time I replaced the belt, but it still would not agitate or spin, and the motor was not turning, just a "buzz, buzz, buzz" when the washer attempted to supply power to the motor. The start capacitor for the motor was bad. Part number 3429938 which runs about $60. Not hard to access once you tip the washer over slightly, just DISCHARGE THE OLD CAPACITOR so you don't get a nasty shock.
Aug 05, 2010 | Washing Machines
My washer will fill up but then wont spin just makes buzzing sound
It doesn't agitate If your washer doesn't agitate, check these: Lid switch Motor coupler Belts Clutch Drive motor Drive pulleys Transmission Agitator Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it. Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Jan 05, 2010 | Maytag HAV3460AWW Top Load Washer
Will not agitate or spin
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
The top load, direct drive, neutral drain Whirlpool / Kenmore washers use a "Motor Coupler" between the transmission and motor.
When the motor goes into drain / spin mode, it reverses and drives the pump to drain the washer.
If the motor coupler is damaged / broken, the motor cannot get power to the transmission to agitate or spin.
This is a relatively easy fix for the basic Kenmore / Whirlpool washers.
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
Follow the instructions for removing the cabinet and pulling the pump, motor and motor mounting plate.
The coupler has two plastic pieces with three prongs each. In between is the rubber coupler with six holes.
Oct 05, 2009 | Kenmore 24032\24036 Top Load Washer
Will not Spin or Agitate. Whirlpool washer came
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
Now...a washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
Take note of your symptoms:
1. Washer fills, may or may not agitate, will not advance to the rinse cycle, and will NOT drain - lid switch.
2. Washer fills, does NOT agitate or spin, but WILL drain - motor coupling.
If you still have questions, please let me know. If the suggestions I have listed do not match your washer symptoms, please post back and elaborate more on what the washer is/is not doing. That way I can provide you with better assistance. I hope this information is helpful to you.
PS The age of the washer is determined by the Serial Number on the appliance. If you post back with the number I can tell you the year it was manufactured.
Jul 10, 2009 | Whirlpool LSR8433K Top Load Washer
Washer problems
if it wont drain , check your lid switch, check out your motor coupler, if it will not agitate and spin, replace your motor coupler, if it agitates and dont spin, replace your lid switch.
alot of times the washer will drain but we hurriedly cut it off when we hear noise or the water is out but it never spinned and so the clothes are soapy wet...
Nov 12, 2007 | Roper RAX7244KQ Top Load Washer
Washing Machines Logo
66 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
