Question about Dirt Devil M089900 Upright Vacuum
Reset I need to know where the moter button is on the dirt devil M08900. I was useing it and it just shut off.
  • 126 Answers
SOURCE: Dirt Devil Repair
Any warranty dealer for Dirt Devil should be able to supply a schematic for that machine. They have access to the dealer web site and can download the information.
Posted on Feb 02, 2008
Agent Don
  • 310 Answers
SOURCE: Instruction Manual needed for Dirt Devil upright model 088305
http://geeksquad.fixya.com/ThreadView.aspx?prdid=89362&thid=642772
Instruction Manual needed for Dirt Devil upright...
Posted by Innahouse on Jun 03, 2008
Describe your problem I need an instruction manual for a Dirt Devil upright model 088305.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Dirt Devil Model #M088300 Upright Vacuum. The best idea is to contact the Royal Customer Service Dept and give them the model 3 and serial 3 of the unit you are requesting the owner’s manual for, I will give you the website address and phone # listed below:
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://royalvacuums.com/ Customer Service 1-800-321-1134
Hours are: 8:00 AM to 7:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 11, 2008
ukvacfan
  • 328 Answers
SOURCE: Dirt Devil Extreme Quick Vac - Won't turn on
Check that the filters are completely clear and not blocked - especially the top filter on top of the bin assembly. If its clogged completely brush it free of dirt and then reassemble. Make sure the inner cone filter and mesh filter is also completely clean. Then check the hose and main dust channel - something is clogged that makes this machine overheat and stop working - and often with this model (Hoover also make it in the UK under the Alyx name) its down to clogged filters or small clogs of dust in the dust channels.
Don't forget to rate, thanks.
Posted on Mar 06, 2009
galati2k
  • 281 Answers
SOURCE: dirt devile featherlite vacuum pushes extremely hard on high pile carpeting
the dirt devil featherlight has a automatic height adjustment for carpet and bare floors.check the wheels and see if there is something wrapped up around the wheels
Posted on Apr 29, 2009
SOURCE: need instruction on dirt devil mop vac
I found very basic direction on eHow
Posted on Mar 20, 2010
Do my Dirt Devil have a restart button it just stop running
Hi! No the vacuum doesn't have a restart button, but it does have a thermal protector that will shut the vacuum down when it is overheated. If your dirt cup was too full this will activate the thermal protector sensor. Clogs and dirty filters can cause this as well. We recommend emptying the dirt cup, tapping out the filter and checking the hose for clogs. The vacuum will come back on usually within 45 minutes to an hour. Hope this helps. If you need further assistance don't hesitate to reach out to us here on Fixya, Facebook.com/dirtdevil or Twitter @DirtDevil
Sep 20, 2014 | Dirt Devil Featherlite Bagless Vacuum...
Where is the reset button on the dirt devil featherlite
Hello! There is no reset button on the vacuum. It is equipped with a thermal protector sensor that will automatically shut the vacuum down when it is overheated. A vacuum usually overheats if there is a clog or if the filter needs to be cleaned or replaced.
To check for a clog twist the lower hose off where it connects to the brushes. Use a wooden spoon or something similar to break up and remove any clogs in the lower hose.
Remove the filter from the dirt cup. Tap the filter firmly against the trash can until debris stops falling. If the filter is really dirty it may need to be replaced. I have included a link that you may follow to purchase a replacement filter if needed. Your vacuum will turn back on after it cools down, this can take up to an hour. Hope this was helpful!
F1 HEPA Filter
Sep 01, 2014 | Dirt Devil Featherlite Bagless Vacuum...
Why does the dirt devil breeze turbo shuts off
Hi there! The vacuum is equipped with a thermal protector sensor that will automatically shut the motor down if it reaches a certain temperature. This is usually caused by either a clog or a filter that needs to be cleaned or replaced. Make sure you check both the hoses for clogs and clean all filters properly. If a filter is really dirty it may be time to replace it. Hope this was helpful!
Apr 24, 2014 | Dirt Devil Vacuums
I have a Dirt Devil M130000 I Dual, which just shut off.
yOU MIGHT TRY LOOKING DEEP INTO THE DEVIL PAST THE CANISTER INTAKE AS THIS IS WHERE THEY CAN GET A HUGE CLOG THAT YOU CAN'T SE UNLESS YOU STICK YOUR HAND WAY IN THE UBE. DO THID WITH THE DEVIL TURNED OFF. CHECK FOR A SHORT IN THE CORD AS WELL BE SAFE FIRST.
Jul 23, 2010 | Dirt Devil M130000 ''i'' Dual Cyclonic...
I have a dirt devil featherlite carpet shampooer. It has been a great one for about five years without any problems. I need to know if anyone knows where I can find the replacement filters?
Hi There,
We actually do carry the foam filter for your Dirt Devil Featherlite (also manufactured as the Easy Steamer) carpet cleaner.
According to the Dirt Devil parts diagram for the CE6000, your machine takes the following foam filter. Here's a direct link to the filter on our website:
Dirt Devil Featherlite, Easy Steamer Foam Filter Part# 1-700750-600
Here's a link for the parts diagram for your Dirt Devil Featherlite CE6000 carpet cleaner. This will give you all of the part numbers, and drawings for each part on your machine should need any further parts:
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/dirt-devil-easy-steamer-featherlite-ce6000-parts-diagram.pdf
I hope this helped. If you have any further questions or concerns, please feel free to use the comment field here on the repair page to contact me, I'm always happy to answer any follow up questions.
If you found this repair helpful, please be so kind and rate the repair helpful and / or leave feedback for me. Thanks so much!
Chris Jones
GoVacuum.com
Apr 21, 2010 | Dirt Devil CE6000 Featherlite Wet/Dry...
Over heats and shuts off, wont start again untill it cools off. can maybe vacuum one room before overheating. cyclone tubes are all clean, all hoses & lines are clear. this vacuum is fairly new, not...
The electric motor has a thermal switch and is self-resetting so there is no re-set switch. Make sure the air filter for the exhaust is clean. Also make sure that the height adjustment is not too low causing strain on the motor. Always bring the height down to where the brushes just make contact with the carpet. It is possible that the thermal safety switch is tripping due to a bad switch. In that case I would contact Drit Devil if it is still under warranty.
Nov 10, 2009 | Dirt Devil Reaction Twin Cyclone Upright...
Wont shut off when I press the power button
the switch has failed inside the unit so it is stuck in the on position
Oct 27, 2009 | Dirt Devil Featherlite Deluxe Bagged...
Stopped working while using..is there a reset button?
There is no reset. There is a thermostat on the motor that shuts down the motor when it gets over heated. Check your filters and bag if you have the bagged type or check your filters and empty the dirt cup if you have the baggless type. Make sure there is no obstruction in the duct hose and the main hose. Check for anything that will not let the air move freely. If you can't get it to operate properly, take it to the shop.
Joe
Sep 19, 2009 | Dirt Devil Vacuums
Dirt Devil M089900 Upright Vacuum Logo
386 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
Jim Parker
Jim Parker
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
