Replace ink absorber on a brother mfc-j630w - Office Equipment & Supplies
SOURCE: BROTHER MFC 210C INK ABSORBENT BOX
You can order the part directly from Brother ( ph # 1-800-284-4329).  The part is called an "Ink Absorber Box Assy" .  The part number is LF7544001 for a MFC-210C printer.  It cost about  $11 and shipping is about $5.   There is a website that has different diagrams for various brother printers.  You will also see  part numbers.
Posted on Oct 19, 2007
Samyfam
  • 379 Answers
SOURCE: Brother MFC-465CN printer. Need a fix for error 46.
The problem is due to the fact that Brother machines excessively self-clean. Each time they self-clean a small amount of ink is dumped in to a holding tank/sponge. When a predefined number of self-clean operations have been performed, the machine refuses to print and gives the error message you have stated. Brother state that the tank/sponge must be replaced before the counter is reset, again by a Brother agent.
However, there is a way of reseting the self-clean counter yourself - if you Google your model number and the error code somewhere in the results you'll find how to do it. The only risk of doing this without changing the tank/sponge is that it will eventually overflow and leak out the bottom, but I did my Brother all in one some time ago and have had no problems yet.
Posted on Jul 12, 2010
  • 8016 Answers
SOURCE: How to check ink level on brother MFC-9440CN?
Run the Brother Control Center. Click Device settings. Click where it says Inklevel.
A simpler way is Start-->All Programs-->Brother--> ...-->Status Monitor.
An icon will lodge itself on the tray (a printer). When icon is clicked on, the inklevels will show.
Hope it helps.
Posted on Sep 03, 2009
pineworks
  • 4041 Answers
SOURCE: Just replaced ink cartridges on my Brother MFC
Hi there you can refill Brother cartidges, like other printers it will not have it sorry.
This is the only way you can trick it.
There are only a few steps you need to do to reset a Brother printer ink cartridge and once you do it, you will be up and printing in no time. There are actually two things that a Brother printer uses to detect ink and you can manipulate one or the other.
Instructions
Things You'll Need: · Black electrical tape, masking tape or duct tape
1. Step 1
Identify the printer If your printer uses memory, you can tell which printer you have by looking at where the cartridge goes in, if you see two "eyes" and a part of the cartridge goes in between them, follow Step 3. Otherwise, continue with Step 2.
2. Step 2
Clear the memory by taking the cartridge out and unplugging the unit for 30 seconds. Then, plug it back in and put back in the cartridge. You may need to do this five times, as the memory holds the last five cartridges.
3. Step 3
If the Brother printer has "eyes" where the cartridge goes, you will need to block in between them with a piece of tape so that it thinks the cartridge is always full. Simply put a piece of tape on the piece of the cartridge that goes in between the eyes to block the path of the infrared beam
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 04, 2010
SOURCE: I have a brother mfc-295cn printer that won't print black
Mine wouldn't print black either on Plain Paper, but if I changed the settings to Transparency Paper type it would. Hope this helps
Posted on Dec 14, 2010
How to reset ink absorber full for brother mfc-j220
https://www.google.co.uk/search?es_sm=122&q=BROTHER+PRINTER+MFC-J220+INK+ABSORBER+FULL&spell=1&sa=X&ei=L7HgVMfAA5HLaJP-gJAD&ved=0CBwQvwUoAA
Feb 15, 2015 | Brother MFC J220 Multifunction Printer
Brother MCF-J4710DW says ink absorber almost full and won't print? Never heard of ink absorber. Where can I purchase replacement and how do I do it
Many ink-jet printers have a pad in the case to absorb the ink from cleaning cycles. Often these show "full" long before they are actually full, and you can reset the counter and continue using them. I found your answer here:
How To Reset Purge Counter on brother mfc j4710dw
Nov 02, 2014 | Brother MFC-J4710DW 35ppm 6000 x 1200 dpi...
Why doesn't my printer print the black text?
With the printer in the ON position take out the black cartridge and put back again and make a sample test text page and see if its recognized and printed,.
Jul 24, 2014 | Brother MFC Office Equipment & Supplies
How to solve ink absorber full brother mfc-j6910dw
You cannot change the ink absorbers as the machine requires a full strip down as they are located in the base. You will have to give it to a dealer for repair.
Jan 30, 2014 | Brother MFC J6910DW - Multifunction fax /...
Disassemble Brother MFC 240C
I know this issue may have been resolved by you already, since I am now looking at this issue for you, however I am setting up the answer to help others that may have a similar problem in the future. You will need to reference a Brother servicing manual as it will show you how to remove the printer assembly and includes part numbers that you may need to replace. Hope this is helpful! You can find the manual at: ftp://ftp.brother.co.il/fax/MFC845.pdf
Dec 27, 2013 | Brother MFC 240C All-In-One InkJet Printer
How to fixed MFC-J220 Brother Ink Absorber full ?
The ink absorber box or flushing box will need to be replaced
Apr 15, 2013 | Brother MFC-5440CN All-In-One InkJet...
Error Message- Ink Absorver Full-MFC-J415W"
Sir/Madam
Your Brother Printer Machine automatically cleans after clearing a printer jam.And Brother Printer Machine automatically cleans after sitting idle for more than 45 days (infrequent use).
To solve the problem:
The ink absorbed box or flushing box will need to be replaced.
In Case You Still Need Online Help For Brother Printer,Then I Suggest You Follow Us For Brother Printer Support
Dec 20, 2012 | Brother Ink for Mfc J415w Printer
MFC-J630W driver will not install arguments invalid dell E1705,XP pro, installed ok on two other computers
You mention two names of your printer above..
The Brother MFC-490cw and also a MFC-J630W
which printer do you have. or is it both?
Aug 16, 2010 | Brother MFC 490cw Color Inkjet...
Is there a waste ink absorber on a Brother MFC 420CN?
MFC420CN waste ink absorber how do you replace it or clean it ?
Dec 18, 2008 | Brother MFC-9420CN All-In-One Laser...
Error 46 on a Brother MFc-8840DN
According to the Brother MFC 8840DN manual:
Machine error code xx: MFC has a mechanical problem
Solution: Call Brother customer service and tell them the error number
USA 800-284-4329
Remember to rate users who offer their expertise to you at no cost :)
Sep 29, 2008 | Brother Office Equipment & Supplies
245 people viewed this question
k24674
jasbo
jasbo
