Question about Singer Tiny Tailor TT700
Where can I get parts for a tiny tailor TT600 machine
barefoot1957
SOURCE: Missing part
I too have a Tiny Tailor with missing parts. I emailed Singer directly and this is the answer I got back from them...
I would be willing to GIVE you mine if you want it...
Unfortunately this item was discontinued several years ago, and replacement parts are no longer available. For this reason, this item is not repairable. We regret that we were not able to assist you with your request.
You may want to search on EBay, where a private individual might be selling this unit. You may be able to obtain parts this way.
Singer Consumer Affairs
Posted on Nov 04, 2008
bargainbox
  • 1388 Answers
SOURCE: Problem with tension on singer tiny tailor mending machine
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks
bargainbox.com.au
Posted on Aug 30, 2009
  • 139 Answers
SOURCE: need ownes mauel for singer tiny tailor mending
You can download a free manual at the Singer website:
http://www.singerco.com/accessories/manuals.html
Posted on Apr 07, 2010
  • 4 Answers
SOURCE: Tiny Tailor bobbin won't wind
I don't know the solution but you can find the manual here:
Do search for TT600 when given the model number (do NOT use TT600X since it wll say not found). It's a very nice manual that is in PDF format.
Posted on May 31, 2010
SOURCE: I've lost the manual to the Singer Tiny Tailor
I've lost the manual to the Singer Tiny Tailor mending machine M100A and need to know how to refill the bobbins. Can you help me?
Posted on Mar 25, 2011
Still need to know where to buy parts....the tray for the Tiny Tailor mending machine and the bobbin winding pin for the M100
I am sorry. The tiny tailor is a throw away machine. Your best bet is to save your money and go buy a Janome or Juki. Singer machines since the mid-1960s are plastic pieces of junk.
If you feel you must replace these parts... I would not spend more then $30 for both of them. Try allparts
Sep 23, 2014 | Sewing Machines
I need an AC adapter for my Singer Tiny Tailor TT700
contact singer customer support about the part
Feb 05, 2012 | Singer Tiny Tailor TT700
Tmail.comI need the cover that slides over the bobbin to keep it in placc,can you advise on how to get one I have searched all the internet.I have the tiny taylor model,it is a see through cover model...
have you tried
sewingpartsonline.com
sewvacdoctor.com
a1sewingmachine.com
sewingmachineparts.net
universalsewing.com
sewing-machine-parts-store.com
Sep 09, 2011 | Singer Tiny Tailor TT700
My granddaughter got a Tiny Tailor TT600. The thread comes off the Disc thread guide as soon as we start sewing. Can't keep thread on there unless I keep finger on that button to keep thread on while...
I had the same problem until I saw that you have to Thread the thread up around the button --not just go around it and expect it to stay. Un-thread the machine to that point then look carefully at the button and you will see an open tab on the right side to go around but on the left side you have to look up at it and thread the thread up next to the button-there's a closed piece on that side that keeps the thread on the button, and then continue to thread the machine. Once you have it correctly it won't be able to fall off every time the arm thing comes down. Hope that helps!
Jul 03, 2011 | Singer Tiny Tailor TT700
Need manual for singer tiny tailor model tt600a
Go to singer website singerco.com and type in tt600, I found it when I was looking for a 600, so you may have to just type in 600. Good luck. BTW, why do you have a picture of the Brother cs6000i?
Aug 22, 2010 | Brother CS6000i Computerized Sewing...
HOW TO THREAD THE TINY TAILOR
check this site out for a mnual Singer_ TINY-TAILOR-TT600-TT600A Manual - Only $5.00 for the ...A Handbook for your Singer_ TINY-TAILOR-TT600-TT600A Sewing Machine ... Download the TINY-TAILOR-TT600-TT600A Singer_ sewing machine manual: ...
http://gotoes.org/sales/Singer_SewingMachineManuals/ViewInfo.pl?Singer_=1&Sewing_Machine_Model=TINY-TAILOR-TT600-TT600A
Aug 28, 2009 | Singer Tiny Tailor TT700
Jan 12, 2009 | Singer Tiny Tailor TT700
Need Foot Switch for Singer Tiny Tailor Modle TT700
Aug 05, 2008 | Singer Tiny Tailor TT700
Sewing Machines Logo
126 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
