Question about HTC Touch Dual P5500 Smartphone
I went cleaning my htc p5500 screen with a dap clothes and rub it up and down now the touchscreen isnt working,jus would like to know if i reboot it will the touchscreen work?
    Top Expert:
  • 12,223 Answers
FOLLOW this steps and fix it. God bless you
  1. Hard Reset
    • 1
      Pull out the stylus from the back of the HTC Touch Diamond or the side of the HTC Touch Pro.
    • 2
      Using one hand, press and hold the volume down button on the left side of the device, the power button on the top of the device and the circular button on the face of the device. It is generally easiest to hold the volume down button with your thumb, have your palm over the LCD, press the power button with your index finger and the circular button with your pinky.
    • Sponsored Links
    • 3
      Continue to hold the buttons down while you turn the device over to access the back side. Use the stylus to press the "Reset" button, located near the end of the stylus cavity on the Diamond, and by the port on the bottom of the device on the Touch Pro. Release the "Reset" button, but do not stop holding the volume down, power and circular buttons.
    • 4
      Turn the HTC Diamond over and watch the LCD. When a message appears saying that this operation will delete your data, release the three buttons. Press the volume up button to complete the hard reset.
    Clear Storage
    • 5
      Slide your finger to the right along the bottom of the LCD until the "Settings" option appears. Tap "All Settings" on the device.
    • 6
      Tap the "System" tab on the screen and then tap "Clear Storage"
    • 7
      Select the drop-down box and choose "Clear Storage Only." Type "1234" into the text box confirming that you do want to delete your information and then press "Yes."
Posted on Jul 25, 2013
Touchscreen isnt functioning
replace her touch screen and clean her parts
Jul 25, 2013 | HTC Touch Dual P5500 Smartphone
Whats the name of the firmware i suppose to use for HTC P5500?
Without the country or the service provider names, I can't tell which files you need, but go HERE and look thru the files for those that match your specific phone/provider.
Sprint zte fury touch screen unresponsive..any solutions?
Your touch screen didn't like "touching" your "really sweaty" chest! Te oils from perspiration are playing havoc with the screen. Use some rubbing oil on the screen with a soft cloth to remove the oils.
Jan 13, 2013 | ZTE Fury - 4gb - Black sprint Smartphone...
Htc wildfire s touch screen randomly selecting things
I solved the problem!
Description of the problem: my touchscreen went crazy (it selected random thins, especially in the bottom region of the screen) quite often and every time i had to lock/unlock the phone in order to fix it... but after 30 sec the problem went back!
Solution: remove the back lid cover, the battery and the sd card; unscrew the 5 screws and remove the second plastic lid; behind the battery slot you'll see three metal flap: when I opened my phone one of them wasn't in contact with the card! I fixed it and I cleaned these three contact with alcohol! Now my Wildfire S works fine!
Nov 25, 2012 | HTC Wildfire S Smartphone
Cleaning touchscreen without damaging it.
Proper cleaning of a Touchscreen
  1. Step 1 Turn off both the computer and touch screen. This way, you can see everything that needs to be cleaned. Some touch screen applications has a cleaning mode which turns off the screen for the specific purpose of cleaning. However, the monitor's brightness can make you miss some areas.
  2. Step 2 Wet a soft, lint-free or microfiber cloth with distilled water. Wring out as much water as you can. Make sure the cloth is damp but not wet. Wipe the screen in a gentle motion to remove dust, oil, or fingerprint smudges off.
  3. Step 3 Another option is to use a screen cleaner kit that includes antistatic wipes. You can buy this at various electronic or online stores. Spray a little solution on a wipe then rub it gently across the screen.
  4. Step 4 Finish cleaning the touch screen with a dry lint-free cloth to wipe any excess moisture, then turn it back on.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thank you.
Feb 03, 2010 | HP Pavilion TX2000Z Notebook
My g1 isnt showing a picture I have lines on the screen . I just put a new lcd screen .What do you think
you may have to reboot your g1.....don't hard reset that will erase everything from your sim card ...try wiping you camera lens with a cloth and check your photos ..if that doesn't work then maybe you had a bad repair tech
Nov 21, 2009 | HTC G1
My htc touch pro through verizon was working fine....then all of the sudden, the screen has almost like a rainbow colored gel or something under the screen, and the touch screen wont work....tried to...
Your description of the problem says that the firmware is corrupt. Reinstall the firmware. That should solve the problem. If the problem still persists then the display IC has gone or is going (I hope not). Should that happen then the phone will have to be scrapped as it becomes beyond economic repairs.
Nov 08, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
TyTn II unresponsive touchscreen
Try to calibrate the touch screen. Also clean it with a soft cloth. But calibrating it should help the film when you tap the screen.
Apr 16, 2008 | HTC TyTN Smartphone
HTC Touch Dual P5500 Smartphone Logo
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
