DVD Players
Problem for DVD Players
Generic problem for all DVD Players
LG V8824w DVD/VCR no video
By weaver00 on Aug 30, 2007
The VCR plays fine with good picture and sound. The DVD will play with sound ok but no picture. I have cleaned connectors that are accessible and run a lens cleaner disc in the DVD.
Same Problem
May 01, 2008
-   sound is good, no picture when plugged into car system. very little sound and no picture when plugged into 110ac..any help will be appreciated than ks canied123@hotmail.com-   piaq
Jan 19, 2008
-   i have same problem with LG v8824w - video works fine dvd sound but no picture. tried pulling it apart, checked cables wiped them with dw40 - no success - any other ideas?-   wenchessau
Best Solution
posted on Feb 02, 2008
Very Helpful)
netbot
Rank: Apprentice
Rating: 98%, 24 votes
rtfm.
Once the setting for progressive scan output is entered,
an image will only be visible on a progressive scan
compatible TV or monitor. If you set Progressive Scan
to On in error, you must reset the unit.
1) Remove any disc from the unit and close the disc
tray. See that "NO DISC" is displayed on the display
window.
2) Press STOP and hold it for five seconds before
releasing it. The video output will be restored to the
standard setting and a picture will once again be visi-
ble on a conventional analog TV or monitor.
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #2
posted on Aug 30, 2007
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
1. DO ALL OF THIS WITH THE UNIT NOT PLUGGED IN TO THE 240 VOLT SUPPLY !
2. Remove the cover.
3. Remove the four screws that anchor the DVD drive unit in place and lift UP the drive unit carefully.
4. Remove the two flat cables connected from DVD unit to the motherboard, by Grasping the end of each between forefinger and thumb and pulling VERY GENTLY.
5. Now have a very close look at the ends of each of the cables. Look for any sign of bent or cracked exposed metal track. IF it looks perfect, just WIPE IT clean with some WD40 and spray a little WD40 into each of the sockets the cables fit into then refit everything and test it. HOWEVER, IF THE FLAT CABLE ENDS LOOK BENT OR JADED OR DAMAGED IN ANY WAY.....get a very good pair of scissors and trim off the ends PERFECTLY SQUARE by 1mm or 2mm to give a "NEW END" appearance.
6. Plug the cables back in VERY carefully with minimum force and make sure that they are in-line and truly parrallel with the socket.
7. Refit the DVD drive and test the operation of the DVD player.
I have found this fixes 95% of this kind of problem. Anthony ( Technician) tminbox@hotmail.com
Solution #3
Somewhat Helpful)
kpuddicombe5
Rank: Wiz
Rating: 79%, 171 votes
it could be that the dvd player is plugged into its wrong spots if it is hooked up seperately
Was this helpful?
Yes
No
Solution #4
posted on Oct 04, 2008
Not Rated)
Ingek393
Rank: Apprentice
Rating: 0%, 0 votes
I got a LG combo V8824w and i have problem's with playing DVD from Germany, no reading. Can you help me, is there a code to put in? hope you can help me , thank you very much. Inge
Was this helpful?
Yes
No
Solution #5
posted on Mar 15, 2008
Not Rated)
horsyroo
Rank: Apprentice
Rating: 0%, 0 votes
thank you for the information i had this propblem and i read the manual but it didnt tell me any thing finding this answer fixed my problem
10/10 thanks for sharing your info
netbot thanks a million
Was this helpful?
Yes
No
Popular Solutions for DVD Players
Questions and Unsolved Problems for DVD Players
Answer
what sort of scart lead for product dvp3360
Answer
Which is the Best and Lower Price DVD player
Answer
I cannot hear the dialogue when i play Redbox movies.
Answer
We have a 2004 Toyota sienna with an empty DVD player console on the ceiling. It has a hinge and... (More)
Answer
need rechargeable battery & adapter
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For DVD Players:
Top DVD Player Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more DVD Player Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
