Question about Refrigerators
Refrigerator part of coil freezing up, what would be the problem?
    Top Expert:
  • Refrigerators Master
  • 12,223 Answers
2) Some refrigerators contain timers that control the self-defrosting heaters. Unfortunately, it can be hard to find the timer, depending on the model of your refrigerator. In most cases, side-by-side refrigerators that have temperature control knobs at the top of the fridge compartment often have the defrost timer located near the thermostat behind the control knobs. It looks like a small, round object with one flat end that has four electrical prongs. It is also often located in the control panel, behind the fridge or behind the foot kick panel at the base of the appliance. Use a flathead screwdriver to advance the timer until you hear a click. This should start the defrost heater. If it doesn't, the timer probably needs to be replaced. Continue to turn it clockwise and a second click will be heard, which turns off the defrost heater. If the timer isn't clicking, simply pull it out and "plug in" a new timer.refrigerators that don't have timers have control panels that control the self-defrosting unit instead. The control panel can sometimes be tested using the controls on the water dispenser or by removing the rear of the front panel to access the controls. A simple press of the button will run several diagnostics that will test your defrost timer, thermostat and heater. The specific instructions vary depending on the model of your Kenmore refrigerator. Consult your owner's manual to run the diagnostics if you have a control panel in your refrigerator.
Read more: http://www.ehow.com/info_12180665_repair-kenmore-refrigerators-coil-freezing-up.html#ixzz2a25eGLEL
tests this steps and fix it. God bless you
Posted on Jul 25, 2013
  • 2 more comments
  • Simon Jul 25, 2013
    My Fridge is Jen Air Model JSD2789GES, I already changed the adaptive control board and did not resolve the problem. Should I change the heater and thermostat? How come part of the inside coil is freezed up and not the entire coil?
  • ernesto cuadra
    ernesto cuadra Jul 25, 2013
    RUN the diagnostic, before to replace the heater and thermostat. After that take your conclusion. God bless you
  • Simon Jul 26, 2013
    Can you please walk me through the diagnostic procedures? Thanks.
  • ernesto cuadra
    ernesto cuadra Jul 27, 2013
    you must read your owner manual. download from www.fitness.manualsosnline.com or from you supplier manufacturer and proceed. God bless you
My refrigerator is freezing everything I changed the door gaskets but it us stll freezing sny suggestions
If the freezer is freezing everything, check the coils. A refrigerant leak will cause ice to build up on the coils, not extra ice in the fridge. ... A leak in the compressor or coil will chill the air around the leak as long as it is outside, but a leak into the fridge could cause it to get extra cold.31 Aug 2015
How to Fix a Refrigerator that Freezes Everything - YouTube
https://www.youtube.com/watch?v=gXMJYv6kzKg refrigerator is freezing everything Google Search
Oct 23, 2017 | Refrigerators
My refrigerator keeps freezing things...,.changed the gaskets around door and still have the freezing probkem
Most fridges have a cooling vent above or on the side of the top shelf. This is where most of the cold air comes from, so keeping food away from here may preventfreezing. ... Some side-by-side refrigerators (particularly older models) feature a vent that funnels cold air from the freezer into the fridge.4 Aug 2015
How to Prevent Your Refrigerator From Accidentally Freezing Food ...
refrigerators.reviewed.com/features/how-to-prevent-accidental-food-freezing-in-fridge...or try this link... refrigerator keeps freezing things Google Search
The refrigerator is freezing the food in the lower parts of the refrigrator by the temperture in the upper part seem to be warmer
If you wish to get some details about refrigerator common fault and troubleshooting ; visit the site linked here. Pull up older posts. search with the word "Refrigerator".... http://electro-medical.blogspot.com/
Jan 22, 2017 | Refrigerators
Coils freeze
Either your coil is blocked with paper or wrap, or you have a refrigerant leak in the coil and the little bit of gas that's left is flashing as it enters the coil. Make sure that the cooling coil and condenser is clear and the fans are running. That's all you can do without refrigeration tools. Good luck and hope this helps
Apr 22, 2014 | True Refrigerated Sandwich Prep Table 72"...
My Airconditioner has ice forming and no cooling. can u suggest what the problem cud be?
Most likely a slow refrigerant leak. When the refrigerant is low, it actually gets colder and causes freezing in the coil. Another possibility is the coil is dirty, not allowing enough air flow through the coil. You didn't indicate if this is a room air conditioner or one attached to your furnace.In either case the coil should be cleaned first. Then if it is still freezing, you will need to have the leak repaired and refrigerant (freon) added to proper level.Normally the coil is not below freezing, but when the pressure drops too low it gets colder and then the condensate that normally drips off the coil freezes.
Oct 30, 2010 | Home
Frigidaire central unit freezing up leaking
The coil freezing can be caused by a couple of things. 1) Not enough air flow over the coil or 2) A low refrigerant charge. First make sure that the indoor fan is running. Then check your air filters and make sure your evaporator coil is clean. After that you can get the refrigerant charge checked. The lower the refrigerant pressure is, the lower it's boiling point is and when it gets below 32F then the evaporator coil and usually the low pressure line freeze up. The leaking you were talking about is probably from the ice melting. Hope this helps.
Jun 06, 2010 | Frigidaire Heating & Cooling
GE Profile refrigerator temperature problem
refrigerators have 2 coils. the evaporator coil and the condensing coil. one is on the bottom of the fridg and one is on the back or inside behind a false panel. these coils must be kept clean or if the condensing coil cannot reject the heat absorbed by the evaporator, the box temp will stay high and if the evap coil cant absorb heat the box temp stays low running the risk of freezing
Nov 26, 2009 | Refrigerators
Coil freezes up. i am wondering if there is a problem with the coil defrost. i also notice that the fan that is behind the coil is not running. should it be running all the time of just when the it is in...
yes the fan needs to operate or it will freeze-up, also make sure coils are clean,dirty coils will freeze,also as a last resort you may be low on freon(refrigerant)
Aug 15, 2009 | Samsung 26.0 Cu. Ft. Side-by-Side...
Coils freezing
coil freezing is a sign of under charged system. Contact aized service center for recharging of refrigerant.
I hope this helps.
Jul 21, 2009 | GE GSS20IEP Side by Side Refrigerator
Samsung RB2055Sl Top refrigerator couling coil freezing up every 2 or 3 weeks
The problem is freeze up. Bad door gasket or too much window shopping are the biggest issues. Could be low gas. Either take off the back freezer panel and defrost or unplug for 2 days to defrost fully. Oh, and clean the condenser coil. Then, let's see what the unit does.
Nov 27, 2007 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
162 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
