Question about Spec-D 1999-2004 Ford F350 Super Duty Projector Black : LHP-F25099JM-APC
No power bogs out spits and sputters but runs perfect at idle
    President:
  • 2,976 Answers
Check your accelerator pump on the side of your carburator.
Posted on Aug 21, 2013
When I start my 1996 Honda accord the engine seems to sputter rpm gauge revs up on its own and spits and sputters as I'm driving down the road
My sputtering & stalling 1993 Honda Accord - YouTube
? 2:12
https://www.youtube.com/watch?v=Ki2H9aq8Xis
Jun 23, 2011 - Uploaded by mdpbfly
My sputtering & stalling 1993 Honda Accord ... 1996 Acura Integra, hesitation accelerating & misfire. ... 1993 Honda Accord Start Up and Review 2.2 L 4-Cylinder ... SIR B16A Engine sputter/ power loss at higher RPM - Duration: 1:14. by ... 1994 Honda Civic Check Engine Light Code Retrieval Tutorial ...
All comments on How To Solve Honda Idle Problems ...
https://www.youtube.com/all_comments?v=L788jKEVblY
What should I do if once I turn on my Ac my idle drops as if it's gonna die, and .... to a complete stop the rpms start going up and the car accelerates on its own. ... Honda Accord LX, and my Honda just started sputtering in idle. check engine .... My cousin replaced my radiator on my 90 civic and since then my temp gauge is ...
Acceleration Bog/Sputter/Hesitation - Honda-Tech
honda-tech.com/honda-accord.../acceleration-bog-sputter-hesitation-279...
Jun 11, 2010 - 1990 Honda Accord Ex F22 209000 miles, recent alternator change When I ... When I take off from a stoplight I get a little hesitation/bogging/sputteringfeeling until about 2,000 RPM then ... My 1999 Accord had a similar problem (F18B2engine). ... It only lasted a second or so before it would actually rev up.
Dec 28, 2015 | Honda Cars & Trucks
I have gas leaking out of the bottom of the carbs where the drain plugs are. It only leaks when the bike is moving. Does not leak idling. It idles perfect and runs out perfect no spitting and sputtering or...
Check is the carbs have a gasket or ring on the cup of the carbs, if they have change them for new ones, if them doesn't have gasket or ring you could make them in order to help seal the cups of the carbs.
Aug 19, 2014 | Motorcycles
Possability the inlet seals on the float bowl are hard or just old and when you ride- the vibration allows too much gas to flow past the inlet seals causing the float bowls to overflow.
How long ago since the Carbs were serviced?.
No power bogs out spit and sputters under throttle but runs perfect at idle
sounds like a vacum leak or the throttle position sensor im not 100 percent sure but that what it sounds like to me
Jul 25, 2013 | 1999 Ford F350 Regular Cab
2002 buick lesabre spits sputters voltage jumps
check you have good earthing points, also check the earthing strap from engine to shell. main earthing point follow the negative lead it will go to the shell.
Jul 26, 2017 | 2002 Buick LeSabre
'01 Tahoe starts right up, idles perfect for abour 20 seconds, then starts to spit and sputter then eventually cuts off. Will start right back up and do the same theing over and over again. Fue
I just fixed mine it was doing the same thing take the air box hose off and clean the throttle body valve with some wd40 or brake cleaner the little valve will move clean inside wherever you can worked perfect for me
Nov 24, 2012 | 2001 Chevrolet Tahoe
Spec-D 1999-2004 Ford F350 Super Duty Projector Black : LHP-F25099JM-APC Logo
Top Spec-D Office Equipment & Supplies Experts
k24674
Are you a Spec-D Office Equipment and Supply Expert? Answer questions, earn points and help others
