Question about LG LWHD2500ER Wall/Window Air Conditioner
I NEED TO KNOW THE WIRE DIAGRAM FOR THIS UNIT
Need wiring schematic for Wesco Model 2100 Electric Furnace (wiring diagram)
82106c19-5c06-486e-9f9a-3e04a0a81160.pngfafba6f2-5eeb-4990-a3c3-1b3f3ae5dbc6.pngThat unit is very small with every component within 3 feet of the pigtail/power cord.
A electric heater has heat strip/s
a switch and 2 thermal limiting devices, 1 auto resetting, the other not resettable or serviceable by the user, tending to not be an economically viable option.
There are 2 hot legs of power and an earth/ground wire feeding any home or most businesses, every wire in every unit is either 1 of the 2 coming in to the building, Line 1 and Line 2.
Now if you know the sequence of operation and can recognize the components, thus locate them and are familiar with each as to what terminal is what, there is no need for a wiring diagram to tell you that 2 legs of power feed each load, be it high, low voltage, AC or DC polarity.
Every circuit requires 2 sides/legs of power Line 1 and Line 2.
Beginning on Line 1 go through the switch, to the load/device,
and from the device/load we return to the opposite side/leg of power from which we began.
Now if you do not know this and do not recognize the components thus cannot locate them other than tediously following both legs of power all over to where you know it must be anyways! as the unit in no way resembles a wiring diagram I see no use for a wiring diagram for those who know or do nor know the trade.
Oct 10, 2013 | Heating & Cooling
Need wiring harness color coded diagram for pioneer dehp3900mp
Hi, the wiring diagram is at the back of the manual. This unit has the standard wire colors for all aftermarket head units. Please get back to me with the car model and year if you need to know the car wire colors to match up.
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/130/130DEHP390.PDF
Nov 20, 2011 | Car Audio & Video
I need a wiring diagram for a generac gp15000e generator
I have a 15000 ultrasource generator the start and stop switch was taken out i need to put it back The problem is i dont know which wire goes where and when i look at the wire diagram the numbers are different the numbers on my unit are 15, 11, 133, 14, 12, The 15 and 11 are the same wires the start and stop switch has 6 males on the back to plug the wires into Does anyone know which wire goes where???
Nov 05, 2011 | Generac Guardian Ultra Source 15,000 Watt...
My rd-s590 igot the wires hooked up but when i start my truck it say see ya. then whenigotto put a cd in it come on then shut it self down i need to kno if i got the wires hook up correctly but theres...
Hello! you realy need the wire diagram that cam with your unit,,,, I do know this> there will be a wire that gets connected to 12 possitive and is hot all the time,, next there is a wire that is cannected to the acc 12 Possitive that is switched on/off with the key,
when the key is "off" then the unit should go off,,,,,,,not be on...
with out seeing your wire diagram, I will say that the red wire (should ) be connected to the 12 possitive hot all the time,,,, and the Orange wire (should) be connected to the 12 possitive acc "key switch)
Please remember : never ground your speakers to the car ground/body!!!!! you could damage your unit
Hope this helps...
Sep 20, 2011 | Car Audio & Video
I have replaced my furnace fan motor with the fd6000a masterfit. There are more wires from motor than the original and Im having trouble figuring out the schematic. There is a red, black, blue power...
Hello Kyjimplumb,
I understand that your are having a problem figuring out your wire diagram for your furnace/air handler. I need to know the make and model of the unit so that I may be able to look up the wire diagram so that I can assist you with your question.
On the diagram it should show all the wires going to the blower and there color. Sometimes you have to trace the wire in the diagram in-order to figure out weather or not it is hot is a hot wire or a common wire. You should be able to trace it to the source L1 or L2 or it may just say line this is current not common.
The motor has more wires because it has more speeds to choose from then the original single speed motor that came with your unit. You will need to wire nut the extra wires of by them selves.
Post back with make and model of the unit and I will see if I am able to help you further as not all units have the same wiring or colors.
Thank you for choosing FixYa.com
Justin
Apr 23, 2011 | Heating & Cooling
I need a wiring diagram for a 2002 883 harley sportser
If you are going to install a new ignition unit, all you basically need to know is which wire is the "HOT" wire. Disconnect all the wires to the coil, turn the ignition switch on and use a test light to find the "power" wire. Once you know which wire this is, you'll need the wiring schematic for the particular type of ignition unit you're installing on your bike. Usually, if you got the website for the manufacturer, they'll have "installation instructions" under their "Technical" section. Usually, with a dual fire ignition system, there are only three wires to hook up. Good Luck!
Feb 22, 2010 | 2004 Harley Davidson XL 883 Sportster
Need wire diagram for 3207-121189
http://www.corp.carrier.com/www/v/index.jsp?vgnextoid=9d087afdef677010VgnVCM100000cb890b80RCRD
Search this web site. It has lots of manuals. It is Carrier site.
Hope this helps. Wiring diagrams are hard to find but I know they are there if you input enough of the right info.
Hope this helps and be patient while you search.
Nov 20, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Dont know which wires are which just need colored wiring diagram
red is hot yellow is memory black is ground -tricky part is without knowing what brand of head unit you have i cant really say what anything else is-so just for kicks lets say you have a pioneer there should be 4 sets of different colored wire pairs grey white green and purple those are your speaker leads white and grey are the front speakers green and purple are the rear speakers-blue is to turn on an amp with orange is usually connected to the lights to dim the unit at night and thats about all i know
May 09, 2009 | Car Audio & Video
Wiring Diagram for Ruud Heat Pump
Unfortunately, the wiring diagrams for heat pumps are not so easy to come up with. The outdoor unit will have its own diagram, but may not include the indoor air handler and will probably not include the thermostat. That said, the orange wire is commonly run from the thermostat to the reversing valve in the outdoor unit. This wire is usually not connected to the indoor airhandler. The orange wire is usually used in a unit that has the reversing valve energized in cool. Ruud, however has its reversing valve energized in heat. Probably not useful but maybe helpful
Mike
Jan 04, 2008 | Heating & Cooling
LG LWHD2500ER Wall/Window Air Conditioner Logo
24 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
