Question about Shoprider Streamer Sport Power Chair
Chasing lights HELP! My cat did something to cause my power wheelchair to not move and the joystick control is displaying left to right chasing lights. what do I do to put the power chair back in useful mode?
    Welcome Back:
    Visited the website for 2 consecutive days.
I think it is locked. It's happened to me too. I have to admit I don't remember the exact combination but try pressing the power button then the horn button then power button again. The exact order of buttons to press is in the manual under How to lock your chair or something like that. Hope this helps.
Posted on Jun 09, 2014
My Jazzy Select HD stopped working. It turns on, but wont move. I have chasing lights going from left to right. I tried unlocking, that did not work. Any other ideas?
make sure that the free wheel levers are in drive position. Also the charger is unplugged. restart and see if that took care of it. Also check the wires coming out of the joystick that they have not been damaged somehow.
Oct 10, 2016 | Pride Jazzy Select Hd JSELECTHD
Tip
UnLocking Sleep and Lock Modes for Pride and Invacare power chairs
<p><b><span>Pride Joysticks and others that use VSI joysticks</SPAN></B><br><p><b><span>SLEEP MODE</SPAN></B><br><p><span>Your VSI controller has a sleep mode feature. Sleep mode is a built-in circuit </SPAN><span>that automatically shuts off the main power if the joystick is not moved </SPAN><span>in any direction for a period of time predetermined by controller program.</SPAN><br><p><span><b>The battery condition meter lights on the keypad indicate sleep mode by </b></SPAN><span><b>blinking once every five seconds.</b> To restore power and continue, push the </SPAN><span>on/off key twice.</SPAN><br><p><span> </SPAN><br><p><b><span>Lock Mode</SPAN></B><br><p><b><span>To unlock the VSI:</SPAN></B><br><p><span>1. Press the on/off key and power on the VSI. <b>The maximum speed/profile </b></SPAN><span><b>indicator should ripple side to side</b>.</SPAN><br><p><span>2. Push the joystick to the full forward position until the VSI beeps.</SPAN><br><p><span>3. Pull the joystick to the full rearward position until the VSI beeps.</SPAN><br><p><span>4. Release the joystick. There should be a long beep.</SPAN><br><p><span>5. The VSI is now unlocked.</SPAN><br><p><span> </SPAN><br><p><i><span>Invacare and others that use SPJ+ joysticks</SPAN></I><br><p><i><span></SPAN></I><i><span>FOR SPJ+ Joysticks</SPAN></I><br><p><i><span><b>Lock Mode will be indicated by all LEDs</b></SPAN></I><br><p><i><span><b>flashing briefly and the information gauge</b></SPAN></I><br><p><i><span><b>LEDs chasing slowly from right to left</b>. If</SPAN></I><br><p><i><span>this occurs, press the horn button two times</SPAN></I><br><p><i><span>within ten seconds to unlock the joystick.</SPAN></I><span></SPAN>
on Nov 16, 2010 | Health & Beauty
Unlock a spj+ joystick on a pronto m41
Lets make sure this is just the joystick lock mode. When you turn the chair on and it is in joystick lock mode all the battery level lights will chase across several times and then the joystick will turn off.
When you turn the chair on and you see the battery level lights chasing from right to left push and hold down the power button till the lights turn off. Only the first year that the M41 was made had this option.
Jan 23, 2015 | Electric Mobility Invacare Pronto M41...
I have a Quickie S646SE wheelchair with a Qtronics Pilot+ romote controller. I charged the chair last night. When I turned it on today the profile lights scroll left to right and the chair does not move. I...
Press and hold power button til beep then push joystick forward and hold joystick til beep then pull the joystick back and hold joystick til beeps. turn power off then on. should be unlocked now
Mar 17, 2014 | Quickie Wheelchairs Quickie S-646 Power...
Have replaced joystick and motor controller, but chair turns left when joystick is moved to right. also, motion seems eratic,what can I do????
sorry to tell u this but with a new controller and joystick u will need a tech with a programmer to redo the joystick and det up controller,so contact a dealer for help
Oct 24, 2013 | NRS Used Merit MP 3CR Power Wheelchair
Wwe have a pronto m41 mobility chair.the service indicator light is telling me its a right brake problem can i fix this and how. also the led lights are chasing left to right. i have to get this working...
First thing you must know is that the error codes are reversed on Pronto chairs with SPJ+ joysticks.
Only one year the M41 was made that the codes were correct. From approximately April 2008 to May 2009 was the only time a left error code ment left motor and a right code ment a right motor. Same for brake codes.
Brakes codes happen when the brake is out of gear, unplugged from the control brain or wire cut. Also from internal coil damage. Unless it's a wire you can reconnect you cannot fix the brake.
Dec 23, 2010 | Electric Mobility Invacare Pronto M41...
When I plug it in to charge the red and amber lights stay lit and the green flashes and if i move the joystick everything is backwards push forward goes backwards left is right. b4 when it was plugged in...
I wouuld suspect a controller problem Since the programming is in the controller and it suddenly changed your operation I would expect something screwed up the controller. Have your provider check it with an Invacare programmer to make sure that the settings for your chair are correct in the controller. If Medicare paid for your chair then you can contact Roadrunner Mobility @ 1-800-467-2668 and have them send out a tech to work on your chair. They will bill Medicare for most of the repair costs Hope this helps
Oct 31, 2010 | Invacare Pronto M51 Power Wheelchair
The speed control light goes back and fourth on the console.
If the lights are chasing left to right then you are in inhibit mode meaning a charger is attached or there is a problem in the joystick with the inhibit functio. Right to left chasing I think means you are in freewheel. Turn the Power off and reset the levers in front on the chair then turn the power back on and hope the lights are steady and the chair will work. If this doesn't do it maybe you are in lockout mode. If you have the manual for this chair it should explain how to get out of "lockout". If not try turning the power on and within 10 seconds push the joystick straight forward and hold until you hear a beep then immediately move the joystick to the rear and hold until you hear another beep then release joystick to the center. This should get it out of "lockout" Hope this helps!!! Of course you could always call Hoveround and ask for tech support to help with this. Checkout their website for phone number Hoveround.com
Aug 19, 2010 | NRS Hoveround MPV 5 - Used Power...
The charge indicator lights flash left to right..when moving joystick the chair does not move.
chair is locked out. turn on then push joystick forward till it beeps then pull backward till it beeps then it is unlocked
Jun 15, 2010 | Invacare Pronto M51 Power Wheelchair
My Jazzy select wheelchair does not run
you move the joystick and can hear something quicking in the motors
May 17, 2009 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
Shoprider Streamer Sport Power Chair Logo
101 people viewed this question
Top Shoprider Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you a Shoprider Health and Beauty Expert? Answer questions, earn points and help others
