Question about Orbit Watermaster 6 Station Dual Program Sprinkler Timer 57196
57196 How to program for three day
Battery location orbit watermaster sprinkler timer 57194 or 57196
usually located on back or bottom near the selector buttons
Oct 11, 2017 | Orbit Hardware & Accessories
I have a 12 station Orbit Model #57900and I want to water the same stations two to three times a day
Program modes
Program A or 1 is your primary program setting. All Zones will run on this program.
Select program B. Or 2
Set start time for program B usually an hour or two after the LAST zone (12) run time on program A or 1
1. set selected run time for the zones you want to run. 5 min -20 min ( leave the others 00:00 or off)
Select program C or 3
And repeat above.
Keep track of the start times of each program as 12 zones running for 10 min will add up to 120 min or 2 hours total. So if Program A/1 starts at 6am it will finish at 8 am. Set program B/2 start time at 11am. Them select the specific area/zone you want to run again will water the area a second time. Just remember to leave the other areas you don't want to water Set at 00:00 or off. Repeat through all the programs and you off to enjoy your day. Cheers
Jun 06, 2016 | Orbit Hardware & Accessories
Plz tell me why left side of my laptop suddenly get darken..this can be solved only by restrart. can anybody tell me why this is happening & hw it can solved. i m using hp pavilion g4 & about
Is it only darken after the startup? meaning it is not the hardware problem?
What operating system are you using?
Perhaps you could upgrade to Windows 8, or just uninstall all programs that you do not really feel safe with -- you say for the last two three days -- look into the programs list and see if you installed something during those days - if so - get rid of them and make a virus sweep - perhaps use Avast free anti virus program
The best solution is to backup all your important files, then format your Harddisk and install Windows 8
Feb 13, 2013 | Computers & Internet
Need instruction manual for orbit sprinkler timer model 57196
Copy following link for Orbit Sprinkler timer manuals
http://www.orbitonline.com/support/guides/Manualsearch3.cfm?Brand=01&Type=Timers
Copy following link for various brand name sprinkler timer manuals, including Nelson, Melnor etc if you need new timer
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
Sep 10, 2012 | Hardware & Accessories
Hey i;m hector : MY PROBLEM / 7 DAYS SETUP NO WORK ; ( ej: TIME ON 8.00PM- TIME OFF 5.00AM( SEME DAYS MONDAY TO SUNDAYS?
Hi Hector.
You posted under ET171C8.
You have the timer in front of you, and whole manual cannot be repeated. So there are two options
1) Free option: Add a comment and say specifically where the programming is tricky. If you don't understand the buttons, or if display doesn't show, or if you can't find all days by pushing day button, or if you can't find the am pm choice.
2) Pay for fixya expert to walk you through each step via e-mail.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/et171c%20-%20english.ashx
http://www.intermatic.com/products/timers/electronic%20time%20switches/7%20day%2030%20amp.aspx
If display shows, then battery is correctly installed.
Instructions copied from manual:
1) RESET TIME SWITCH: Press the recessed RESET switch to reset the
microprocessor and delete any set point information which has been
programmed. NOTE: DO NOT press RESET after programming has
begun or you will lose all of your program information.
2) TO SET TIME AND DAY OF WEEK: Place the three position selector
in PROGRAM and the two position selector in CLK mode. Press the
HOUR, MINUTE and DAY buttons individually to select the current time
of day (12 hour AM/PM repeating) and the day of the week. Day 1 is
Sunday, day 2 is Monday, etc.
3) TO PROGRAM SET POINTS: Select PROGRAM mode with the three
position selector and OUTPUT mode with the two position selector.
Press the HOUR and MINUTE buttons separately to program the first set point time desired.
Press the DAY button to select the day the event is to occur.
Press the ON/OFF button to select an ON or OFF set point.
Press the ENTER button to enter that set point for the selected day.
Note that the ON or OFF indicator stops flashing only after pressing ENTER. If this set point is to occur for other days of the week, simply press the DAY button to select the next day then ENTER. Repeat for any additional days. Note that this allows you to utilize one set point for
any or all days of the week.
Then set timer to AUTO for programs to operate
Apr 26, 2011 | Intermatic ET171C8 Electronic Timer
When I access my Yahoo Mail; I get blank page, an hour glass appears, and then the computer shows that the program is not responding. I have not been able to open and read my email for three days.
when I access my yahoomail ! classic, I get page about blank writen on the computer result and after some time it shows,program is not respondig since four days. What should I do.
Dec 17, 2009 | Yahoo Mail
How to set the three cycc-les per day
You need to provide more info....If you're talking about programming the Thermostat you click "Program"...and scroll through the days,times and temperature you want...if you leave a field blank it will simply stay on the previous program
Oct 20, 2009 | Honeywell Electronic Programmable...
Off power Orbit watermaster 57196
I am having the same problem, did anyone find the solution to ths?
Jul 07, 2009 | Garden
Hit program button and the screen blinks fast
try to replace your batteries otherwise im not sure sorry i couldn't be more help :(
Jun 14, 2009 | Texas Instruments TI-83 Plus Calculator
Orbit Watermaster 6 Station Dual Program Sprinkler Timer 57196 Logo
15 people viewed this question
Top Orbit Video Cameras Experts
richie46
Tom Chichester
Tony Parsons
Tony Parsons
Are you an Orbit Video Camera Expert? Answer questions, earn points and help others
