Question about Acer Aspire Computers & Internet
What does it mean when my acer laptop light bulb, battery and power button are all flashing at the same time?
  • 3940 Answers
SOURCE: Battery Light Flashes Orange and Green
The LED sequence indicates a failure in the battery. (Like one cell has low charge) As long as the overall battery output meets the minimum for system operation, the battery will work.
The average lifespan for a Portable battery is about 500 discharge/recharge cycles (1 to 2 years) anything after that is a bonus
Replace the battery, issue will go away
Posted on Nov 18, 2008
El Geek
  • 148 Answers
I have had three different laptops, last one an XPS from DELL which did the same thing. Replacing the battery solved all three laptops. How old is the battery you have in there now?
Posted on Jun 02, 2009
Damilare
  • 358 Answers
SOURCE: LG x110 laptop power supply problem:
To be very sure of what the problem is, try to test the your laptop with a another friend's battery, or through a technician first. If it powers, then try and test the laptop again with another AC Adapter, from someone who uses the same type, or a technician.
Trying out these two things will give you a clearer and better idea of what might have gone wrong.
Hope it helps you out.
Posted on Jul 13, 2009
heavymetal77
  • 721 Answers
SOURCE: Gateway laptop model W350i will not boot. When
It's a hardware failure like a cpu fan not working or faulty ram.Check the gateway site for an explanation of the lights. It's flashing a trouble code.
Posted on Jul 14, 2009
anandsharad
  • 137 Answers
SOURCE: Laptop will not boot. The power light flashes
CLICK HERE
the codes which you see are universal for all the dell laptops. find the appropriate. this will solve your purpose and guide you how to go furthur.
Posted on Sep 26, 2009
Aspire 1 laptop won't turn on but the light bulb
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.
Apr 02, 2012 | Acer Computers & Internet
Acer aspire netbook wont turn on flashing white light on power button
Did you try to flash a new BIOS? If so, you might be in trouble and
need probably to reflash the new BIOS. (Look at Acer site for info).
But anyway try:
1. Push and hold the Power On switch for 4-6 seconds.
Try to Power On again.
2. If this does not work, do a Power Reset:
- Disconnect powersupply cable and pull out the battery.
- Hold the Power button for 60 seconds a few times.
- Place the battery and powercupply cable.
- Try to Power On.
Aug 04, 2011 | Acer Computers & Internet
HI , I have an Acer ZG5 netbook. The unit will not turn on, i mean nothing. The wall charger works. The battery light shows its charged. When I push the power button, nothing happens. When I hold the power...
my acer netbook will not come on.the charger is working,i took the battery out ,and still the battery light and the power button blinks at the same time.And after pressing the power button constantly, the screen blink on and off every now and then.
May 08, 2011 | Acer Aspire One Netbook 8.9" Notebook
On the front of my Aspire 5610, the red light is flashing next to the light bulb symbol
Light 'OFF' - you are on Battery
Light 'ON' - you are charging the Battery
Light 'flashing' - Battery BAD.
Time for a new battery :(
Aug 23, 2010 | Acer Aspire 5610-4648 Notebook
I shut my laptop down and it would not start back up. The green battery light is solid but the light bulb power light now longer display. The way it's put together; I can get to the connection to see if...
Remove the battery the memory the ac cord .Press and hold the power button for twenty seconds.If you cant get to the memory don't worry about it. THE OBJECT OF THIS EXERCISE IS TO TRY TO RESET THE COMPUTER.
GOOD LUCK
Sep 17, 2009 | Acer Extensa 5420-5687 Notebook
Aspire 1640, when i press power button, battery light flashes a few times and then nothing
that means it's not powering up... Take out the battery...hold power button for about 60secs and start the laptop with the adapter...if laptop powers up this will clear one thing...it's the battery if not then might be your adapter...check the voltage...try plugging in another adapter. Check the battery if it's working with any other laptop. Try lightening the laptop remove any external attachments[printers,scanners,pen drives etc.] All this you can try on your own and other than this leads to internal problems.Call any authorized personal from the company.
Aug 02, 2009 | Acer Aspire 1640Z Notebook
Computers & Internet Logo
41 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
