Question about Jabra BT250 Consumer Headset
Jabra bt250v Indicator light doesn't remain on...
I received a set of the jabra headsets and discovered that the indicator light doesn't stay on while charging. It flashes on for a split second once piece is inserted...and after unit is left alone for a time to charge, the unit won't power on. Is it the charger or the Jabra bt250v? Thanks for your help!
  • 14 more comments
  • sacmund Dec 02, 2007
    With my set of the jabra headsets the indicator light doesn't stay on while charging. It flashes on for a second once piece is inserted and after unit is left alone for a time to charge, the unit won't power on. Now i dont understand whether the carger is a problem or my headset.
  • Anonymous Jan 15, 2008
    Jabra bt250v will not charge up.
  • RAM64 Apr 07, 2008
  • jabra250 Apr 13, 2008
    same problem with the bt250
  • MFM Angel Apr 18, 2008
    Same problem here?
  • Chrissyace May 08, 2008
    I have exactly the same problem. Does the headset have a battery on the inside of it that needs replacing? I have used it in the past and had no issues with charging but after a years in the cupboard it now does the same thing flashes once and then nothing. Does anyone know if it has to have a replacement battery in the headset. Perhaps that's why as it's fairly old now.?????
  • moiraf May 22, 2008
    light does not stay on while charging
  • kbubbles May 24, 2008
    Just bought my jabra bt250v and having the same problem. How do I fix it?
  • elequiero Jul 24, 2008
    I have the same problem with my BT205.
    Has anyone got a solution?
  • matwork Aug 17, 2008
    I bought this as a gift for a friend and they decided it wasn't of much use at the time. When they decided to use it, still brand new it doesn't hold a charge. the blue light doesn't stay on. Is it the charger or the phone?
  • Anonymous Sep 03, 2008
    tried two new ones two days apart ....same issue on both. the company i baught from tells me final sale on all these items....i dont think so ...it was bunked to start with
  • Norman Korell
    Norman Korell Nov 21, 2008
    I dissassembled the unit (out of warranty anyways) to find that the battey is very accessible.
    Amperex Technology Limited
    3.7V 125 mAh
    #26-00046
    http://www.atlbattery.com/eng/
    I have contacted them to ask about availability of replacements. No reponse as yet
    If I can get the battery it should be easy to replace. The leads are very exposed. will update post later if anything develops
  • whenshivospe Jan 21, 2009
    same issue
  • Anonymous Feb 05, 2009
    Haven't used the headset for a long time. Just got it out and put it in the charger. Got the same problem.
  • Anonymous Apr 28, 2009
    I have the same problem...
    I never used the headset but still cannot charge it !!
  • jonixxxxxx May 06, 2009
    same problem.just got 1.light doesnt show up while charging.no luck for me...
  • 4 Answers
I have just repaired my bt250 with this problem, i hadn't used it for around 2 years and when i put it on charge just got i flash of blue led. the fix was to "jumpstart it" the headset needs to se some sort of battery voltage to start the charging process, i stripped mine right down but that was just to fiddley. IF YOU DO THIS IT WILL BE ENTIRLEY AT YOUR OWN RISK AND I TAKE NO RESPONSIBILITY IF YOU TRASH YOUR OTHERWISE USELESS HEADSET. ok all you need to do is very carefully remove back cover (undo 1 screw and ease it apart). be very carefull as there are delicate wires inside. lift the inner part out slowly and you will see the battery.it has some orange tape around the end and there is a small circuit board attached to it with a small red wire and a small black wire. look at the battery and you will see under the orange tape there are to larger tags.these are the main battery terminals, peel back the orange tape just until the tags are slightly exposed. now you need to solder a wire to each of them and DON'T TOUCH THEM TOGETHER. on the battery it says which tag is + and which is - make sure you mark your wires or get red and black ones. now i used the lead from the charger. look at it . it has a hole in the center of the pin that is the + so put the + wire in there. if you are not sure use a volt meter. now touch the - wire to the outer metal of the connector that is the - point on the charger connector. hold this for around 2 mins but no more. as the out put of the connector is 6.2v and the battery is only 3.7v the battery will get warm. if the battery is getting too hot in under 2 mins then take of charge. when you have done that and taken off the connector i recommend to use a volt meter and just put it on the battery wires you soldered on to check battery voltage. as long as it reads you should be ok. de solder your wires from the tags and rebuild headset then try and charge it. this worked for me. i am no electronics expert i just like to mess with broken stuff so i know it seems a bit dodgy to connect like this but i had nothing to lose and it worked.
Posted on Dec 01, 2008
  • 15 more comments
  • smtlogistics Oct 16, 2010
    Spot on, I didn't solder, just held the two wires to the terminals for 1min and it came to life and now charges. Thanks a mil.
  • krix003 Oct 18, 2010
    Bang on mate ,
    stripped two ends of the wire twist that came wrapped around charging lead .
    twisted end round outer of charging adapter and pushed other end through yellow plastic onto - of battery connection ,
    then got sowing needle in inside connection of adapter and poked the pin end through yellow tinted plastic against positive connector for ten seconds
    held headset together and slid back in charger and blue light stayed on
    so reassembled and works superb
  • gizarm Feb 06, 2011
    I had not used this Jabra 250 in years and had the same problem-would not charge. I followed the instructions from dididocky and like magic the blue light appeared and the unit fully charged within a couple of hours. Many,many thanks.
  • tgr1234 Feb 20, 2011
    I pulled out my old Jabra BCE 250 after something like 5 or 6 years in the drawer. It wouldn't charge. I found this post and it worked great. Thanks much!
  • anotherjames Mar 03, 2011
    Fantastic solution. Even better than using solder - just insert a pin into the ve centre of the AC adapter and use this to touch the ve battery terminal, whilst holding the -ve outer against the -ve terminal; works a treat.
  • fletch1694 Mar 04, 2011
    Brilliant, easy to do,instant solution, only took a connection of 10 secs to cure. Thanks, where would we be without people like you. Fletch
  • baynicbe Mar 14, 2011
    Works like a charm!
  • dididocky Mar 29, 2011
    Thanks guys, thought id just put my head in and see how this is going after 2 years and to see that it still works for you all make me feel good. thanks for the good comments. and glad it has been modified slightly so as not to use solder, i only did that because i was taking it apart anyway just trying to repair it. although my headset speaker blew in the end so i had to replace it anyway,
  • JoshSeaBass Apr 26, 2011
    Worked like a charm. My BT250 was dormant for years but lives again thanks to this info! Biggup yourself!
  • chuter4 Jun 27, 2011
    i have 2 bt250 with this problem, i opened it up to have a look and im lost i see the prange tape i see the circuit board i cant see no + - and are the bigger tabs on the back of the battery?
    help
    i have 2 units same thing took them apart can see orange tape are the + - where the black an red wires are soldered on the circuit board? i can see them on mine! please help
  • dididocky Jun 27, 2011
    its been 3 years since i done this and to be honest i can't remeber to much without looking at another headset but mine is gone now, you should be able to see the gold looking tabs on the battery and the markings + - are small next to the tabs if you can see through the tape i cant remember but would think there are 2 wires on the battery 1 black 1 red, red is + black - seems its best not to solder solder as i did, read the comments and there are aa few tips there that othres have done to do it. just remember hold wires on for 2 min max probably not need that long
  • dcb64 May 17, 2012
    was fantastic,my headset is working agein!!
    is fantastic,my headset is working again, this after more than 3 years....
  • jfos5
    jfos5 Aug 04, 2012
    that worked a treat m8 thanks
  • jfos5
    jfos5 Aug 04, 2012
    worked a treat m8 cheers
  • Menno van Dellen
    Menno van Dellen Aug 19, 2014
    worked like a charm!
Dididocky, your solution worked perfectly! My only mod was to just hold test lead probes on the battery terminals rather than soldering on wires -- mucho kudos to your solution!!!
Posted on Aug 29, 2009
I confirmed with Jabra that the headset usses a non-standard battery with integral circuitry, and of course not offered as a replacement part. The best solution is to not purchase products from a manufacturer that sells devices that are known to contain such engineering constraints that limit the product life. As they say, "You buy junk, you get junk."
Posted on Oct 12, 2008
Jump starting the battery worked for me, thanks for the suggestion, GREAT JOB,,,,,,,
Posted on Mar 01, 2009
  • 47 Answers
I was looking for a solution for a similar problem... The circuit on the internal battery has an issue and I cannot measure the voltage through it correctly. The battery reads 3,55 V, while the circuit reads 0,55 V. So, I have the same problem as above then... A blue flash and nothing else, no charge... I am going to remove the circuit of the battery and connect it directly to the charger pins. I believe this will not cause any issues. At least, I will be able to charge the headset this way. I will post once more should this method fails.
Posted on Jan 07, 2010
Just wanted to say thanks to dididocky I had never used my Jabra BT205 and when i dicided to, same problem. You solution worked perfectly.
Posted on Sep 29, 2009
Dididocky's solution worked perfectly. Just touched a wire from the inside (hole) of the charger plug to the + of the tiny battery tab under the orange tape and the outter ring of the charger plug to the - tab for about 2 minutes. Wha-lah! Blue light is on and the unit charges!!!
Posted on Mar 16, 2010
Junp starting is great! i just taped the wires on.
waited 5 mins, put it back together and voila!
Cheers.
Posted on Jan 11, 2010
Yes this device has a battery installed that has a appearant life of maybe two years depending on how often it's used. The battery is approx 1.5 inch in length and is not replacable.
Posted on Aug 07, 2008
    New Friend:
  • 3 Answers
Remarkable it worked a dream - Thanks for the tip. The battery does swell up a little during the charge but this is to be expected I suppose.
Posted on Mar 09, 2013
Thanks, this helped a lot. My BT250 would not charge. Blue light was steady and flickering, but nothing. I opened up the BT250, dismanteld the battery. I measured 0,34v. So I used some old wires, connected them to the charger and jumpstarted the battery on the larger terminals (flip the circuit board over) for 1 minute. I then measured 3,4v. So no need to solder anything. Repackaged everything and hooked up the charger. BT250 will now turn on and off as usual.
Posted on Oct 16, 2011
Amazing!! Followed dididocki's solution, blue light back on! No soldering, just held wires in contact for 30 seconds and hey presto!
Posted on Jul 10, 2010
Didicocky - worked great. Only slight worry was the battery swelled up a little, but I may have left it on too long. Got the blue light on now and chasrging as usual.
Great answer !
Posted on Apr 24, 2010
Jabra 250V headsets kept unused for a longtime in the packing as new and later when its was put in use it was discovered that the indicator light doesn't stay on while charging. It flashes on for a split second once piece is inserted...and after unit is left alone for a time to charge, the unit won't power on, looks like the battery is kranked
Posted on Jul 16, 2008
Battery is knackered.
Posted on Sep 24, 2007
Dididocky you are a star, followed your instructions and now my headset is working and charging properly. A little bit nerve wracking and fiddley but even I as a big handed truck driver managed to do it. Thanks
Posted on Mar 08, 2010
SOURCE:
How do i pair my jabra head to my phome
Hold the power button down until it either beeps or the indicator light stays lighted (this usually indicates pairing mode, might want to check manual to verify). Once headset is in pairing mode, go to phone's blue tooth settings and choose "pair" or "search for devices". This is pretty much the standard method for pairing devices using BT technology.
Jul 18, 2014 | Jabra Radio Communications
I want to connect my Jabra 0te3 blutooth headset to my laptop fujitsu P3010 in win 7 but my bluetooth is not finding jabra. how can i pair it.
1) Ensure that your Jabra headset is turned completely off. Press the tap button on the headset until it ceases flashing and the light goes off.
2) Hold down the tap button to power your Jabra headset back on. Keep holding the power button until the lit power indicator cycles past flashing mode and becomes solid.
3) Release the power button.
4) Navigate through your cell phone "Settings" menu and ensure your "Bluetooth" or "Hands-free" section is set to the "On" or "Active" mode.
5) Choose "Search for new devices" or "Find new devices" on your phone's Bluetooth or hands-free menu.
6) Place the Jabra headset close to your phone to ensure it can be discovered by your cell phone.
7) Select a "Connect" or "Pair" option once the Jabra headset name displays on your cell phone.
8) Enter the default passcode by entering "0000" on your cell phone keypad.
9) Ensure that the Jabra headset has been paired. Look for the Bluetooth icon in the upper portion of your cell phone screen. Make a call to verify that audio is being routed through the Jabra headset.
Dec 22, 2010 | Computers & Internet
How do I sink my Jabra BT4051 with my Nokia 2720a . I do not have a manual any more.
Usually the following setup is required to Pair bluetooth headset with mobile phone. Your mobile phone should support bluetooth interface. 1. Put the headset in pairing mode ? Make sure the headset is off. ? Press the on/off/pairing button marked until the LED indicator light is solid blue. 2. Set your Bluetooth phone to ?discover? the Jabra device Follow your phone?s instruction guide. This usually involves going to a ?setup,? ?connect? or ?Bluetooth? menu on your phone and selecting the option to ?discover? or ?add? a Bluetooth device.* 3. Your phone will find the Jabra device' Your phone then asks if you want to pair with it. Accept by pressing ?Yes? or ?OK? on the phone and confirm with the passkey or PIN = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing, repeat steps 1 to 3.
May 12, 2010 | Jabra BT4051 Bluetooth Headset
I have been given a Jabra BT 250v hands free head set
It should have come with a small 45 mm diameter cradle base unit which the mains has a 1.4 mm jack plug plugs in and the headset rests in.
Look for it on Jabra support website or pictures on a search on Ebay
Search on Ebay for one for a replacement.
Dec 26, 2009 | Jabra BT250 Consumer Headset
Cant find a manual jabra bt4051 bluetooth
abra burst onto the audio microtechnology scene in the early 1980s, gaining initial attention for its Macintosh EarPHONE telephony products. Jabra's cell phonemag-glass_10x10.gif Bluetooth headsets have also garnered wide acclaim for their sleek aesthetics and compact form. Jabra Bluetooth headsets can be connected or "paired" with virtually any cell phone by using a few simple steps.
  1. Ensure that your Jabra headset is turned completely off. Press the tap button on the headset until it ceases flashing and the light goes off.
  2. Step 2 Hold down the tap button to power your Jabra headset back on. Keep holding the power button until the lit power indicator cycles past flashing mode and becomes solid.
  3. Step 3 Release the power button.
  4. Step 4 Navigate through your cell phone "Settings" menu and ensure your "Bluetoothmag-glass_10x10.gif" or "Hands-free" section is set to the "On" or "Active" mode.
  5. Step 5 Elect to "Search for new devices" or "Find new devices" on your phone's Bluetooth or hands-free menu.
  6. Step 6 Place the Jabra headset close to your phone to ensure it can be discovered by your cell phone.
  7. Step 7 Select a "Connect" or "Pair" option once the Jabra headset name is discovered and displays on your cell phone.
  8. Step 8 Enter the default passcode by entering "0000" on your cell phone keypad.
  9. Step 9 Ensure that the Jabra headset has been paired. Look for the Bluetooth icon in the upper portion of your cell phone screen. Make a call to verify that audio is being routed through the Jabra headset.
Nov 12, 2009 | Cell Phones
JABRA BT250V Hearing Problem
Cannot get my Jabra BT 250v to work with my Blackberry Curve 8310. Phone indicates I am paired, but there is no audio through earpiece. You can still hear audio through phone. Help.
Jun 18, 2008 | Jabra BT250 Consumer Headset
BT250v vibrating after picking up the call
Check Jabra website for manual.
It is a simple hold volumne button up or down when switching on or off to disable /enable it
Apr 21, 2008 | Jabra BT250 Consumer Headset
Problem charging the device
This has been answered on this site try this link
http://www.fixya.com/support/t190081-jabra_bt250v_indicator_light_doesnt
Dec 02, 2007 | Jabra BT250 Consumer Headset
Jabra bt 250v not charging or cannot use headset.
Try this link to help you on this site it is a battery problem
Sep 28, 2007 | Jabra BT250 Consumer Headset
Jabra BT250 Consumer Headset Logo
12,260 people viewed this question
Top Jabra Radio Communications Experts
Anthony Ward
Anthony Ward
Bobby G
Bobby G
Damen Wong
Damen Wong
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
