Tem pro 2000 heat pump
Need a water tempature probe
2 Suggested Answers
kingkash90
  • 8 Answers
SOURCE: over heating
check to make sure your head gasket is okay not warp
Posted on May 03, 2014
Over heating
May 02, 2014 | 2000 Nissan Quest
Waterco 4555100e spa pump
most timers run on a 24 hour cycle may need to reset the timer so the tub will run until the desired tem is reached OR drain some water out and refill with hot water from your in-house heater..help it catch up..
Jan 10, 2014 | Pool & Spa
2000 VW Beelte - Car smelt like antifreeze the day we bought it, 2 weeks ago. Had radiator flushed and tempature light came on after 4 or 5 days. Need a second opinion, could this possibly be a leak in the...
Check to make sure that the rubber o-ring going into the heater core located under the hood on the passenger side does not need replaced. Also check the water pump, these are both very common problems with volkswagen.
May 04, 2011 | 2000 Volkswagen Beetle
Heat is luke warm and coolant temp gauge not getting to operating tempature. installed a new thermostat with the valve up on the thermostat. removed the heater control valve to make sure it was functioning...
this is probibly a blockage in the radiator or water pump issue start by flushing the radiator,then check that water is flowing thru the radiator and water system.
Dec 21, 2010 | 2000 Honda Accord
Need to keep turning up tempature to get hot water
The thermostat probe inside the tank is scaling up with mineral buildup. You can drain the tank and then remove the control. Soak the thermostats probe in vinegar and a little baking soda. Do not let the mix get into the control box. Reinstall the control once the scale is removed. If this does not help, you will need to replace the control box.
Sep 13, 2010 | Reliance Natural Gas Water Heater Control
My Maytag wall oven CWE9000ACB is giving me a fault code F2.
The F2 fault code is usually for a out of limit tempature reading due to a faulty temp probe or excessive temp during clean cycle with door unlocked. If you have disconnected the power for over 10 minutes and the error keeps coming back then you will need to test the tempature probe to see if it is defective. Test with a OHM meter and at room tempature most probes should read around 1100-1300 ohms. if the reading is way off or open then replace the tempature probe.
Jan 18, 2010 | Sears 61301 Gas Kitchen Range
Range over heats and flashes error code f3-e2 Whirlpool
That is a bake range over tempature error. First try disconnecting the power to the range for more than 10 minutes and see if the error re-appears. If it does then you will need to test the tempature probe with an ohm meter. At room tempature the probe should test 1000 to 1100 ohms. If you get a reading that is out of range or different ohms than rated replace the probe. If the probe tests good then replace the control.
Jan 17, 2010 | Whirlpool Ovens
This is an early model livia 90 (~1994). Problem is no heating of water. Pump works but neither heating light or pump light comes on. I determined the power relay was not closing. Replaced it with new...
Hi
I would check the level probes on top of the boiler. There is a yellow wire going to the high level( left) and a green wire going to the low (right) probe. The probes get scaled and do not sense water. If there is no sensing of the right probe ( low water) it will not heat. They both need to be cleaned. There is a nut or a big nut that will allow for the removal. Clean both probes and it should go back to normal.
Dec 26, 2009 | Pasquini Livia 90 Espresso Machine
Wolf wall oven error message: RTD Open
RTD is resistence tempature detector. The oven is telling you that the tempature probe circuit is open. The temapture probe may have been damaged due to the self-cleaning cycle or it could just be the wiring harness is loose. You will need to remove the tempature probe and test it with a ohm meter. The average reading should be aroun 1200 ohms at room tempature. If it is testing open or the ohm reading is way off then you will need to replace the tempature probe. If it is testing good then it could be aproblem with the control board.
Dec 19, 2009 | Ovens
The tempature doesn't register
there should be a reset somewhere you might try that first
Apr 24, 2009 | Heating & Cooling
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
