Question about Cooktops
My miele km490 induction cooktop turns off during cooking. I turn it back on and after a few minutes it turns off again. The boost buttons are not working either but unit still turns on and I am able to cook with it but just turns off throughout cooking process. I have had my cook top for 9 years and it has been fine up until a few months ago. Anyone had similar problem?
localwonder
  • 6784 Answers
SOURCE: all cook top burners spark when any is turned on
OK, the best action is to call for service, if the unit was just installed, and purchased. This unit should be covered at this time, by the manufactures warranty, or store 30 day warranty. This repair should be free. The culprit will be a faulty spark ignition switch, and module. Testing is required. Once this switch, or(module), is replaced, the unit will operate correctly.
Posted on Nov 04, 2009
jyackle5
  • 8197 Answers
SOURCE: How do I know if I have fully turned off the cook top?
The orange light is on to tell you the suffuse is still hot. It should go off after 15 minutes.
Posted on May 26, 2010
  • 906 Answers
SOURCE: induction cook tops
good day,
hope this link below will solve your problem.
kitchen appliances
Posted on Jul 31, 2010
SOURCE: Cooktop shut off and lock itself up
36" electric wolf brand cooktop. Goes off completely after just few seconds sometimes 30 sec. sometimes minute..Repair man looked at it-thinks either something electrical or some sensor messed up.He took apart look at electric ribbon nothing looked over puts back together..turns on and it goes completely blank again..no error codes..any suggestions
Posted on Aug 20, 2010
BElectric
  • 1140 Answers
SOURCE: My miele induction schott ceran
If you have an illuminated red key symbol on the cooktop, press down where the illuminated red key is, for about 5 seconds. This method works on many Schott Ceran / Miele cooktops including the KM443 listed above.
If this doesn't work, please let me know the correct model number.
Hope this helps.
Regards,
BElectric
Posted on Apr 25, 2011
I turned my power off and when I turned it back on my Miele 5733 is beeping and giving me a 30 error code. How do I make it stop?
No handbook? Go online to the main Miele importer HQ or go to Miele in Germany website and usually there are handbooks to download. If not message Miele service centre and they will help.
May 20, 2014 | Miele Induction Cooktop
Telefunken spare parts australia
Try turning off the power for a short while to allow the p c board to re set itself turn it back on and individually turn on each elements for a few minutes. Good luck
Ray
Apr 16, 2014 | Kuppersbusch Glass ceramic induction hob...
Replacement glass top miele KM5773 36
THERE ARE SEVERAL WEBSITES SELLING MIELE
parts: Search them and contact them:
Technical Service
Miele Parts Partmaster
Find Miele Spares and Accessories
Accessories
Expanda your search with google, use terms
MIELE PARTS
Apr 10, 2013 | Miele "KM5773 36"" Ceran Glass Induction...
Miele Fault Code FE 30
I have the same FE 30 problem on my KM5733 Induction cooktop whenever it's circuit breaker/isolation switch (in my house's fuse box) has been turned off and then on again. I have turned in back on after waiting a day or longer (figuring it needed to reset itself?) and the results have been hit and miss and I have had no idea why it would work sometimes and not others. Needless to say, I've trolled the net looking for answers and Miele online support is useless (unless you're ok with shelling out loads of cash to have a technician come by) and I still haven't heard back from them after lodging an enquiry.
What I have discovered from this and other forums is that these units do not like being attached to a power source which has a voltage significantly above the amount stipulated in its specifications (for my unit it's 230 Volts). After reading this I used a voltage meter to measure the voltage in one of the power outlets in my house (I have a really cheap meter I'd bought a while ago at an electronics retailer). Sure enough it was above 260 Volts which is totally beyond the range it's supposed to be for where I'm living.
The thing is, I know the unit works just fine provided it has been turned on and it doesn't get the initial FE 30 error (it's almost like you have to get past an initial voltage check and then once it's going everything is ok). If the voltage is at an "acceptable" (whatever that may be) level when it's turned on, it will turn on and then stay on even if the voltage goes up afterwards (which it obviously has done during the time from when it was last switched on until recently).
How did I get it to work this time? well I thought of ways to reduce the voltage to the unit and came across all sorts of stuff on the net including powerbox voltage reducers, optimisers, blah, blah... I thought this is total rubbish and I'm going to ring the power company and complain about the voltage being so high when it's not supposed to be. I then thought back to my old high school physics days and remembered that there's a relationship between voltage, current and resistance. I then thought the voltage to the induction cooktop (as well as to all the other power outlets/circuits in the house) is likely to drop if I plug in and turned on a lot of high resistance electrical appliances.
Sure enough, when I turned on the kettle, toaster, clothes dryer, computers, televisions, electric oil heaters, lights and dishwasher, the voltage in the power outlet I'd been measuring went down from 260 to 235 volts.
I then turned on the power to the induction top back on and it turned on and with no FE 30 error!
I boiled some water to make sure everything was working ok (it was) and then I turned off the induction top and all of the other devices I'd switched on.
Still no FE 30 error! Great.
I double checked the unit by turning it back on and boiling water again and it did it with no problems. I then turned the unit off and measured the voltage in the power outlet again and sure enough it was back at 260 Volts. Hurray!
I'm now going to ring the power company and make a complaint...
Mar 22, 2013 | Cooktops
F11 reading on control panel of electrolux induction range
Go to the Electrolux website on your computer and look up the model of your range. Th owner's manual should give you what you need...download it!
Dec 25, 2012 | Electrolux EW30IF60IS | 30" Induction...
My miele induction schott ceran is being locked, and I can not open it to cook??
Hope this helps.
Regards,
BElectric
Apr 25, 2011 | Miele 30 in. KM443 Electric Cooktop
Induction cook tops
good day,
kitchen appliances
Sep 14, 2008 | Dacor Millennia ETT304 Electric Cooktop
Wolf electric induction stovetop
I had that happen once and it went off after a day. I'd suggest maybe turning off the breaker and wait a few minutes and turn it back on. But here's my problem for you. I got the 30" model in March, 2008. The problem I've had is that the induction units cool down and start cycling when I'm cooking something like bacon, or pork chops etc., ie. where you're trying to brown something or sear. They cycle up and down every couple of minutes, so its really annoying. They work fine if I'm boiling water for pasta or sauces, etc. Have you experienced this. I've been working with the dealer and the company and they say its a "software" problem, but they've haven't taken them off the market. I use All-Clad stainless steel pans so that's not the issue. Thanks for your comments.
Aug 16, 2008 | LG 30" Built-In Electric Induction Cooktop...
Cooktops Logo
46 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
