Maytag washer mavt446aww is making a lot of noise during the spin cycle.What may be the problem?
clusterfx
  • 67 Answers
SOURCE: loud squeal during wash and spin cycles, maytag atlantis washer
Squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
If part of a belt gets torn and it is long enough, it will hit any part of the washing machine within range and make a clicking noise at every revolution of the motor.
I am pretty sure you need new belts. You should be able to remove a few screws and open the back cover. Between the pulleys there is a tensioner...loosen that so you can remove the belt easily. replace it with a new belt and adjust the tension.
hope this helps
Posted on Feb 23, 2008
duby1990
  • 367 Answers
SOURCE: Maytag Washer HAV2558AWW loud noise during spin cycle
Your maytag is really an amana and the bearings are bad. Yes it does cost a lot. If i were you i would buy another washer. Get a whirlpool. (whirlpool now owns maytag)
Posted on Nov 18, 2008
  • 240 Answers
SOURCE: washer sounds like off balance during spin
old duets have nut on rear pulley that becomes loose. remove rear panel and tighten nut. check while spinning by hand if pop is felt. if it rotates smoothly then you may need new shocks on tub
Posted on Mar 14, 2009
  • 219 Answers
SOURCE: Grinding noise during agitation on washing machine
check water pump
Posted on Apr 17, 2009
  • 84 Answers
SOURCE: Grinding sound during agitation cycle on my Maytag Performa
Its probably you stator plate and rotor. But you need special tools for this repair. There a spring that is under 200 pounds of pressure and if you take the screws off that hold the plate its going to fly into you face if your dont use the special tools to depress the spring. Is it more of a clanking kinda of noise? DOes it olnly happen with heavy loads? Try this out. Fill the washer with water only. and get it into a wash cycle with water only. If there is no noise then put in like a load of towels. A heavy load. Now if you hear the noise now then its for sure you stator plate and rotor..hope this helps, but like i said you need those special tools to do this repair or injury can result from the spring part.
Posted on Jul 27, 2009
Maytag Top Load Washer MVWB850YW making loud noise in spin cycle.
If it's a roaring noise, the tub bearing is probably wearing out. Spin the tub a little with your hand, if you hear a little of the roar, that's it.
Nov 26, 2013 | Maytag Bravos Series MVWB850YW 28"...
My maytag washer model #MAVT446AWW, will not spin , all the water drains out but the unit won't spin ,
Similar issue for MAVT446AWW machine. Tech ordered a brake, rotor, belt and thrust bearing. I had a service contract with Lowes and they elected not to fix as too expensive. Gave me a store credit for a new machine.
Feb 08, 2011 | Maytag SAV571EEWW Washer
Make loud noise during spin cycle
Washer may be out of balance, Move closes around in washer and restart
Oct 24, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Washer makes a lot of noise during spinning
we need the brand and the model
but for starters, please check on the links below.
http://forum.appliancepartspros.com/washer-repair/4501-washer-makes-extremely-loud-noise-during-spin.html
http://www.thestuccocompany.com/maintenance/Washing-Machine-noise-during-spin-cycle-169980-.htm
http://www.askmehelpdesk.com/appliances/washing-machine-noise-during-spin-cycle-167960.html
Sep 10, 2009 | Whirlpool Washing Machines
Maytag washer not agitating and not spinning fully
Pr obably a coupling between the motor and gear box, Take motor off and coupling will come out, re place it and it should be fine
Dec 03, 2008 | Maytag MAV4755 Top Load Washer
Nov 16, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Rattling noise during spin cycle
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Nov 12, 2008 | Maytag MAH2400A Front Load Washer
Washing Machines Logo
51 people viewed this question
Top Washing Machines Experts
