Question about Holmes Products /FANS HT38R-U Tower Fan/Remote
Holmes ht38r manual - Holmes Products /FANS HT38R-U Tower Fan/Remote
I need a remote and filter for HCH6150
Here is a link to your heater manual.
Here is also one for Holmes Customer Support.
Sites holmes products Site
Holmes HCH6150 Product Manual
Oct 24, 2015 | Holmes HCH6150-U Triple Ceramic Heater...
How do I get the front cover off the Holmes table fan HAOF90?
Should be three clips that fold over the outer cover pry up clips with a screw driver.
Jul 21, 2014 | Holmes Products Dryers
Holmes HT38R stopped working can we repair it?
were you able to find a solution? i now have the same problem
Nov 06, 2013 | Holmes Products /FANS HT38R-U Tower...
I'm in Europe where the voltage is 220 instead of 110-120. I need a transformer to use the fan but was wondering what wattage is required.
Hi elinorkim...
To find out what wattage transformer to use you must do a little math.
Multiply Amps times Volts = Watts...this is the least amount of watts you want to use, the more the better...higher wattage will make the transformer run cooler and last longer.
Look on the side of your fan for a tag that has this information on it.
Please take time to rate me
Sep 04, 2011 | Holmes Products /FANS HT38R-U Tower...
I need an owners manual for my Holmes fan, serial # HPF-650
Go to the Holmes Group web site and type in your model. Then you can download a PDF copy of the original manual.
Aug 20, 2011 | Holmes Products HPF650-U Stand (Pedestal)...
How do i manually reset the Holmes HCT460 Tower Heater? I do not have a manual.How do i get a manual for this heater?
reset means a malfunction has occured a bad wire etc. most are non resettable if it is resetable find out problem that has occurred before resetting.
Jan 16, 2010 | Holmes Products Holmes HCT460 Home Base...
Electric fan model ht38r...press buttons and lights light up but no fan and no movement.
Hi.
If the fan lights are turning on, but the fan is not spinning, check first that there is no mechanical problem or obstruction, check also starter switch then eventually replace the fan capacitor, that is most common cause for this fault.
See also: Ceiling Fan Capactors.
Jan 13, 2010 | Holmes Products Dryers
Need a manual for Holmes Model HM5601.
I have a manual for the Holmes Model HM5601. If you contact me I can make a copy & mail
it to you.
My email is jadamson7@cogeco.ca
Dave
Dec 10, 2008 | Holmes Products HM5601-UC 1.8 Gallon...
Dryers Logo
67 people viewed this question
Top Holmes Products Dryers Experts
Jay Finke
Jay Finke
James Coghill
ray gallant
Are you a Holmes Products Dryer Expert? Answer questions, earn points and help others
