Question about Xerox DocuMate 152 Pass-Through Scanner
Error message internal invalid state - Xerox DocuMate 152 Pass-Through Scanner
Ti 83 error message invalid dim
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
If that's not it, please reply to this post stating just what you did to generate this error message.
Oct 01, 2010 | Texas Instruments TI-83 Plus Calculator
I have been using windows Vista for about 2 months and I shut the computer one night and now it states the validation code is invalid
If, when you try to activate Windows Vista on a computer that was obtained from an OEM, you experience one one of the following symptoms. Error message 1
Error Code: Invalid Volume License Key
Error message 2
Error Code: 0xC004F059
Description: The Software Licensing Service reported that a license in the computer BIOS is invalid.
You receive the following error message:
Error Code: 0xc004f035
The Software Licensing Service reported that the computer could not be activated with a Volume license product key. Volume licensed systems require upgrading from a qualified operating system. Please contact your system administrator or use a different type of key. Article KB94962 will help you. If the following error code or error message appears when users try to activate Windows Vista The activation key You typed is invalid This TechNet thread may prove to be of help. If you face Volume Activation error codes on Windows Vista-based computers, KB938450 will help you troubleshoot them.If, when you try to activate Windows Vista on a computer that was obtained from an OEM, you experience one one of the following symptoms.
Error message 1
Error message 2
If you face Volume Activation error codes on Windows Vista-based computers..
May 05, 2010 | Microsoft Windows? Vista Home Basic...
I get the message Uncaught exception: DSSMA: invalid state (5):10060 everytime I try to get my messages
Hi, When the BlackBerry smartphone user attempts to access or open the messages folder from the Home screen, the Uncaught Exception: DSSMA Invalid state error message is displayed. To resolve this error, you need to perform a hard reset of the BlackBerry smartphone. If you face the same error even after performing a hard reset of the BlackBerry smartphone, you need to complete the following steps: 1. Back up the BlackBerry smartphone using BlackBerry Desktop Manager. Erase all data and applications from the BlackBerry smartphone. Restore the backup of the BlackBerry smartphone using BlackBerry Desktop Manager. Hope I helped you. Thank you for using ' Fixya ' and have a nice day!!
Nov 18, 2009 | RIM BlackBerry 8800
I get this internal error message and texts are not being sent out? help?
i cant send a picture message. when i send it says invalid
Oct 21, 2009 | LG Vu CU920 Cellular Phone
Web page errors
if you're using IE8 try the compatibility view,
Make sure that the page displays correctly within ie7 or ie6.
Let me have some feedback
Regards
GeWiz.
Jul 21, 2009 | Microsoft Internet Explorer 8
Flashing amber warning light
The problem is that the MICR Toner Wire was placed into the wrong jumper position on the TROY Font Card. By moving it to the other jumper, this should clear your 'Invalid Toner Sense State' Error. If you need further assistance, please feel free to contact me at 800-633-2266 x 218 or vial email to bmcmillen@troygroup.com.
Regards,
Brian
Mar 20, 2009 | Troy MICR 2200T Secure Laser Printer
SQL Invalid cursor number 135 error
The error is being generated because you are trying to order on a value not in your selected fields e.g EFFECTIVE_DATE
You only have TRANSACTION_TYPE in your select statement
Sep 24, 2008 | Gupta Team Developer for PC
Scanner command invalid in current state
I have not used CapturePerfect 3.0. Hope the scanner is just fine. Try count only mode to check if it is okay.
Uninstall Captureperfect. Run chkdsk/scandisk to check if OS is ok. Reinstall Captureperfect again and it should work.
S. Mohan
Jan 31, 2008 | Canon DR-9080C Path-Through Scanner
Xerox DocuMate 152 Pass-Through Scanner Logo
544 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
