Lg ecosave turbodrum what cause door error in washing machine
SOURCE: LG Fuzzy Logic WF-T7030TP Turbodrum Sensor
Error Peurta
Posted on Mar 24, 2008
techbuster
  • 5081 Answers
SOURCE: What does PE mean on my LG washing machine
Check the pressure switch -the system that determines correct water level in the drum. If its giving an incorrect indication to the program timer machine will either overfill, refuse to fill or refuse to spin. Its an air operated diaphragm switch triggered by rising air pressure induced by the entry of water into an airtight vessel attached to the base of the drum. It tells the program timer that the water has reached the correct level, allowing it to proceed to the water heating stage in the cycle.
Power off, drag machine out onto the floor, remove back cover and top cover. The pressure switch is a round item about 3 inches across with several wires and a thin rubber pipe attached. It generally sits just under the top cover. Disconnect the thin rubber pipe from the switch and blow down through it to clear any blockage.
Switch itself may be faulty but its more likely the pressure pipe or the vessel attached to the other end of the pipe is blocked. Some machines have the pressure vessel integrated as part of the filter unit, with a pressure chamber moulded into the top of the filter body. Remove the pressure vessel, put a small nut or screw in it, fill it with water and shake vigorously till any crud or residue is removed. Refit all parts, check that joints and connections are water tight.
Also check the filter itself - generally located behind a panel at the foot of the machine.Some are obvious like little square hatches and some are hidden behind the trim panel at the foot of the machine. Once panel is removed the filter should be visible. Its generally a circular plastic fitting which unscrews in an anticlockwise direction.
Some hotpoint, indesit and ariston filters are located in the big black sump hose (the one that leaves the bottom of the outer drum and connects to the pump). Power off, drag machine out onto the floor, remove back cover or tip machine up at an angle. Locate sump hose, remove the tensioner clip by squeezing the tabs together with a large pair of pliers or vise grips, remove the hose, take out filter and clean. Be prepared for spillage of water. May help if the machine is tilted backwards at an angle.
Posted on Mar 04, 2010
SOURCE: de error on my lg washing machine
LG WFT70A37ECT Top load washing machine, showing DE error... even door is close still showing this error. that is the solution... really appriciate... thanx
Posted on Oct 17, 2010
SOURCE: Our washing machine is LG Turbodrum i sensor.
My Turbo Drum Isensor is Beeping and shows dE..what is wrong and how do i fix it?
Posted on Nov 14, 2010
SOURCE: My Lg 3 Step turbodrum washing machine does not
LG 3Step Turbolite washing machine displays PE Error What does this mean
Posted on Mar 27, 2011
I have a 7kg LG TurboDrum washing machine, The power is on but the machine does not come on, any help pls?
Check to make sure that the door switch is being activated when you close the door. If not the unit will be dead and not turn on the motor, etc.
Aug 28, 2017 | LG Washing Machines
I have a lg top loading machine model no. WF-T851 with a bE fault. What is this and how is it fixed.
There was a similar question that was resolved a few years back, perhaps it may help. Here is the link:
LG 3 turbodrum wf t851 bE error code
Jan 30, 2017 | LG Washing Machines
LG TurboDrum DD 8 kg WT R801 machine with LE error. Usually I can override the spasmodic message by manually setting the wash, rinse and spin cycles, but not today. The motor speed indicator is not
You have an intermittent problem with the machine's motor. Have the stator and rotor sections of the machine checked out by a qualified electrician.
Jan 01, 2015 | LG Washing Machines
LG TURBO DRUM DD WT-R854
my LG Turbodrum DD 8.5 KG WT-R852 have an Error Message (A). What can i do
Oct 25, 2012 | LG Washing Machines
My LG Turbodrum DD will not drain
Get a new machine. LG washing machines are ****. I have the same model and it has broken down and made horrible noises for years. It finally just stopped working. RIP
Feb 11, 2010 | LG Washing Machines
I KEEP GETTING A dE ERROR ON MY LG TURBODRUM WF-8071TTP WASHING MACHINE PLEASE HELP
you will need to replace the door sensor, this error will appear until it has been replaced. it is inside the unit and pretty much hard to get to if your not familiar with workin on it. take it to an LG tech or some one whos familiar with it..........
good luck LG's are very sensitive.
drsn777@hotmail.com for more info.
Dec 15, 2008 | Washing Machines
Washing Machines Logo
127 people viewed this question
Top Washing Machines Experts
