Question about Maytag Neptune FAV6800AW Top Load Washer
Water inlet valve -how do i install it.
Cant figure out how to get into the water inlet valve to install the new one.i cant figure out how to get the top off.maytag neptune tl
  • 625 Answers
On the back of the washer are two spring clips fastened by hex head screws. remove the screws. Under the front of the top in each corner are spring clips. use a putty knife and locate the clips and press towards the back and lift that corner. it should come off. now do the same on the other corner. once the front is free, tilt the top up and pull up. the clips in back will release and you can rotate the top out of the way
Posted on Aug 30, 2007
Water does not come through water filter
You will need to replace the "water inlet valve" on the back of the unit. Here is the part to order.
Apr 06, 2013 | Maytag Refrigerators
Water flows into ice maker when water lever is pushed
Be sure that you have the water inlet valve wired correctly.
Nov 26, 2012 | Refrigerators
Why is my machine flashing a tap sign and stopping?
Hi and welcome to FixYa, I am Kelly.
Turn off the water at the wall connection and remove the water hoses from the inlet water valve. Remove the inlet screens and wash them under slowly running water by rubbing your fingers over them. Reinstall the inlet screens and re-connect the water hoses to the machine. Remove the hoses at the wall connection and make sure the installer has not installed inlet screens on the hoses. If there are inlet screens on the hoses also clean the inlet screens. Then reconnect the hoses.. turn on the water and test for leaks then test the machine.
This should get you going unless you have relly low water pressure in the home.
Thanks for choosing FixYa,
Kelly
May 15, 2011 | Hotpoint WMA74 Front Load Washer
Where is the thermostat located in a 2001 toyota sienna?
Welcome to FIxYa.com
THERMOSTAT REMOVAL
HINT: Removal of the thermostat would have an adverse
effect causing a lowering of cooling efficiency. Do not remove
the thermostat, even if the engine tends to overheat.
1. DRAIN ENGINE COOLANT
2. REMOVE AIR CLEANER CAP WITH AIR CLEANER
HOSE
3. DISCONNECT ECT SW1TCH CONNECTORS
4. DISCONNECT ENGINE VIRE PROTECTOR FROM
WATER INLET AND RH CYLINDER HEAD
Remove the 2 nuts, and disconnect the engine wire
protector from the water inlet and cylinder head.
5. DISCONNECT WATER INLET PIPE FROM WATER
INLET AND LH CYLINDER HEAD
a) Remove the bolt and disconnect the inlet pipe from the
water inlet.
b) Remove the O-ring from the inlet pip e.
6. REMOVE WATER INLET AND THERMOSTAT
a) Remove the 3 nuts, water inlet and thermostat.
b) Remove the gasket from the thermostat.
INSPECTION
INSPECT THERMOSTAT
HINT: The thermostat is numbered with the valve opening
temperature.
a) immerse the thermostat in water and gradually heat the
water.
b) Check the valve opening temperature.
Valve opening temperature: 80 - 84CC (176- 183 deg f)
If the valve opening temperature is not as specified,
replace the thermostat.
c) Check the valve lift.
Valve lift: 10.0 mm (0.394 inch) or more at 95CC (203 deg f)
If the valve lift is not as specified, replace the
thermostatleedavidian_93.jpgleedavidian_92.jpg.
d) Check that the valve is fully closed when the
thermostat is at low temperatures (below 40CC (104CF)).
if not dosed, replace the thermostat.
INSTALLATION
1. PLACE THERMOSTAT IN WATER PUMP
a) Install a new gasket on to the thermostat.
b) Align the thermostat jiggle valve with the upper stud
bolt and insert the thermostat in the water inlet
housing.
HINT: The jiggle valve maybe set within 15 deg of either
side of the prescribed position.
2. INSTALL WATER INLET
Install the water inlet with the 3 nuts.
Torque: 8.0 Nm (80 kgf-cm, 69 inch lbs.)
3. INSTALL WATER INLET PIPE
a) Install a new O-ring to the water inlet pipe.
leedavidian_91.jpgleedavidian_90.jpgleedavidian_89.jpgleedavidian_88.jpgleedavidian_87.jpgleedavidian_86.jpg
Thank you for using FixYa.com
Regards, Lee Davidian
Dec 06, 2010 | 2001 Toyota Sienna
Water pooling in washer in between loads
The problem is caused by a leaking water inlet valve and the only way to solve it is by replacing the water inlet valve assembly. It is an easy "do-it-yourself" fix that only requires a minimum effort.
Water Inlet Valve Replacement Procedure
  1. Remove the three screws at the back of the machine holding the top cover.
  2. Slide the top cover to the back and lift it from the washer.
  3. Put a bucket or pan under the inlet valves.
  4. Remove the fill hoses from the machine and drain the water into the bucket or pan to avoid flooding your floor.
  5. Remove the screws holding the water inlet valve assembly to the back of the machine.
  6. Use a pair of pliers to press the spring clamp holding the inlet hose to the inlet valve assembly and move the spring clamp away.
  7. Install the new water inlet valve assembly and all other parts disassembled in reverse order of the procedure above.
  8. Make sure to clean the fill hose filters, if there's any, before attaching it to the water inlet valve assembly.
Jan 20, 2010 | Kenmore Elite 45986 Front Load Washer
I need to reinstall awater inlet valve on my
Parts & Accessories | Shop & Find Lawn & Garden, Appliance Parts at Sears PartsDirect | SearsPartsDirect.com go here,put your model number in and hopefully this will help you,next time you need help send the model number,good luck,just take off one line at a time and install it into the new valve,the lines are different sizes and the solenoids are colored so it's kind of hard to do this wrong,also there should be instructions with the vavle
Jan 10, 2010 | Kenmore 22.0 cu. ft. Side-By-Side...
Water doesn't fill after 50-60 secs of valve
Float valve is not used in normal cycle, it is a failsafe method. Energy conservation issues dictated less water during washing.
Oct 31, 2009 | GE 24 in. GSD5500G - Multiple Color...
Asko D3530 water inlet fault code, water valve is on, water comes in but after water comes in for a couple of minutes we get a (inlet water fault code) check power at circulating pump no 120v unit will not...
It is common for these valves to "appear" to be ok, meaning they begin to allow water into the unit, but then one of the two coils or plungers inside fail, or are clogged with mineral deposit from the water or other debris.
Change the valve and you should be fine. part #1164471, you can find it at select parts depots or on-line retailers like repairclinic.com etc.
** Hire a pro or make sure to use a good replacement clamp on the fill line to the tub when you replace the valve, as well as some plumbers puddy/tape on the inlet fitting. Those little buggers have alot of water pressure going thru them when they open and I've seen them come off or leak due to insufficient fastening/loose clamps, then your machine goes into "flood mode".**
Asko seems to be repeating their past. On the earlier DW95 series (mid 90's to around 2000ish) they had a dual valve inlet which had a single valve rework issued to repair the faulty dual valves, now it looks like they're doing it again. Go figure.
Hope that helps, let me know.
Good Luck :)
Oct 28, 2009 | Asko 24 in. D3530FI Built-in Dishwasher
Testing IM-6 Water inlet valve
check water valve or icemaker
Apr 06, 2009 | GE Refrigerators
02 camry 4cyl theromostat replacement instructions
DRAIN COOLANT
  1. REMOVE WATER INLET
    1. Remove 2 nuts, and disconnect the water inlet from the cylinder block.
  1. REMOVE THERMOSTAT
    1. INSTALL THERMOSTAT
      1. Install a new gasket to the thermostat.
      2. Install the thermostat with the jiggle valve upward. HINT: The jiggle valve may be set within 10° on either side of the prescribed position.
    1. INSTALL WATER INLET
      1. Install the water inlet with 2 nuts. Torque: 9 Nm (92 kgf-cm, 80 inch lbs.)
    1. ADD COOLANT
    2. INSPECT CHECK ENGINE COOLANT LEAK Follow your rad hose and you will see the thermo housing the thermostat is under that should be upper hose
Mar 27, 2009 | 1991 Toyota Camry
Maytag Neptune FAV6800AW Top Load Washer Logo
51 people viewed this question
Top Maytag Washing Machines Experts
Sheldon Dedek
John Tripp
John Tripp
Donni Steen
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
