Question about Dishwashers
Whirlpool dishwasher gu1500xtls0
Displays 2 mins when pressing cancel but otherwise no cycles work and does nothing else. How do you reset it?
SOURCE: Kenmore Quiet Guard 2 keypad
Sounds like the electronic controls (smart card) are acting up. Try shutting off the power at your fuse box or shut off the circuit breaker for 1 minute them turn the power on again. This fix quite often works on electronic appliances.
Posted on Apr 08, 2007
  • 76 Answers
SOURCE: dishwasher won't start
jamcdani Most likely the problem with your dish washer is bad key pad. It is not repairable and has to be replaced. Whirlpool does not sell it separate and you have to by the whole console assembly. The price range is between $95 and $115 (different colors) and it is not very complicated to replace it. I can help you with the complete step by step instructions and, if you provide the complete model number of your dish washer, I get the part number and the best price for you. Gendos post back...
Posted on Jun 29, 2007
SOURCE: Whirlpool GU2548 green light flashing, nothing working
I have had the same problem with my the same dishwasher. The manual says that "the dishwasher has malfunctioned. Call service to check heater element". I called service and they are saying that replacing the heater element and possibly the electronic panel may be required. Total cost (part + labor) = $350-400!! I am very very upset with Whirlpool right now.
Posted on Oct 09, 2007
SOURCE: Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Posted on Mar 22, 2008
  • 1214 Answers
I suspect for either of these units that the timer control boards are bad.
Posted on Jan 24, 2009
Whirlpool quiet partner iv. Turn breaker off then on. Displays 4H then goes off few mins later. Press the cancel button and then the POTS AND PANS along with NORMAL buttons start flashing back and forth.
this is not from me but i found it and am passing on..
Hi
Thanks for using FixYa. Error code 4h means 4 hour delay start which means that the dishwasher is in delay start mode and has been set to 4 hours. You can either wait for 4 hrs or to start it immediately press the cancel button to cancel the delay start option. After this program the cycle and options and press Start again as the dishwasher will not start the wash until it reaches the delayed hour i.e. till 4hrs. If after 4 hrs still the light blinks and it wont start then you'll have to replace the control panel. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Dec 28, 2017 | Whirlpool Dishwashers
Model #DU1015XTXS2
With the dishwasher door closed and the unit in standby mode or with no cycle selected and all lights off, press - heated-dry, normal, heated-dry, normal buttons in that sequence. Then press cancel..... wait until 2 minute cycle is done. Open and close the door and make sure it is closed. Then run another cycle.
Apr 06, 2014 | Whirlpool Dishwashers
Kitchenaid DW KUDS30FXSS Cycle starts then I hear a solenoid actuate 4 times then unit goes into cancel drain cycle
Here's a link for the repair manual for your dishwasher:
http://www.appliancerepair.net/kitchenaid-dishwasher-repair.html
Concentration should be on Chapter 2 subsection 2-3 "No Fill"
Then go to Chapter 6; subsections 6-2, 6-3, 6-3a, 6-3b, 6-3c, and 6-3h for testing procedures on relays, actuator valves, etc.
Nov 30, 2013 | KitchenAid KUDS30FXSS Builtin Dishwasher
Reset button maytag dishwasher
  • 1 Open and close the dooricon1.png of your Maytag dishwasher.
  • 2 Locate the "Rinse" button on the dishwasher control panel. Press and release the button five times in quickicon1.png succession.
  • 3 Press and release the adjacent "Drain/Off" button on the control panel two times; this will deactivate the dishwasher's demo mode and reset your dishwasher.
  • If you need to restart your dishwasher or forgot some dishes and want to open it during a cycle and restart it
  • 1 Press the "Cancel Drain" button on the display. Allow about 2 minutes for the dishwasher to completely drain.
  • 2 Choose a cycle under "Cycles" on the panel.
  • 3 Select an option or options under "Options" on the panel.
  • 4 Push the "Start Resume" button.
  • Oct 24, 2013 | Dishwashers
    I have a whirlpool gold quiet partner III Black dishwasher. All of a sudden it stopped working. I push the accusense button and start the cycle for washing, it looks like everything is working normally, I...
    Hi
    If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry or High Temp Wash-Heated Dry-High Temp Wash-Heated Dry . Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
    Daniel
    Aug 30, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
    Whirlpool dishwasher won't start
    I have had the same problem with my dishwasher. I.e., the buttons don't respond (no LED) when you press them. Only the "Cancel/Drain" light works and the dishwasher reacts to cancel/drain. I found a diagnostic in the kick panel that has you press; "heated dry, normal, heated dry, normal" within 6 seconds and the washer goes through a diagnostic. All of the tests perform as they should and at the end the washer works again. I don't know why unless doing this resets the circuit board. Does anyone know?
    Jan 04, 2009 | Whirlpool 24 in. DU1100XTPS Built-in...
    Dishwashers Logo
    23 people viewed this question
    Top Dishwashers Experts
