Question about Hunter 20479 The Stratford II Ceiling Fan
Hunter 20479 The Stratford II Ceiling Fan & light
I don't know how to change the remote code, I don't understand the instructions that came with it
johnny5846
  • 379 Answers
SOURCE: ceiling fan remote will not turn on light
common problem , i went to home depot and bought a new remote for my hunter fan , and it worked again , salesman was very knowledgeable and helpful . thanks. explain the problem to him , he can help .
Posted on Dec 30, 2008
SOURCE: Hunter fan/light with remote installed turns on by itself
Many times this is caused by stray frequencies in the neighborhood. And, sometimes changing the frequencies on the remote and receiver reduce the occurrence.
But it sounds like this may not be the case, here. If not, the receiver in the fan is the culprit and should be replaced. No danger, just annoying.
Posted on May 31, 2009
SOURCE: Remote controlled ceiling fan has mind of it's own.
I have the same fan. The fan and the remote have some "jumpers" which allow you to change the codes, useful if someone else nearby has the same fan. You can see the jumpers inside the remote, open the back cover... you'll see "4 3 2 1" on the circuit board. Unfortunately you'll need to dismount the fan to change its jumpers, they need to be the same as the jumpers in your remote (which you can move around pretty easily).
Posted on Jul 03, 2009
SOURCE: Hunter ceiling fan remote 85095-01 stopped working
it also could be one of the the jumpers fell out of the remote
they are located just above the battery. you will need to match the placement of the jumpers with the receiver mounted in the fan.
Posted on Mar 09, 2010
SOURCE: light on my ceiling fan works but the fan does not
Maybe the capacitor on the fan are damaged
Posted on Apr 12, 2010
Trying to remove the Hunter Stratford II 52" ceiling fan. The canopy ring rotates approximately 1/4 turn but does not release.
http://www.hunterfan.com/uploadedfiles/Support/Owner_Manuals/41803.pdf
Page 8 of the model 20761 Hunter ceiling fan shows how to remove the canopy trim ring. Ours had double stick tape holding the brushed nickel to a plastic trim ring. Dropped it, then squeezed the plastic ring.
Sep 19, 2011 | Hunter 20761 52'' The Stratford II Brushed...
HI - our Hunter Strafford fan works fine, however, my wall lights switch does not turn on or off the fan light. Any thoughts?
did it ever work with the wall switch, if the wires are all tight in the wall and light it should work fine but the switch does go out some times you may just need a new switch they coast 2-5 dollars not much if you have a meter you can put the two probs on the two screws and put your meter on conn, this will make a sound if it is working good luck.
Aug 07, 2011 | Hunter 20479 The Stratford II Ceiling Fan
Where do I find the model number on the fan
usually there is a metal plate behind the center dome of the fan with specifications and model details.
regards.
Jul 03, 2011 | Hunter 20479 The Stratford II Ceiling Fan
After installation the whole fan wobbles. it is standard installation
The most important thing about installing a ceiling fan is to use the proper ceiling box, one that is approved and very firmly fastened to the ceiling joists. If this is not done and the fan is only attached to an existing ceiling box, it may end up being out of balance and wobbling, not to mention being very dangerous.
Sep 08, 2010 | Hunter 20479 The Stratford II Ceiling Fan
The fan chain does not pull smoothly ,had to use string
if its an old fan the switch may be worn out an electrician can replace it most places like home depot offer some kinda replacement part for not much money. replace it yourself if you can do it safely remember electricity kill
Mar 30, 2010 | Hunter 20479 The Stratford II Ceiling Fan
I think our house is haunted. Just installed
See my post below: (Sorry, we're in the same boat!) Hunter ceiling fan with remote, have 5, 4 are seriously impaired! Lights dim to half strengh after variable time 10 seconds-30 minutes. And lights or fan turns on randomly (come home & fan on full blast), and one in which the lights won't dim (just blinks when try to dim)! Hunter "kinda" admits there is serious problem with remote but doesn't have a solution. Tells people to try changing to different code/channel on the remote due to possible interference (pain in **** to change code on ceiling base!), was totally ineffective. Then replaced receiver in ceiling base (another total pain) in 3 fans with new ones sent Hunter, still totally useless. Hunter's suggestion, don't use the remote, just use the pull chain. If I had wanted a pull chain fan, I'd have bought a pull chain fan. TOTALLY USELESS! Moral of story: If you want a remote ceiling fan (my friend found out that all their remotes are made by the same company in Taiwan), don't buy Hunter!!!!!
- P.S. I found a "Kinda"- fix for the lights dimming to half strenth. After turning on the lights, wait 1 second, then dim lights slightly, they will then stay on the strength that you dim them to. - P.P.S. When I changed the receiver in the one where the lights won't dim, it "solved" that problem...Now it has the same problem as the others, lights or fan turn on randomly!
Mar 20, 2010 | Hunter 52" Ceiling Fan With Light And...
Fan won't turn on, dont know where switch is
I looked up the owners manual for your fan at the following site: http://www.hunterfan.com/search.aspx?search=20763
Click on the pdf file labeled owner's.This manual indicates there should be a pull chain for turning on and off the fan. Maybe the chain has broken off up inside the fan. You can follow the instructions in this manual to take the fan apart and replace the pull chain.
May 30, 2009 | Hunter 20763 52'' The Stratford II Ceiling...
Hunter 20479 The Stratford II Ceiling Fan Logo
87 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
