Question about D-Link DI-704P Router
No amber light
My DLink DI-704P router seems to work nice yesterday but now it seems to have problem. my internet connection stop and i found out that i cannot ping my router. when i look on my 704 router it was very hot and the WAN amber light was not flashing, also no amber light on port 1,2 when i test port 3,4 the amber light turned on (i used only port 1,2). can any one help me or suggest how to repair my 704p router. thank you very much and god bless...
  • clericwizard Aug 31, 2007
    Thank you. we return the router to the store where we bought the device. Hoping if they can replace it or repair for us.
  1. I THINK IT IS A HARDWARE PROBLEM SO REPLACE THE ROUTER
Posted on Oct 30, 2007
    Brigadier General:
  • 6,966 Answers
Hi, Based on your post/description, it would seem to be a hardware problem. You may want to try and do a hard reset by pressing on the RESET button while the 704 is on, press till all the leds blink. If this doesn't do the trick, you may have to replace the router. Hardware issues of this nature normally is a result of near lightning strike or power surge. Good luck and kind regards.
Posted on Aug 30, 2007
  • 12,061 Answers
I think ya gonna find ya modem has gone "toes up"... It may well be in the power supply section (PSU)... I guess ya could try a "Shotgun" replacement of all the PSU components.. If this don't "Fix" it.. then I am sorry but ya up for a replacement.. which may be the best option in any event?
I powered off my dlink DI 704P and internet modem by turning off switch on surge suppressor (which I have do several times) and just powered back up after 3 days and my dlink will not come back up no...
1. if you have a power adapter connected to this router it may have burn out when restoring power several times in the way you shut down.
2. When visiting the manufacturer website and researching your unit I found that the unit is "discontinued" and there is no other support for it.
3. I suggest that a new router be purchase with update technology to get the most from your internet experience.
I hope this helps. Have a great day!
Aug 23, 2010 | D-Link DI-704P Router
How to set up a dlink di-704p?
That will depends on your ISP, Internet Service Provider, please let usknow more in detail about the kind of Internet Connection you are using, the configuration of the router will purly depend on it.
Mar 15, 2010 | D-Link DI-704P Router
D-Link DI-704P as wireless
Yes, you have to. The router model mentioned is not a wireless router, not unless you have other network device there that transmits wireless connection such as a wireless access point.
Jul 05, 2009 | D-Link DI-704P Router
D-Link DI-808HV Router Problem
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can set-up form scratch.
May 04, 2009 | D-Link DI-808HV Router (280006OB)
DLink connection
  • try updating your D-Link's firmware at:http://support.dlink.com/products/view.asp?productid=DI%2D524
Jun 19, 2008 | D-Link AirPlus DI-524 Wireless Router
Need help in connecting to the internet using Dlink 704p router.....
it doesn't matter whether the other computer is set to static and the other one is set to dynamic as long as both computers are getting/using valid ip addresses.
if i got it right. 1 computer is connected to the LAN port of the router and the other computer is connected to the WAN port. if so, you need to connect both computer to the LAN ports and the WAN port of the router should be connected to the modem that you are using.
if the physical connection is correct, check how you are connecting to the internet through the modem. if you can access the internet from the modem without configuring anything, you just need to power cycle. turn off everything then turn on the modem first, wait for the lights on the modem to turn on properly before turning on the router then turn on the computers.
hope this'll help you but if not, just provide the following:
(1)ISP:
(2)brand/model of the modem:
so i can help you further.
Jun 04, 2008 | D-Link DI-704P Router
Mac Support for DLink 704P Router
The DI 704 P software is not distributed anymore , as D-Link discontinued the product.
Among 704 P only last version (revision D) supported mac, check here to find out your version.
You can still couple the server to mac using this procedure, give it a try.
If it does not work contact D-Link and ask if you can have copy of control software.
May 28, 2008 | D-Link DI-704P Router
Remote Desktop Connection on DI-704P
did you open TCP port 3389 on the router, and assign it to your computer? Remote desktop requires that port.
Mar 29, 2008 | D-Link DI-704P Router
Sympatico & DLink DI-704P
It usually is simple, and hopefully the answer is as well. If you haven?t already done so unplug the modem and the router. Wait for a few seconds and then plug the modem in followed by the router. Reboot your PC and try the Internet again. If it still doesn?t work then I would try doing a hard reset of your router and reconfigure using the setup process outlined by the manufacturer. If that still doesn?t work let us know and we?ll continue ?.
Jan 01, 2007 | D-Link DI-704P Router
D-Link DI-704P Router Logo
127 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
