Question about Maytag Bravos 7.0 Cu. Ft. Electric Dryer
F49 error code dryer
Dryer was on and running when there was a sudden power failure.. Dryer makes clicking sound but does not turn on and error code f49 shows up
Healeyman
  • 1198 Answers
SOURCE: maytag dryer lde 313
Check the belt.
Posted on Apr 28, 2009
  • 4088 Answers
SOURCE: Our Maytag Intellidry PYE4558AYW dryer will not turn on
Check the door interlock switch. If it is defective, the machine will not start. If no help, then there may be trouble in the control panel.
Posted on Jan 02, 2010
wfservices
  • 262 Answers
SOURCE: Dryer is making a loud banging noise.
there are bushings or rollers at the front of the drum that do wear out this will cause the thumping as it turns. A local appliance repair place may be able to source out new guides for you.
Posted on Feb 23, 2010
heatman101
  • 43501 Answers
SOURCE: dryer makes clicking noise when running
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
w56w
Posted on Sep 29, 2010
SOURCE: Maytag Dryer, Model DE210
Dryer just buzzes when i push start
Posted on Nov 01, 2010
I have a Maytag dryer model: MEDE300VW0 that is showing a PF code. I have tried unplugging, pressing the cancel button, etc. as recommended on various internet sites. PF code persists.
i know that the voltage overseas is different form the usa,that's telling you there was a power failure while the dryer was running,check the back of dryer to make sure you have 240 volts going to the dryer,you could have a bad power cord or something to do with power source.
Feb 06, 2018 | Maytag Dryers
Dryer will not turn on. Lights blink and the Code "F-01" shows in the display
depending on your model The F-01 error code indicates a primary control board failure . If the error cleared after unplugging it for a while, then the control board could have received a power surge or glitch through the electrical lines. Completely disconnecting the electrical power and then reconnecting it will sometimes reset the board and it will operate properly. If your dryer continues to operate properly, then resetting the control board may have fixed your problem.
If the dryer motor continues to stop, then you may have a bad control board. A wiring problem or drive motor failure could also prevent the dryer from continuing to run properly. A technician is normally needed to diagnose and repair this type of problem.
If the F-01 returns and will not clear, then you will need to replace the control board in the dryer
Nov 25, 2015 | Dryers
I have a Frigidaire Affinity electric dryer model number FASE7021NW0. It suddenly began giving error code E61. I called frigidaire. they said it was likely a shorted wire and put me in contact with an
I appreciate your post, Doug Anderson! From the information you have provided your Frigidaire dryer is displaying an error code of "E61". "E61" stands for heater relay failure which could be a problem with wiring, heater relay, or main control board. I would recommend performing a reset on your dryer and you can do that by disconnecting the power cord for ten minutes. This should help clear out any potential false error codes. Hope this information is helpful. -Matt
Dec 20, 2014 | Frigidaire Dryers
Kenmore Elite Oasis Electric Dryer - no power (PF code)
Press and hold the "Start" button to restart the dryer cycle if the "PF" (power failure) error code appears. This code often appears when a cycle is interrupted before it completes. You may also check the breaker or household fuse, and ensure the machine has not come unplugged.
Read more: How to Repair Kenmore Elite Oasis Dryer Error Codes ' eHow.com http://www.ehow.com/how_7703883_repair-oasis-dryer-error-codes.html#ixzz1u
May 12, 2012 | Kenmore Elite Oasis 6808 Electric Dryer
We have a kenmore elite oasis dryer.one year old.just bought from some people only had it for two days.it was in the middle of a cycle when it suddenly shut off with the code af appearing where the timer...
An "AF" code means there is a low airflow condition and the clothes may not dry properly. To remedy this, check to make sure the lint screen is cleaned off and that there is no blockage in either the vent duct that runs from the dryer to the wall or the vent hood on the exterior of the house.
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle.
Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 26, 2010 | Kenmore Elite Oasis ST 6807 Dryer
Power Failure without tripping breaker
Sounds like an overheat code tripped due to obstruction in the exhaust. There is also a vent tube on the bottom of the dryer that could be loose.
Jul 27, 2010 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Whirlpool duet dryer error code pf
The error code means that the unit suffered from a power failure.just make sure that all the wiring is good there is nothing loose and the circuit breaker is in good shape you should be able to turn off the dryer unplug it for a few minutes and the plug it back in this should clear the fault code.
Feb 26, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Kenmore Elite HE3 washer won't spin during rinse cycle...
possible door lock failure fdl/error code f-11- maybe f-2 pump,,,
Dec 27, 2008 | Kenmore Elite HE4 Electric Dryer
Hi, I have been using my dryer with no problems today then all of the sudden an hour ago it has a error code PF. I know that it means power failure but how can I correct the problem? Thanks!
if the power did not go out and you have a pf code you may have loose conection to the power cord. reset the dryer (cancel button)
and if it returns check the conector block where the the power cord connects.
Dec 24, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Dryer
Error codes. are any of these lit? PF Power failure "PF" flashes to indicate that a power failure occurred while the dryer was running. Press HOLD TO START to continue the cycle, or press OFF/Pause to clear the display. E1 Thermistor open Replace thermistor if found defective E2 Thermistor shorted Replace thermistor if found defective
Sep 12, 2007 | Kenmore 82836 Gas Dryer
Maytag Bravos 7.0 Cu. Ft. Electric Dryer Logo
54 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
