Question about Kenwood KW85 Air Conditioner
The air conditioner will suddenly stop after being on for maybe an hour or so and says E4. It also makes somewhat of a grinding sound while on and doesn't fill up with water. The air seems to be cool as if the a.c. is on, but doesn't fill up with water. Any ideas of what is wrong? Thanks!
  • Anonymous Sep 03, 2008
    after a couple (1-2) hours of working it will stop and display the E4 error message.
  • 241 Answers
Start the unit and press the remote control at C if the display in the unit displays C, then turn off the unit using the remote control and plug out the ac supply. Plug the unit again and using the remote control turn on the unit. If the E4 still display there is something wrong with your air in sensor or the main board itself. Replacement of this parts needs a qualified technician.
Posted on Dec 30, 2007
SOURCE:
Eurodib Portable AC E4 Error code
Make sure the condenser and evaporator fins are clean, and that there are the condensate drain hole or hose is not clogged. Also, check the blower or fan bearings to make sure they turn freely without grinding or noticeable sideways slop.
Jul 03, 2017 | Heating & Cooling
What's the means of E4
I don't know what model you have, but maybe the error codes are the same for all air conditioners. Check here:
http://acerrorcode.com/york-air-conditioner-error-codes.html
Nov 16, 2014 | Heating & Cooling
LG portable a/c model LP1010SNR and after running for about 15 mins it reads E4
salaams......the unit will stop and display E4, when coil sensor reads temp less or equal to 2 degree centigrade.so deforst it. orrrrr when the coil temperature greater or equal to 8 degree centigrade.its from manual.
Sep 13, 2011 | LG LP0910WNR Air Conditioner
Unit stopped, displayed E4
the unit is not draining properly. unplug it from the current outlet, check behind there should be two places to drain the machine. unplug the two drain plugs in the back and let the water empty out. the e4 error message comes up when the unit is filling up with water.
Sep 04, 2011 | Royal Sovereign Portable Air Conditioner
E4 error on Yamatsu S-24H air conditioner ?
E4Fault indoor coil sensor (open or closed). Replace it.
Dec 14, 2010 | DeLonghi PAC85 Portable Air Conditioner
My domain air 2.65kw portable ac unit - E4
Make sure the filter is clean and the pump is operating.
Mar 08, 2009 | Heating & Cooling
E4 in an innovair a/c
Check the Capacitor.
Jan 12, 2009 | Heating & Cooling
Kenwood KW85 Air Conditioner Logo
527 people viewed this question
Top Kenwood Heating & Cooling Experts
john h
ray gallant
ray gallant
Michael Youngman
Michael Youngman
Are you a Kenwood Heating and Cooling Expert? Answer questions, earn points and help others
