SOURCE: 37" Polaroid LCD TV No signal appears when select channel
I was having same problem, and think I got lucky and found fix.
Try unplugging the TV and waiting 30 seconds, then plug back in.
You will likely get blue screen with "No Signal".
Go to Menu, then scroll down to "Setup". Select "Factory Reset" then hit "Yes."
This did it for me. Wish you all luck.
SOURCE: setting polaroid 32" HDTV to 1080i
Manuals for Polaroid LCD TV's are found on the Polaroid support site at http://www.polaroid.com/service/userGuides.jsp?FOLDER%3C%3Efolder_id=2534374302034967&bmUID=1229787329055&bmLocale=en_US
SOURCE: selecting 1080p
Hd tv only has 720p picture ability
bluray xbox playstation 3 needs a hdmi cable connected to enable 1080p
SOURCE: I have a polaroid hdtv model TLA-d1911c that wont
You may be looking in the wrong place or have the wrong kind of antenna. With the digital conversion, TV channels shifted from the numbers they used before. In my area, the previous Channel 6 is now broadcasting in the UHF band.
It can be harder to adjust the antenna for a digital TV because it is either working well or totally off - no gradually decreasing "snow" as a clue.
It is possible your TV is not equipped to pick up digital TV. There are converters to translate digital TV to analog signals for older TV. They cost between $30 and $70 depending on features.
