Question about SanDisk Sansa m240 MP3 Player
Sansa m240 I want to remove 3 of the songs on here but when I plug into the computer they don't pull up. I don't care if I have ro remove everything just to get them off.
You'll probably have to reformat your Sansa. First switch the hold button on your sansa to lock and then plug into your computer. Pull up My Computer and right click on your MP3 player. One of the options should be Format, left click. The File Systems drop down box likely says FAT32, change this to FAT and then click Start. This will erase everything on your player so save any recordings you may want to keep.
Posted on Sep 11, 2007
Can't see song list in Windows Explorer
Try this to locate you songs.. Good luck, I hope this helps
Hook up your mp3 player to your computer Go to your desktop and double left click on "My Computer" When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there. Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible. If you want to remove files/songs then you would do this: Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release, right click and then click on "Delete" Now you mp3 player should be clear of the files/songs you do not want. Be careful and do not delete files needed to operate your MP3 player. Good Luck, I hope this helps Please rate me, Thank You
Dec 06, 2009 | SanDisk Sansa m240 MP3 Player
How do i delete music from player
Deleting Files,Pictures,etc from MP3 Player
Good Luck,
I hope this helps
Please rate me,
Thank You
Dec 04, 2009 | SanDisk Sansa m240 MP3 Player
Sansa m240 player
I dont know if the mac is the same as windows, but plug it in. Go to my computer. You should see Sansa m240, or F:\, or a personalized name (right click and click rename). Copy the songs you want and paste them in the player. It should pull up a message that says copying. When it's done, you can unplug it and listen to your music
Dec 07, 2008 | SanDisk Sansa m240 MP3 Player
Sansa m240
go under - my computer - and choose the removable drive your player is creating (ex Removable drive E:) and you should find the folder with the songs this way.Of course you have to conect your player to the computer first :-)
Sep 14, 2008 | SanDisk Sansa m240 MP3 Player
Rearrange songs on the SanDisk
Creating Playlists on the Sansa M240
The Sansa M240 is a decent device, but if you are like many, you have not been able to create playlists. The instructions with the player and the maker’s website offer little help. Here a solution that I found on-line with some additional detail. The step by step instructions for even those with little computer savvy.
1. power up your M240 player without connecting to your computer. Scroll thru the menu to the “settings” menu. Select “USB”, deselect “auto detect” then select “MSC”. (I don’t know if this step is critical, but I picked up this suggestion from another site)
2. Power down the MP240 and using the cable supplied with your player, connect to the USB port of your computer. The display will show “MSC” when connected.
3. If you have not already done so, download the songs you want to include on your playlist from your computer to the M240. Any number of media player software packages will allow you to copy or burn your songs to a “portable media device” for this step.
4. After your songs are downloaded, on your computer, go to “My Computer” and open the "Sansa M240" icon. On the explorer task bar, select “view”> “details”. You should see several standard folders and all your songs. (Note I have used this for both .wma and .mp3 formats and have intermixed them in the playlist)
5. On your computer, open a new Notepad document and save it to your desktop.
Name it whatever you like, but it has to have “.m3u” as a file extension when you save it.
For example I named mine…. playlist1.m3u, playlist2.m3u, playlist3.m3u.
6. Next, in this newly saved notepad document, type this exactly on the very first line < #EXTM3U > without the brackets.
7. Now, find your first song in the open M240 folder, place your cursor on it, right click and select "rename". When the song title is highlighted hit control + C or "Copy" the entire title, being careful not to change anything. Now place your cursor immediately after the #EXTM3U text, hit return and paste the title of your first song directly below it with NO line space in between.
8. Repeat the steps to copy the title of your next song from the M240 folder. When copied, place your cursor immediately after the previous song title copied in the step above. Hit return Twice to create a single line space after the song title and paste in the next song title at the beginning of the line. Repeat this process til you have built your playlist.
8. After you’ve entered your last song title, it should look something like this. (Either .mp3 or .wma extensions can be used)
#EXTM3U
First song.mp3
Second song.mp3
Third song.mp3
And so on.mp3
Now, within your notepad playlist document, click File/Save (noting where it was saved) and close the file. Now, find that same original playlist on your computer. Highlight it and copy / paste it onto your M240. I copied mine into a folder called “playlist” on the M240. Then I repeated the process for other playlists, giving each a unique name.
After allowing sufficient time for the file to copy, use the icon in the lower taskbar of your computer to “safely disconnect hardware” to unplug your player. Disconnect the USB cord, power up and your ready to enjoy your playlists.
Jan 28, 2008 | SanDisk Sansa m240 MP3 Player
Playlist
You have to create the playlist on your computer. Here is a tutorial on using Windows Media Player (version 10). http://mp3support.sandisk.com/wmp10/wmp10playlist.wmv Best of Luck.
Sep 10, 2007 | SanDisk Sansa m240 MP3 Player
How do you setup Playlists? - pls help
if you hold down the menue for like 15 secends it will ask to add to favorites you cant put in playlists I dont think. ~Grim
May 11, 2007 | SanDisk Sansa m240 MP3 Player
How do i put a playlist on a sansa m240
#EXTM3U
First song.mp3
Second song.mp3
Third song.mp3
And so on.mp3
Mar 11, 2007 | SanDisk Sansa m240 MP3 Player
Player will not start
Call Sandisk support. This is a problem with a batch of M240's from 2006.
Mar 09, 2007 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
37 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
