Question about Garden
Craftsman lawn tractor model 917 271832
When I operate my tractor, a tiny jet stream of gasoline shooting out of the fuel pump (located right in front of the tractor). I replaced the pump, but still the same.
SOURCE: craftsman lawn mower
I had both my front wheels wobbly - so I cut shims from a tin can - wrapped the axle of the wheels with the shims and then inserted them back into the plastic bushes. It was a snug fit - but helped quite a lot.
Posted on May 27, 2008
  • 49 Answers
SOURCE: mounting snow blade to lawn tractor
It attaches the the front of the tractor. Similar to a plow to a truck. If you don't have the brackets, you will need those, or make your own. You can see a picture of the brackets if you go to sears.com. Click on the PartsDirect link at the top, and enter the blade model number.
Posted on Feb 05, 2009
  • 246 Answers
SOURCE: owners manual for a craftsman model 917255812 lawn tractor
Hello:
>>You can Use the Site Addys at this Site Addy; http://www.yetmans.mb.ca/antiques.html to Search and Locate New/Used Parts or for Manuals for this Unit.
Respectfully
John
Posted on Apr 21, 2009
  • 246 Answers
SOURCE: Replace V belt on mastercraft 38 inch 12 hp lawn tractor
Hello
The Breakdown of the Unit Usually Shows the Belt Routing.
>>To View a Breakdown of this Unit Go to this Site Addy, http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001 and Enter the Model Numbers and Click Search. From this Page you can View Diagrams and Parts Lists for you Equipment Using the "View Sub Components" Section Near the Bottom Left.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
lonewolf1996
  • 142 Answers
SOURCE: How do I replace the Drive Belt on a Craftsman
You need to get underneath the mower.Look in the front on the bottom of the engine.You will see the engine pulley.On the side of the pulley you will see a bracket that keeps the belt from falling off the pulley.It is help on by two bolts.Take the bracket off.Now you will be able to take the belt off.
Reinstall the new belt and replace the bracket.
Posted on Sep 02, 2009
My Craftsman lawn tractor will run for a while and then stop then sometimes after sitting for a while will run again. What should I check? I added fuel additive to gas just incase the fuel was bad.
Drain the fuel tank. Dispose of the gasoline responsibly.
Replace the fuel line between the tank and the carburetor.
Put fresh gas in the tank. See how long it runs.
While you're at it, change the oil and remove any debris from
the cooling fins on the engine. It may be overheating.
If it still doesn't run, you probably failed to replace the fuel line.
Trust me, this is part of good maintenance for these machines.
Sep 24, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman lawn tractor backfiring
clean the jets inside the carb
Aug 06, 2012 | Craftsman Garden
Engine will not turn over
A FUEL PROBLEM. It doesn't over or doesn't keep running when gas is gone. Doesn't turn over, remove spark plug to let fuel out.
Nov 12, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I'am trying to locate the fuel pump on craftsman 19.5 hp lawntractor ( model # 944608450 ).
Hello, 944608450 is bad model #, however, it would be easier to find with the engine model number. Here are a couple of guesses: if it is the single cylinder engine with the fuel tank under the hood it has no fuel pump. Fuel is gravity fed. If it is the V-twin engine the fuel pump is a generally round black plastic mounted on the left side (as you sit on the seat) of the engine. There should be and in & out fuel line and a vacuum tube going to the valve cover. If it is the opposed twin then is is incorporated into the carb at the front of the engine. Hopefully this info will help otherwise, please get back to me with the correct tractor model and the engine model - type numbers. Please vote if this was helpful, thanks, Dean
Apr 15, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
How do you properly drain the fuel tank on craftsman 19.5 hp lawn tractor
The proper way is to remove the tank from the unit. You can also use a vacuum type device to remove all the fuel and water although it is very difficult to remove everything without removing the tank. Make sure you do not use a motorized vacuum device unless it is ul rated for use around gasoline!!!!
Mar 22, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I found Gasoline inside My Craftsman riding mower engine, this is the third time I have to drain it and replace it with new oil, somehow gasoline is flowing inside and I have no idea where it is coming...
There is a fuel shut off solenoid on the bottom of the carb and it is most likely stuck open. The gravity flow of the fuel causes it to force through the carb, through the intake valve, through the cylinder and then into the oil sump.
Oct 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 21 hp mower
check fuel line for colapse near frame rail common problem ? new hose from tank to fuel filter will fix it
Aug 25, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Gasoline comes out when I pulled out the spark plug. Without the spark plug a large jet of gasoline comes out when I crank it. The gasoline in the tank is gone by the next day and comes out the spark plug...
The carb's needle is stuck open remove carberators float bowl and replace the needle and seat for the float or you can spray the needle and float with carb cleaner while working the float up and down this may work if you don't want to replace parts.
Aug 05, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman garden tractor stalls after running for about 20 minute
do you have the right fuel filter? some are for pressure and some are for gravity feed, the pressure type (fuel pump) wont flow the gas correctly. another possibility would be the coil.
Jul 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
