FixYa.com
Tags:
Compaq Motherboard
Where do all the leads go?
posted by niall75 on Aug 30, 2007
I bought a computer which came with none of the front of case leads connected. i have managed to sort out the usb leads due to an earlier post but still have no idea which configuration the audio leads go in and where as well as the power and reset sw's the h.d.d and power leds. can someone please tell me where they go and in which order.
thanks.
Comment by niall75, posted on Aug 31, 2007
I haver been all over the hp site looking for the service manual and cant even find the right product. I have been able to find a pic of the motherboard on page 2 of this link but have still no idea where the leads go. http://h20000.www2.hp.com/bc/docs/suppor...
it's a homebuilt computer with a compaq power pack and motherboard everything else isnt compaq.
Comment by niall75, posted on Sep 01, 2007
it was working when i bought it but it didnt have the front of case leads connected apart from the power sw which i then forgot to write down.i had to disconnect the power sw to sort out the upgrades i put in and now i cant remember where it goes. that was the only lead connected when i bought it apart from the hard drive and disc drive. my mate works for dell and we spent hours trying to sort it out but had no luck. i know where the leads now go but need pin by pin placement as they are all single pins and not in block form. the leads all have their own details on but that dont help much when i dont know exactly where they go.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Feb 08, 2008
FixYa! (100)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Here is tech manual with pin out.
http://members.home.nl/frejon/compaq/Compaq%20Evo%20D500%20P4%20+%20i845%20Tech%20Ref.TPM_329001-001_rev4_us.pdf
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Aug 30, 2007
FixYa! (100)
Benimur
Rank:Guru Guru
Rating: 87%, 2148 votes
This might start you off >
http://www.fixya.com/support/t186324-fro...
If your PC is a Compaq, you may download the service manual which would better illustrate the what and where of the front panel wires.
http://h18000.www1.hp.com/support/files/
Post back should you need additional information.
Good luck and kind regards.
Comment by Benimur, posted on Sep 01, 2007
Hi again,
My compliments on the homebuilding (DIY).
Now I understand the difficulty, a non-Compaq casing (front panel wiring) to a Compaq motherboard.
The front panel wiring I gave in my first post still will hold; however specific motherboard placement is gonna be a bit tricky since Compaq doesn't label pins individually for the front panel connector.
Hang on and bear with me, will get back to you soon as I have opened an old Compaq and figure things out. Might take a day or two. Question pls., were you able to boot it up yet?
Cheers.
Solution #3
posted on Sep 11, 2007
Helpful (85)
Wolfman1970
Rating: 90%, 2 votes
Hi there!
I got given one of these MoBo's and, in a mad fit of generousity, told my daughter that I'd build her a PC for college using it!
I found the MoBo tech reference guide on this page-
http://h20000.www2.hp.com/bizsupport/Tec...
It's near the bottom of the page, with the text "Technical Reference Guide for Compaq Evo D300/D500 Personal Computers and W4000 Workstations Featuring Intel Pentium 4 Processors and the 845 Chipset" on the button!
You will need page 6-11 for the Pin-Out details of the P5 connector.
Hope that helps you out
Wolfie
Solution #4
posted on Feb 01, 2008
Not Rated (0)
Barry_IA
Rating: 0%, 0 votes
Hi Niall75!
Did you ever get a solution to your problem? I think I found a document for you: www.manualshark.org/manualshark/files/28/pdf_27666.pdf
I was looking to find if there was a motherboard connector for the auxiliary chassis fan when I stumbled on your message.
If you print the PDF it comes out super-small -- I enlarged the portion I wanted to fill the screen, did a screen capture (using IrfanView), then printed that.
BTW, the processor board's part number is 252608-001, product ID is 22441101, for a HP/Compaq D500 CMT, among others.
Solution #5
posted on Jan 13, 2008
Not Rated (0)
nawaz49
Rating: 0%, 0 votes
I have Compaq Evo Desktop D500 motheboard, I need user's manual for the board. Please provide if available.
Can you Help with these Motherboards problems?
Motherboards
carte mere adequat ? mon...
j'ai boitier du mdele... Answer This...
Motherboards
My camera is not working,
My LG KU990 camera is not... Answer This...
Repair Service
Find Motherboard Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
