Question about Craftsman YT 4000 42" Briggs Stratton 24 hp Gas Powered Riding Lawn Tract
How to remove gas tank from craftsman YT 4000 ride lawnmower
Sand in gas tank need to remove to clean. How? YT 4000 Craftsman riding lawnmower
chad7houston
  • 62 Answers
SOURCE: replacing the blades on a craftsman dyt 4000
Not a hard job, but you will need a couple of tools. First, you will need a wrench that fits the nut that is holding the blade on. I prefer a closed end wrench, but an open end will do. Second, you will need a blade changing tool. The brand name is called a Blade Hog. It attaches to the deck and holds the blade in place so you can turn the nut. Raise the deck as high as it will go, attach the Blade Hog, and then loosen and remove the nut. Be sure and pay attention to which side is up on the old blade and put the new one on in the same manner.
hope this helps,
c
Posted on Oct 08, 2008
wadembly
  • 489 Answers
SOURCE: riding lawnmower older Craftsman 143406012 12hp searches for rpm/
the needle valve on carb is out of adjustment it should be turned all the way in & out 1-1/2 turns to 2 turns try that & let me know if i can further help ya
Posted on Jun 28, 2009
wadembly
  • 489 Answers
SOURCE: Steering column
take the side pannels off of dash there are a few bolts & the steering column is held in by a long pin if i can further help e-mail me wade at wadembly@aol.com
panilling9
  • 284 Answers
SOURCE: how do u take off the rear wheel of a craftsman
in the center of each back wheel you see a black cap
this needs to be removed first.
Remove by hand or have pliers that wont damage cap while removing
E clip next it is located behind this cap and needle nose pliers will remove it or a flat blade screwdriver.( could be a bolt if so remove with a wrench that fits turn ccw)
Remove e clip and washer and slide wheel off of shaft along with keystock
Be sure to reinstall keystock in each wheel or your tractor will not move when it is in a gear
if your wheel doesnt come off easy spray the shaft liberally with pb blaster or liquid wrench and let it sit for a few minutes
Find a big hammer and a 2x4 with the rear end jacked up and supported hit on the inside of the wheel (with the hammer hitting the 2x4 )while rotating the wheel to different spots hit with some authority and it should start coming off the shaft
if not heat with a torch is next and rehit some more.
clean and grease shafts lightly before reinstalling for next removal
Posted on Jul 09, 2009
  • 512 Answers
SOURCE: Cut grass clippings does not get picked up by riding lawnmower
When using a bagger, you need correct blades on mower or Worn blades will cause the deck not to get the vacuum needed for the bagger to pickup.
Posted on Aug 22, 2009
Www managemyhome com
bad safty switch or shorting pto if pto replace it but i think one of your safty switches is bad
Aug 26, 2014 | Craftsman YT 4000 42" Briggs Stratton 24...
Gas tank
Un hook the gas line,.drain all gas out.Get a rag,stuff it in gas tank.Get a 1/2 inch dowl.About 7 inches long.Stir the rag inside gas tank.Take rag out,put new rag in tank Swish around inside tank.Get as much as you can out of tank.when you get it Quite clean,add /spray Carb cleaner into the tank.And some gas,drain again until its clean.Only enough gas to swish around.You can see inside tank with a mirror.
Jul 24, 2013 | Craftsman YT 4000 42" Briggs Stratton 24...
Motor surges up and down
Check your fuel cap vent. What is repair man finding?
May 21, 2013 | Craftsman Garden
Just got the mower 6 weeks ago gas cap will not stay on if you cut around bushs. I have gotten leaves in tank,need to take tank off to clean it out. It is a YT 4000 42 in. cut 24 hp . thank B.M.Davis Jr.
Only around bushes? If you getting so close that the bushes are forced up against the bushes I recommend trimming this area, or use a push mower if the ground is in good shape for it, however if your not getting very close to the bushes I will need more info
May 20, 2011 | Craftsman YT 4000 42" Briggs Stratton 24...
24 hp Briggs Stratton sears riding mower engine wont start unless you use start fluid cleaned filter have flow to engine
If the mower starts and continues to run after injecting, you may want to make sure the choke is working properly. If the choke plate is not closing all the way, it will make cold starts difficult.
Feb 12, 2011 | Craftsman YT 4000 42" Briggs Stratton 24...
Motor dies
it sounds like your safety switch under seat is faulty check & replace if needed
Jun 25, 2010 | Craftsman YT 4000 42" Briggs Stratton 24...
Craftsman YT 4000 42" Briggs Stratton 24 hp Gas Powered Riding Lawn Tract Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
