Question about Lincoln Welding Tools
Welder circuit board
LOCATE LINCOLN PCB L 6325
Main pcb 880-456-000 need schematic to troubleshoot.
Dana, Sorry no schematic, but I do remember the welders may of had bad circuit boards
Jan 23, 2016 | Welding Tools
I have a 125 lincoln wire feed welder. wire will feed but will not arc to weld
check you ground cable, try to strike and ark on the ground cable, if no ark test the ground circuit if the circuit is ok you will need to have the transformer tested and for that you need some specal tools.
Aug 28, 2011 | Lincoln Welding Tools
Arc does not stop when foot control released
You need to get a diagram of the connector on the pedal, and check the contacts leads that trigger the power on. If the power on contacts are not opening up when you let up on the pedal then the problem is in the pedal, and you will need to open it up to find the problem. If the pedal is opening and closing as it should the problem is most likely in the welders control board. I just went through a similar problem on my Miller TIG, where the pedal wasn't the problem. If you have a bad board in the welder there are places on the internet that rebuild them, for much less than Lincoln would charge for a replacement. Try the two places listed below for circuit boards if you need them.
http://www.yorkelectronics.com/
http://gemelectronics.ieasysite.com/
Dec 18, 2010 | Lincoln K870 Foot Control For Tig Welder
My lincoln welder has auxiliary power, but will not weld
there is a controller board issue at that point it will have to go to a service center do to there are no supplier's for them other that Lincoln go to their sit HERE and find a service center in your area these boards range from $250.00 to $600.00 there is 4 of them in the machine they will have to remove the top and swap the boards till they find the right one have the same welder i have been through this with Lincoln already hope this helps
Aug 23, 2010 | Lincoln Electric Ranger Gxt 250 Amp...
Ranger welder does not generate enough dc current to weld with and only enough current to turn a ac drill very slowly. checked wires seem to be ok.
clean the brush rings with a very fine emery cloth is still then there is a controller board issue at that point it will have to go to a service center do to there are no supplier's for them other that Lincoln go to their sit HERE and find a service center in your area these boards range from $250.00 to $600.00 there is 4 of them in the machine they will have to remove the top and swap the boards till they find the right one have the same welder i have been through this with Lincoln already hope this helps
Aug 09, 2010 | Lincoln Electric Ranger Gxt 250 Amp...
My Lincoln 135 mig welder suddenly doesn't have enough arc to weld. How do I determine the cause?
check the diodes that there not short or open circuit you will need a meter with diode test..
Jun 19, 2009 | Lincoln Welding Tools
Termal overtemp LED light on, welder not working, not overheated
interconnecting ribbon cable between circuit boards was not properly seated in receptacle
Mar 30, 2009 | Lincoln Welding Tools
Welding Tools Logo
75 people viewed this question
Top Lincoln Welding Tools Experts
Steve
Robert Monigold
Robert Monigold
Jim Goldsmith
Jim Goldsmith
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
