Question about Toshiba TZ50V61 50" Rear Projection Television
Red light blinking
Red light power blinking non stop and does not turn on manualy or by remote contorol
3 Suggested Answers
SOURCE: TV on/off light keeps blinking red light/no sound or picture on screen
Here's a solution that I received from an TV expert in another website: "This sounds like a power supply problem. i have seen it several time on your model. i would not keep trying to turn it on it might damage something else in the tv. the reason it is shutting off is because the power supply is putting out too much voltage. a repair cost will range around 300-400. this is a great model and well worth a repair. here is a web site that might help you in finding a repairman.
http://www.nesda.com/locator/state_search.php." <-- $300-$400 is too much! But throwing away a 300lbs TV will cost a lot of $$$ for the towing and dumping too. I haven't decide what to do yet.
Posted on Dec 19, 2007
wyoed1
  • 211 Answers
SOURCE: no picture tp50g50
Sounds as thought you have a dead B+ from the power supply board. Replacement of the board should be a certain fix. The power supply could be fixed with the help of a good service technician. I hope this has helped.
Ed
NC Electronic
Mills, Wyoming
Posted on Feb 18, 2008
Wont turn on red blinking light
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Dec 19, 2013 | NEC PlasmaSync 42MP4 42 in. Television
My tv wont turn on by power button or remote. white light keep blinking.
Dec 14, 2013 | Sharp AQUOS LC-60LE632U 60-inch 1080p LED...
Hitachi l42vco4u
In other-words, the standby/power slight blinks. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Dec 14, 2013 | Televison & Video
Sony Trinitron Model KV20FV10- when I turn it on the Sound comes on BUT no picture and the red light for the Standby Times keeps flashing non-stop.
How many times do this standby light blinks. It is fault indications. You can get an idea about the faulty section inside the TV, by counting these blinks occurs at one time switch ON. These are called blinking codes. For more details about blinking codes to Sony brand TVs, check this link. Pull up older posts there. Surf the site with patience.
Mar 21, 2013 | Televison & Video
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a philips remote control and I need the code to control a pioneer DVD player
Though all remotes are differnet just try this it can be kind of standard. But not all remotes are always compatible
1. On the remote control, press DVD once and Turn DVD player off
2. Press and hold SET until the red light blinks twice, then release SET.
3. Aim the remote control at the TV and press SCAN. The red light will blink twice.
4. Continue aiming the remote control and click on and off at the DVD Player (which may take up to 5 minutes) until it turns off. Immediately press any key except VOL-, SCAN, or SET. If SCAN is pressed again after any key stops Auto Scan, the remote will continue Auto Scan of the next ID from where it stopped. If you have passed by the code that turns off the TV, press VOL- one or more times until the TV turns on again.
5. To lock in the code and exit Auto Scan, press and release SET the red light will blink twice.
1. Or if you have a code. Press Set
2. Wait for blinks
3. Put in code.
4. Test it and if it works click set if not try next one.
Jul 17, 2011 | Philips Televison & Video
Need code 4 one 4 all tv remote contorol 4 Sanyo?
Hello
Three digit universal remote codes for Sanyo are:
004/ 013/ 049/ 108/ 110/ 180/ 209
Four digit universal remote codes for Sanyo are:
0049 0097 0110 0004 0268 0012 0108 0180
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Feb 13, 2011 | Televison & Video
I need to program my one for all remote to my zenith tv
Try the following steps: 1. Turn on the tv. 2. On the remote, press the "tv" button once. 3. Press and hold "set" button until the red light blinks twice. Release "set" 4. Using the remote's keypad, type in the digits 9-9-1. The red light should blink twice. 5. Point the remote at the tv and slowly alternate between pressing the "power" button and the "tv" button. Stop when the tv shuts off. 6. To save this code, press and release the "set" key. The light should blink twice. Your remote should be programed to your tv.
These steps came from the following link. If you have any problems, I suggest consulting the manual on the link:
http://www.hifi-remote.com/manuals/manual.shtml?URC-3021
I hope this helps! Sincerely, Der Strom
Apr 13, 2010 | One For All URC-3021 Remote Control
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
Toshiba TZ50V61 50" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
