Question about Vacuums
Hose replacement kenmore 739
I need new hose for Kenmore 739 vacuum
SOURCE: Replace Kenmore Vacuum Hose
check out this solution http://www.howtomendit.com/answers.php?id=25754
Posted on Feb 03, 2008
SOURCE: Kenmore vacuum manuals
I tried what reddevil6 suggested and was not able to get Sears to produce a manual. I would prefer an online manual but at this point I'm desperate enough to try anything.
Posted on Oct 05, 2008
SOURCE: Assemble Swivel Assembly onto Kenmore Canister vac
Got this post off this web site...I just replaced my swivel and it worked:
http://www.managemyhome.com/mmh/answers/Answers.action#l4q110567
To install a new swivel assembly, you will need 2 small, flat tip screw drivers. Unplug the vacuum. Push the screw drivers in between the hose and the collar where you see the seams in the plastic collar on the end where the hose enters the collar. This will release tabs that hold the collar to the swivel. Pry and pull the collar back over the hose and then pull the small screwdrivers out of the collar. Slide the collar back along the hose. Unplug the wiring connections from the hose. Pull the hose wires up and out of the holder on the swivel assembly. Lift the tabs on the side of the hose and pull it off of the swivel. Push the new swivel onto the hose. Align the hose wires and secure them in the holder. Plug the wires from the swivel into the hose wires (blue to blue, white to white). Secure the swivel wires into the wire holder on the swivel assembly. Push the collar back up the hose and onto the swivel with the plastic seams aligned with the tabs on each side of the hose. Snap the collar securely into place.
Posted on Dec 10, 2008
  • 10 Answers
SOURCE: Need Manual for Kenmore Progressive with Direct Drive vacuum clea
You can check for the manual at:
I would suggest checking the hoses for clogs. Especially the hose right after the carpet brushes. Don't forget to clean off your brush. Hope this helps.
Posted on Jan 14, 2009
  • 298 Answers
SOURCE: Kenmore Progressive Vacuum-Need to replace plug
Splice a new plug, but get a good one. Tough with a scew to hold it together
  • White wire goes on the silver terminal.
  • Black wire goes on the gold terminal.
  • Green (or bare ground) wire goes on the green terminal
More here:http://www.hammerzone.com/archives/elect/accessories/ext_cord/end1/replace.htm
Posted on Mar 26, 2009
No power when I turn it on. Should I insert new exhaust filter?
A new filter will not solve an electrical problem. It could be a plug, wire, switch, PCB, etc. Electrical problems usually require a qualified technician to diagnose and repair.
May 06, 2016 | Kenmore 25512/ 25513 Progressive Canister...
How do i replace vacuum hose
if you need a new hose you will need to get intouch with the manifactors.
Oct 28, 2009 | Kenmore 22085 Bagged Canister Vacuum
We have a Kenmore canister vacuum cleaner and the power in the floor component (rotating brush, etc) is no longer functioning. The vacuum is producing suction, but does not seem to be providing power to...
the problem could be with the power head itself or the hose providing the power. If you can turn the unit on from the handle, then its not the hose and you need to get a new power head..
Aug 14, 2009 | Panasonic Kenmore Canister Vacuum Vacuum
Jan 12, 2009 | Kenmore 31913 Progressive Direct Drive...
Nov 12, 2008 | Kenmore 25512/ 25513 Progressive Canister...
Kenmore canister hose
The part number for the hose is 4370993, you can go to sears.com, put int he part number and order it. You will only get just the hose, you have to take the ends off of the old one and put them on the new hose.
Mar 11, 2008 | Kenmore 22822 Canister Vacuum
Jun 07, 2007 | Kenmore 23313 Whispertone Bagged Canister...
Vacuums Logo
49 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
