LS k1860hl The unit doesn't respond to the remote. I have got a new remote and still the unit won't turn on.
Demonic-2011
  • 467 Answers
SOURCE: I have a soniq b100 disc player, which only
Sorry, no there isn't much you can do at a consumer level with this player, except, if you still have a manufacturer's warranty, taking advantage of it and sending the unit back for warranty repair/replacement (whichever they suggest to you). It is clearly malfunctioning, beyond user control - send it back as a warranty claim (if you still have one on this model). It won't cost you in repairs that way.
Don't put up with a defective product, send it back - get it fixed under warranty free of charge (if applicable), or the unit replaced (again, if under warranty, free).
It won't cost hundreds of dollars and shouldn't take forever to resolve this simple case. Good luck. This is something the manufacturer should worry about; not you.
Posted on May 06, 2011
dunnbiker
  • 8546 Answers
SOURCE: RCA Home Theater RT2906 doesn't respond to Remote
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Have you tried new batteries?
Posted on May 17, 2011
  • 5370 Answers
SOURCE: I have an LG Art
The remote is fine, the batteries are new, the remote is giving signal.The remote is not communicating with the AC.On the split system front panel.There is a sensor in the internal side of the panel.This sensor detects the signal from remote.But if this sensor is weak or got faulty, then unit will work manually but not function as per remotes command.The front panel has to be removed by local ac repair tech and the panel sensor has to be checked.May be that sensor is got dirty or dust got covered on it or its got internally short.That has to be checked and confirmed.---------- But still if you have not tried with new brand battery, then before doing any thing just try with new brand battery and re-confirm that its not battery related issue.-------- --------------- This should help.Thanks.Helpmech.
Posted on May 31, 2011
heatman101
  • 43501 Answers
SOURCE: "ON" button doesn't work; calculator won't
In most cases this cannot be economically repaired... the cost to repair would be more then the calculator is worth...
heatman101
Posted on Jun 19, 2011
SOURCE: My 2003 Saturn Ion remote trunk release won't
Check to make sure the button on the trunk latch is turned from manual unlock...they made that feature so only the key will work to open the trunk that way if someone breaks in the front of your car they can't hit the trunk release and get into the trunk...may be the same thing for your remote. Hope that helps.
Posted on Jun 20, 2011
My airwell aircon won't respond to my remote, my
FROM THE AIRWELL RC-4 REMOTE CONTROL MANUAL
NOTE THE COMMENT ABOUT THE RESET AND THE SIMULTANEOUS SELECTION OF THE + - SET and CLEAR BUTTONS to effect a reset after replacingg batteries
HOW TO INSTALL BATTERIES Remove the lid in the rear part of the remote control unit.
Insert two AAA alkaline batteries of 1,5 V-DC. Make sure the batteries point in the direction marked in the battery compartment.
The batteries last about six months. Depending on how much you use the remote control unit. Remove the batteries if you do not use the remote control unit for more than one month. Press the +, -, SET and CLEAR buttons together after batteries replacement.
(This operation allows you to reset correctly all the programs. The remote control unit is to be set up again).Replace the batteries when the remote control unit lamp fails to light, or when the air conditioner does not receive the remote control unit signals.
The batteries of the remote control contain polluted substances exhausted batteries must be disposed according to the laws in force.
https://www.google.com.au/url?sa=t&rct=j&q=&esrc=s&source=web&cd=6&ved=0ahUKEwi_8IKByO3UAhVDVbwKHQB1B5AQFghUMAU&url=http%3A%2F%2Ftrade.jng.com.au%2Fhome%2Ffile%2F9031&usg=AFQjCNGiMLYsIf_M8G3-H0Ccni6xhE_0Ig&cad=rja
Jan 12, 2013 | Heating & Cooling
Turn on but remote doesn't work
I would try new batteries first. If that doesn't help then replace the remote with a universal unit that you can program to work with your TV.
Nov 13, 2012 | LG 42LC2D 42 in. LCD HDTV
My S107G is fully charged, I turn on and off transmitter on different frequencies, turn the heli on and off according to my instruction manuel, but the lights on the heli are on,the circuit board red led...
I have similar problem with my LS-208 heli.
Helicopter leds are blinking red/green, front white led is on, and tail leds are blinking too.
Remote controller red led is on as should be but helicopter doesn't respond to controller at all.
I followed instructions above with no success.
Anyone has a suggestion?
Regards, Yaron.
Jun 12, 2012 | SYMA Toys industrial New Syma S107 Radio...
My Technika LCD32-229 is just over 12 months old and has suddenly decided not to respond to the remote or on/off control on the TV. If I turn of the power at the mains for 30 seconds or so, it will then...
HERE'S THE ANSWER TO YOUR PROBLEM:
The possible reason why your TV doesn't respond to your remote is probably the battery of your remote. Maybe it has been used up to it's fullest capacity, so try checking it up. In case, it has been used up, try to buy a new one.
The possible reason why your TV doesn't stay on is still your remote control. Maybe you have accidentally set it to "sleep mode." When it is set into sleep mode, it turns on just for a shorter time. It cannot stay on longer.
So, here's what you've got to do. Check your remote. When the remote works already, press the sleep button remote again. I hope it works for you.
Thanks.
Jul 23, 2011 | Televison & Video
The door lock on driver side front doesn't work anymore with the remote, the other doors are working fine on a Lincoln Ls 2004
Try using the Keyless Entry Pad
If that won't open the drivers door,
then you will need a scan tool, to see
if it can comunicate with the DDM -
Drivers Door Module.
That may be a possible problem, if
everything else works
Jun 24, 2011 | 2004 Lincoln LS
MojogiMy GHD1621F2 freeview recorder is frozen on one programme, won't respond to the remote at all (have new batterys) and won't respond to buttons on front. Turning off and on doesn't work...
Hi mojogill,
It sounds like the receiver may be locked up. If the buttons on the front do not work, then try unplugging the receiver for 5 seconds and plug back in then check to see if everything is working fine.
If you need any further assistance with this, feel free to contact me at thomas.faust@dishnetwork.com. Thanks!
Tommy Faust
DISH Network
May 25, 2011 | DISH Network ViP722 DTV Receiver /...
May 16, 2011 | RCA Audio Players & Recorders
I have a soniq b100 disc player, which only responds intermittently after only 6 months since purchase. The player won't turn on, the buttons on the main unit have stopped responding and the remote...
May 06, 2011 | Televison & Video
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
