Model # 043-5443-4 Air conditioner problem
My air conditioner is continually beeping and the temperature is going up and down all by itself. The remote doesn't seem to be working to fix it and I have tried unplugging the air conditioner and plugging it back in. Also, the buttons on the air conditioner itself aren't controlling it either, any suggestions on what to do, I no longer have the manual
SOURCE: How can I get Westpoint air conditioner wireless remote controls?
Dear,
Do you mean thermostat, the wireless controller for air conditioner? we are exporter of this line from China. Should you be interested in our products. Please feel free contact me at leeysea@gmail.com or add my MSN lee_ysea@hotmail.com. Our website is www.yseagroup.com
Thank you!
Lee Lee
Posted on Oct 20, 2008
  • 400 Answers
SOURCE: Kelvinator Split System Air Conditioner not turning on.
On some remotes there is a reset button which is pressed by using the nib of a pen. Or if this does not work you should look under the cover for a manual button, most units have one, and see if the aircon responds. I suspect your remote sensor is faulty, but try the previous suggestions first.
Posted on Mar 05, 2009
oneqtpieiam
SOURCE: Haier Air conditioner problems - e1 message
try turning it off holding buttons each individually in for 3 secs then in an hour plug back in ... the rep from Haier gave me this advice ... just waiting my hour now ... i also hear that the remote works for sure ...
Posted on Aug 11, 2009
SOURCE: I have a Panasonic split
I have a A C Panasonic, I m operate with remote bat not communicate, and than b emergency switch. indoor unit "on" but out door unit doesn't running. what wrong?
Posted on Jun 10, 2010
  • 10 Answers
SOURCE: I have a model AR DL10 remote for a Fujitsu air
After changing the batteries you have to depress the RST button and if the remote has the abcd slide switch ensure it is set to A.
Posted on Jul 15, 2010
Testimonial: "THANKS"
What causes an air conditioner to continually reset itself to 28' after you set it to any other temperature?
Did you press ok after re setting ?, it may be set at 28 by default , if so go into settings a change this.
Nov 13, 2016 | Heating & Cooling
Why does my unit beep and turn on by itself with a 0.5 in the led
Sounds like it is made to react to humidity as well as temperature. Check to see if there is a setting for that, or perhaps it is supposed to come on to protect itself from moisture. Do you notice ice cold air coming out when it does that, or is it just regular ''air''. If just regular ''air'', and if it does also blow _cold_ when working at the temp you set it at, then I am probably right about humidity... which means this is normal.
May 19, 2015 | Frigidaire FAC105P1A Window Air...
WHY DOES MY FRIGIDAIRE AIR CONDITIONER SLEEP BUTTON KEEPS BEEPING?
I appreciate your post, Tamara Brazile!
I see that your sleep button on your Frigidaire air conditioner continues to beep. Do you see any error codes on your air conditioner? Additionally, could you please provide me with your model number? You can locate the serial tag (which lists your model number) on the outside frame of your air conditioner or under the front panel. With that additional information I can further assist you. -Matt
Feb 22, 2015 | Frigidaire Heating & Cooling
We have a portable air conditioner. It keeps
Follow the steps below....
1. Power down the air conditioner using the "power" button on the front
panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air
conditioner in. Continue to hold the power button down as the machine
goes through a brief test sequence (fan & compressor each come on
briefly, etc). There is a "beep" sound at the end of the test sequence,
and the machine will be off. At this point, you can release the power
button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air
conditioner normally for another 720 hours, but only if you followed
the instructions above EXACTLY.
Jun 26, 2010 | Heating & Cooling
Air conditioner is flashing e1
hi..
panel.
button.
thank u
rate me
Jul 18, 2009 | Sharp Heating & Cooling
ARF120
If you have the error code E1 on the LED temperature display. This error code is intended as a reminder for the user to clean the air filter every 720 hours . I have a sharp and I don't know what model you have but you may check the manufacturers web site for a instruction book but on my unit you have to do the following
panel.
button.
after following this procedure to clear the nefarious E1 indication, you should obtain
another 720 hours of cooling bliss
Jul 13, 2008 | Sharp AFR120FX Air Conditioner
AC changes temperature by itself!
If it's not some sort of built in economizing feature, someone else isn't getting up and changing the temperature while you are asleep and the air conditioner fairy is playing tricks, then the control PCB is in need of repair and will have to be repaired through a sears authorized repair center.
I am a bit surprised that it will allow you to set the temperature to a low 70 degrees as this is pushing the limits of an air conditioner. They tend to freeze the coils at around that temperature.
Jun 07, 2008 | Kenmore 75050 Wall/Window Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
