How do you change the filter on the RUUD uakb-024jaz?
Is there a filter of any kind to change out monthly?
farfield
  • 462 Answers
SOURCE: ruud UAKB-018JAZ outside condensing unit will not run
Trace the wires (small cable) going to the out door unit. This is your 24v control circuit. when it enters the outdoor unit it ties to wires routing through the inside of the unit trace these down. For AC units 1 usually goes directly to the "contactor" (the item you push in and the unit runs?) the other wire can also go to the other side of this same item. But I suspect it goes through other tings before it finally gets there.
Some items are the high and low pressure switches and a delay timer.
A red button sticking out where you can reset it is the high pressure switch and if it clicks and lets it come on you may have a dirty outdoor coil or a fan motor outdoor that is not operating all time.
A low pressure switch has no reset normally on AC or HP.
A delay timer will have 2 3 or 4 wires depending on the type of timer. 1 of these wires goes to the contactor (usually) and one of them feed this wire. remove the wire going to the contactor. now 1 at a time take the other timer wires and touch them to the wire just removed. if the times is bad the contactor will click when you touch one of them with the removed wire.
If its a heat pump you will have to make the contactor try to come on around the board. and this you will need some knowledge on which and what feeds your contactor. Here Id suggest a technician. If I had a way to see your setup and wiring I could talk you through this but its too hard to type and would take way too long.
Posted on Jun 27, 2009
jumptrout51
  • 3361 Answers
SOURCE: I am thinking about purchasing a Ruud UANL -024JAZ
All brands have issues at some point. You should be satisfied with RUUD.
Posted on Sep 28, 2009
gear001
  • 59 Answers
SOURCE: RUUD M/N UAND-024JAZ;heat operation issue
Its a wiring problem.
w = white
r = red
y = yellow
g = green
c = brown or blue
check how the furnace is wired, it should match the new thermostat you installed.
www.fastacservice.com
Posted on Oct 18, 2009
  • 415 Answers
SOURCE: need to find a reversing valve for a ruud achiever
The easiest way to achieve this is to determine the manufacturer of the failed valve (Alco, Ranco.....). Next you need to determine the size of the stubs, and third, you need to determine the coil voltage.....it is recommended you replace the coil when you replace a reversing valve. With this information in hand, you should be able to obtain a reversing valve from just about any A/C supply house. :-)
Posted on Apr 04, 2010
SOURCE: Need the amount of tonage for a Ruud unit.
Hello Robin you got a 5 ton unit.
Posted on Jul 22, 2010
WHAT SIZE UNIT IS A model # UAKB-042JAZ SERIAL # 6953F300414316..HOW MANY TONS IS IT...
They are: Height:19in X Length: 40-1/2in X Width: 27-5/8in
You can also check the manual here:
http://www.adamsheatingandcooling.com/ruud/ruud-ac/uakb/UAKB-specs.pdf
It is located on page 6.
Hope this helps!
Remember to give me 4 Thumbs Up
for all the hard work to the Community! :D
~~Dayminner
Jun 04, 2011 | Ruud UAKB048 Air Conditioner
The fan does not spin
If this unit is located outdoors then it is your condensor fan. Can you hear the compressor come on? If not it could be the capacitor is bad,
If compressor comes on but fan does not, it is most likely your fan.
Jun 26, 2010 | Ruud UAKB048 Air Conditioner
w = white
r = red
y = yellow
g = green
c = brown or blue
Oct 18, 2009 | Ruud Heating & Cooling
Heating & Cooling Logo
16 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
