Question about Garden
How oil goes in 25 horsepower kawansaki motor on lesco z two mower with 60 inch deck
SOURCE: Need diagram of deck linkage on Craftsman 42 inch
Go to sears parts direct and punch in your model #
Posted on Mar 27, 2009
SOURCE: mower quits when engaging mower deck of husqvarna yth 2348
Try putting a jumper wire on the wire going from the engine to the seat. Take that plug and put a wire from one side to the other. Be careful not to cut your feet off when engaging deck.
Posted on Mar 31, 2009
  • 148 Answers
SOURCE: need a manual for a LT1000 craftsman 19 1/2 HP 42 inch mower deck
You can download a free copy at www.managemyhome.com or you can go to www.searspartsdirect.com and buy a copy along with look at the diagram that you need.
Posted on Jul 23, 2009
mickey813
  • 472 Answers
SOURCE: Looking for mower deck belt diagram for a Husky
THAT NUMBER IS NOT COMEING UP CAN YOU SEND ME THE NUMBERS FROME UNDER THE SEAT
Posted on Oct 08, 2009
  • 146 Answers
SOURCE: Swisher 60 deck belt breaks after mowing about 15 minutes.
Even though the routing is correct, have you checked that every spindle and idler pulley turns freely? These bearings can freeze up or bind because debris builds up in them. Also, if the bushings on the idler pulleys can wear, causing them to misalign. Keep checking. Also - is the belt snapping clean, or do you see a burnt, worn spot?
Posted on May 28, 2010
Testimonial: "Thank you for your help. The belt is snapping clean. You are correct in your assessment to what the problem might be. We checked all the above and did not correct problem. We put three washers on top of small idler pulley to bring it down and better align routing. Bought heavier belt at auto parts. Believe the bolt head was touching belt where it routed throught to larger idler pulley."
Where can I get parts for my Lesco 60”deck mower?
i would assume directly from lesco
May 12, 2018 | Garden
John deere model FC420
Specifications
Engine HD45
Engine Model Number(Kawasaki FC420V
Horsepower (10.5 kW (14 hp)
Displacement (423 cc (25.8 cu.in.)
Crankcase Capacity w/o oil filter (1.3 L (1.4 qt.)
Crankcase Capacity with oil filter (1.6 L (1.7 qt.)
Spark Plug-Gap (0.64 mm (0.025 in.)
Spark Plug-Torque (20 N·m (15 lb-ft.)
Cylinders (One
Stroke/Cycle (Four
Lubrication (Full-Pressure
Oil Filter (Standard Single Element
Air Cleaner (Dual Stage
Engine HD75
Engine Model Numbe(Kawasaki FC540V
Horsepower (12.7 kW (17 hp)
Displacement (535 cc (32.6 cu.in.)
Crankcase Capacity w/o oil filter (1.6 L (1.7 qt.)
Crankcase Capacity with oil filter (1.9 L (2.0 qt.)
Cylinders (One
Stroke/Cycle (Four
Fuel System
Fuel (See Fuel in the Service Miscellaneous section
Fuel Filter (Single Stage, 60 Micron
Fuel Pump (Vacuum Operated-Diaphragm
Fuel Delivery (Gravity Feed to Fuel Pump)
Fuel Tank Capacity (19 L (5.0 gal.)
Drive Train Mower Deck (36-inch)
Blades (2
Blade Bolt Torque (81 N·m (60 lb-ft.)
Cutting Heights (25-114 mm (1-41/2 in.)
Weight (86.7 Kg (191 lb)
Overall Width (chute up) (927 mm (36.5 in.)
Mower Deck (48-inch)
Blades (3
Blade Bolt Torque (68 N·m (50 lb-ft.)
Cutting Heights (25-127 mm (1-5 in.)
Weight (83.6 Kg (184 lb)
Overall Width (chute up) (1308 mm (51.5 in
ower Deck (54-inch)
Blades (3
Cutting Heights (25-127mm (1-5 in.)
Weight (86.7 Kg (187 lb)
Overall Width (chute up) (1460 mm (57.5 in.)
Recommended Lubricants
Engine Oil (John Deere PLUS-4
Grease (John Deere MOLY HIGH Temperature EP
Transmission Oil (HY-GARD-J20C (TURF-GARD-SAE10W-30 (PLUS-4-SAE10W-30 (TORQ-GARD SUPREME-SAE30
(Specifications and design subject to change without notice.)
Sep 28, 2016 | John Deere Garden
I NEED A PART NUMBER FOR THE MOTOR TO DECK BELT
should be able to give serial & model # to distributor or dealer to get your belt #
Aug 07, 2013 | Swisher T14560 T - 60" Trailmower with 14...
Need diagram for mower belt deck for Craftsman ZTS 7500 42'
need a mowing deck diagram for 2008 42 inch 21 horsepower zero turn
Aug 08, 2012 | Craftsman 21 HP 42 in. Zero Turn Tractor...
I have a 60" Lesco
If it were me I would check the PTO switch with it running and use a dvm or test light to see if switch is working or defective , you could just have a bad wire connector at the switch or at PTO clutch ....look for discoloration or spread terminals, good luck
Aug 01, 2011 | Garden
I have a craftsman mower with the Briggs and Stratton 19.5 horsepower turbo cooled motor in it. What weight of motor oil is required? This does not have a oil filter
Hi and welcome to FixYa, I am Kelly.
Oil for your engine is a standard 30 weight detergent oil. If your in a hot environment the manufacturer recommends 20 - 50 W and if your in a cold environment the recommended oil is 5W-30 or 5W-40. For most US applications a 30 W detergent oil is fine. If you can locate your engine number I can provide you with an engine manual stating the above.
This manual is for the 19.5 Hp Vanguard engine:
http://www.vanguardengines.com/document/index.cfm?doc=277675WST_E_LO.pdf
Thanks for choosing FixYa,
Kelly
Jun 05, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
What type oil and what level should I put in my 6-7yr old Murrary riding garden tractor. Model=?, but 25 HP, 2cyl 52 inch deck.
You didn't specify what engine is on your Murray, but most of them were either Briggs & Stratton or Tecumseh. Both of these engine take SAE HD30 weight motor oil. Appoximately 48 ounces will fill these from a complete drain.
If your Murray has an imported engine (honda or kawasaki) then they would use 10W30 oil.
Aug 30, 2010 | Garden
Started using oil and smoking severely, all at once .
the best compression for a B&S is between 50 psi and 60 psi. if it's below 40 psi there is a problem with the rings or the tappet clearance (not letting the valves close all the way) but if it's smoking i would start with the rings...good luck
Apr 09, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
