Question about Vacuums
Ryobi RPBV2500 My blower only seems to ant to run when the choke lever is at the first position. It did run with the choke completely off but seemed to suffer from what I thought was fuel starvation when it ran for awhile. When I took the fuel cap off it would start up again, making me think it had a fuel lock. I had a garden centre with engineers look at it.They said that they had checked the carb and could find no blockages. Can you please help?
3 Suggested Answers
buffalonyman
  • 1865 Answers
SOURCE: Ryobi blower vac RPBV2500 Is it possible to obtain an extension tube which will enable roof gutters to be cleaned by blowing while the operator is standing on the ground? Thanks for any help, John
I don't know about Ryobi, but I did purchase additional hoses for my Rigid vac for the same purpose
Posted on May 04, 2009
hunter19_46m
  • 7482 Answers
SOURCE: will not start- seems to
Hi peterblesset...
You did not give me any info on what kind of engine that is starving for fuel.
So I will give you my solution to 2 cycle some 4 cycle chainsaw and trimmer engines with fuel problems and igintion problems.
Make sure you are getting spark at the spark plug, to do this:
Remove your spark plug and check to be sure you are getting a bright blue spark at the spark plug.
You do this by grounding the plug on the head of the engine and pulling the crank rope...watching the plug for spark.
If you are getting a nice blue spark then skip A below and go to B.
A...If you do not get a nice blue spark then you may need to replace the electronic module.
Note: If you have to replace the module be sure to measure the position it is in, it is critical to starting.
B...Also take some fine grit sandpaper (not emery) and lightly sand the flywheel where the magnet is located to clean any rust or corrosion from the magnet area.
Then follow the procedure below:
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of chainsaws and weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor or take a pictue for later
reference.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Make sure you are using fresh fuel...and oil mix if your using a two cycle chainsaw or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the mower/trimmer is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Note:
The little spring inside of the carburetor goes under the float arm.
That is where your fuel inlet needle/float valve is located...on the arm at the end.
Normally there is a small indetion in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation.
The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me thumbs up
Posted on Sep 13, 2011
The Rug Doctor stopped spraying.
did you run out of water ???
Sep 30, 2015 | Vacuums
Bissell proheat 7901-9 the brushbar only turns when handle is completely upright. When I lean handle back to move machine, brushbar stops rolling. What could be the problem?
There is a lever in the machine that lifts the brushes when it is stopped. The lever can slip out of position. You have to take it apart to get to the lever.
Jul 08, 2014 | Vacuums
Vacuum won't stay in the upright position
I believe you have a broken handle release pedal. It make look intact, but if you turn it over and look where the lever is fastened to the body, it should protrude out another inch to an inch and a half. If you don't see this, then the plastic "spring" part of the lever has broken off; this is what forces the lever to stay up. the part for the Helix should be # 203-2463 and should be under $10.
Nov 15, 2013 | Bissell Cleanview Helix Vacuum
Dyson DC15 Animal will not run in upright position, only when reclined. Power also does not seem to be all there. Any suggestions?
Hi Ian,
I'm sorry to hear you're having difficulties with your DC15. If the cleaner doesn't seem to be picking up as well as usual, it's likely to be due to a blockage in the machine, or because the filter needs a wash.
The easiest way to locate and remove any blockages is to follow the steps shown in our online support guide:
http://www.dyson.co.uk/support/help.asp?article=815&product=DC15-ANIMAL
In normal use, the filter should be washed at least once every 3-6 months, as shown in the video below. Use cold water without detergent, and allow at least 12 hours for the filter to dry completely before replacing it.
This should resolve your concern about the cleaner's performance - however, if the machine continues to shut off when stood in the upright position, it's probably best if you get in touch with us directly so we can help. You can call us free on 0800 298 0298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Dyson Online Customer Support
Nov 13, 2011 | Dyson DC15 Animal Bagless Upright Cyclonic...
Def no choked probs, as I check and clean filters regularly, but when switched on there seems to be a short whineing sound before returning to normal, and def wont lift fluff etc., just runs over it,...
Hi, this is Jack at Dyson.
You should be able to resolve your problem by following these simple steps: http://www.dyson.co.uk/support/help.asp?article=1492&product=DC24-ALLFLOORS
If you're still experiencing issues, please get in touch with us, free, on 08002980298 (UK), or 1866MYDYSON (US), so we can run though some checks over the phone.
Kind regards,
Jack
Dyson Customer Service
Mar 18, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
How is the V-belt tension adjusted (Hoover Model U6439-900)or how do I know if the tension is correct? There seems to be a lot of "play" in the belt and I'm wondering if that is the reason the brush roll...
The V-Belt is not adjustable. There are two ways the belt has no tension: (1) when the handle is upright, a mechanical lever takes the drive tension off the belt, and (2) the brush roll lever setting you described. The upper handle would have to be in the floor cleaning position to check the belt, not in the storage position.
Oct 07, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
I can't change the belt on my Ultimate G Diamond Edition
You have to take the nozzle off. Then twist the handle to OFF position to catch and stretch the belt, put the nozzle back and then twist the knob to ON.
Instructions with pictures HERE
There is video manual on the front page on goodvac.com too...
Good Luck,
Rocky
Mar 15, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Vacuums Logo
27 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
