Question about Sony Used DAV-TZ140 DVD Home Theater Multi-Region System
I CAN NOT GET MY SONY DAV-TZ140 HOME THEATRE TO WORK ON THE TV MODE
I CANT GET MY HOME THEATRE SYSTEM TO WORK ON THE TV MODE BUT IT WORKS GREAT ON DVDS.
SOURCE: sony dav-hdx576wf home theatre system
Same problem here!
Posted on Aug 16, 2008
SOURCE: C:13:71 error on my DAV IS10 SONY home theatre
I think it is a dvd laser failure My Sony HT gave that error when it couldnt read discs , its most likely a failed laser (DVD player in one of those home theatre in a box)
Posted on Oct 07, 2008
  • 34 Answers
SOURCE: problems with hearing sound from bravia LCD tv through bravia DAV-HDX275 theatre system
The fiber optic port on back on your bravia tv is only for when your using a over the air antenna and watching local atsc channels in your local market. You need to run the fiber optic from your hd cablebox if it has one or your hd sat box if it has one. If you don't have a set top box with the fiberoptic port on it you can use a digital coax cable from the cable or sat box to sound system. The only other way to get sound if you don't have a cable or sat box is to run the red and white rca audio cable from the tv to the sound system and got to the audio setup on tv and turn the tv speakers off and you might have to adjust the audio to fixed instead of variable.
Posted on Nov 06, 2008
  • 4 Answers
SOURCE: sony compact AV SYSTEM DAV-S400
Hi Joey - I had exactly the same problem.
In my case, I followed the advice of others and took the thing apart. On the main amp board there is a large brown capacitor. Mine had come completely loose, so I soldered it back in place with a good amount of solder to make sure the contacts were ok. I also dabbed some solder on the headphone connectors on the same board (just follow the wire from the headphone socket to the board). Well, when I put it back together and tried it again everything worked perfectly, and it has so far remained free from the error. Hope that helps !
Posted on Nov 27, 2008
welcomejee
  • 10594 Answers
SOURCE: why does push power protector keeps flashing in
This is an error massage and comes when home theater got some internal problem specially in amplifier output section that can have defective output IC etc.
It is not user level repair and requires qualified tech for fix.
Thanks.
Posted on Sep 14, 2009
I can't get the tv to have the surround sound work
This effect varies greatly from one set to another, it may only barely perceptible.
Dec 25, 2014 | Sony DAV-TZ140 Home Cinema System Home...
Region code sony dav-tz140
sorry you fix yoy problem i have the same one
Jan 19, 2013 | Sony DAV-TZ140 DVD System
Cant find a english manual for the sony dav-f300 home theatre system
did you find it?
I need the DAV-F300 manual in English or Hebrew. My problem is that I connect the Sony home theatre system to my Philips TV with HDMI cable and the sound doesn't work
thanks
ran
Mar 28, 2011 | Televison & Video
I have connected the HDMI cable from the home theatre system into my TV but when I select to receive the Home theatre System signal (HDMI) on my TV it does not show the SONY Screen (It flashes as if it is...
Change/ reduce HDMI resolution in DAV-DZ810 so your tv can get proper video signal because it seems DAV-DZ810 is set on bit higher picture resolution and tv is unable to present that picture.
Thanks.
Jan 10, 2011 | Sony DAV-DZ810 Theater System
I am usin the components port to connect my Sony home theatre DAV-DX250 to my TV Sony Wega, and it doesn ot work, I just get static. Any idea what the problem is? thanks in advacne
You need to turn On Progressive Scan mode in home theater system to get video output in component video out ports so tv can show its picture.
Progressive Scan mode can be turned On by going into setup menu of home theater, details are available in user manual.
Thanks.
Nov 29, 2010 | Sony DAV-DX250 System
Getting sound to TV from DVD Home Theatre System
lght304su home cinema,how to connect to tv to get sound through
Dec 29, 2009 | Sony DAV-SR2 System
Connection/sound issues!
the best thing to do is if ur lcd has a phono in/out is to connect ur theatre system through phono straight to the tv as then everything that comes up on the tv comes throught the theatre system
Feb 10, 2008 | Sony DAV-IS10 System
Sony Used DAV-TZ140 DVD Home Theater Multi-Region System Logo
23 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
