Question about Garden
Yardman Owners Manual for self propelled lawn mower model 12AV5690501
Motor seems to bog down. I changed the blade. Now when I start there is a cloud of white smoke. I checked the oil. It is at proper level and not dirty.
  • 7 Answers
SOURCE: yardman push mower self propell not working
check to see if it is belt or gear driven
Posted on May 02, 2009
  • 37 Answers
SOURCE: Heavy smoke when you first start the engine
Hi. sounds likes too much oil in engine or if you tilt the mower up&down or side to side.
if you need more help, just write again
Posted on Nov 21, 2008
  • 205 Answers
SOURCE: How do I change the oil in a Sears Craftsman MRS
Tip the mower up on it's side with the dip stick tube on the lower side and dump the oil out. Best to run the mower till its out of gas first.
Posted on Apr 24, 2009
SOURCE: Honda lawn mower, self propelled mechanism not working
check the mechanism first before changing the gearbox its possible that the cable might jump out from the pulley or the cable is worn out or its possible that the gear on the tire is worn out to if not then that would be the time for you to change the gear box it would be hard to change it if you don't have the right tools to work on it if you know how everything work its not that hard to replace it just make sure were everything goes memorize the parts before disassembling cause that would be you guide to reassemble it...goodluck
Posted on Aug 16, 2009
vincob
  • 718 Answers
SOURCE: my craftsman self propelled lawn mower no longer
if it is a belt driven drive check the belt for tension or break. or check the cable that engages the drive wheels.
Posted on Sep 04, 2009
John deere instructions
Your mower doesn't have enough power to handle very thick grass at high speed. You need to go slower across the lawn. That's easy to do if this is a push mower (just don't walk so fast) or if it's a self-propelled model with a speed control. But if it's a single-speed model you'll have to mow the lawn in fits and starts: squeeze the lever to move it forward; release it when you hear it bogging down; wait for the motor to reach full speed; squeeze the lever to move it forward again; repeat. Also, is the grass very high? If so, try setting the cutting height higher on the first pass, then lower it for a second pass. Finally, make sure the blade is sharp.
Aug 06, 2014 | Briggs & Stratton 190cc 875 Series OHV...
Chugging motor, lots of white smoke.
oil has either run into the muffler or the air filter assembly clean out and good to go.
May 22, 2013 | Craftsman 675 Torque 190 cc 21" Push Lawn...
What type of oil do you use for 6.5 hp yardman lawn mower mtd 160cc 21 inch self propelled
The manual will call for 30 weight, but 10w30 works just fine. Be careful to not overfill the crankcase. Your machine will take 16 - 18 oz's when the crankcase is empty.
Tim
Oct 06, 2011 | Mtd Yard - Man 160cc, 21" Self - Propelled...
I have a Toro self propelled walk behind mower model # 20016. The self propelled just stopped working. My owners manual does not mention anything about the self propell. Can you direct me as to what to...
Toro 20016 self propelled walk behind when the wheels are engaged it moves, when the wheels are not engaged, the wheels look up.
What should I do to fix the problem
Apr 19, 2011 | Toro Lawn Boy Self Propelled CARB Walk...
Wheels not working on yard man mower
Seems like a New propel belt will solve the problem.
Apr 07, 2009 | Garden
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
