Question about Singer 2639
What is the correct Bobbin model for Singer 2639?
  • Sue Archer Aug 09, 2013
    Use a size 15 bobbin. I just fixed my friends multitude of problems. I don't know why or how she got a size 66 bobbin for it, but when I switched to the correct bobbin most of the problems stopped.
    P.S. I just looked it up on a Singer sight on the computer 15J. Manual doesn't say what size.
SOURCE: My Singer 2639 Bobbin case
Hi, I used to have the same problem. I pulled the whole bobin casing out, cleaned it oiled it. When I put it back in, I made sure the actual bobin was turing the right direction so the cotton didnt snag and pull casing up.
If you havent already tried this give it a go.Its amazing how much gunk gets in there.
Posted on Sep 03, 2008
clyde2j2
  • 137 Answers
SOURCE: singer simple model 3116 bobbin case
Try www.sewingmachinepartsonline.com
Posted on Mar 02, 2009
Mongo32
  • 111 Answers
SOURCE: Machine will not pick up the bobbin thread.
if your machine's needle threads from front to back, make sure that the flat part of the needle shank points to the rear of the machine. If it threads from left to right, the flat side should face right, etc.
Posted on Jun 11, 2009
SOURCE: buttonholer on Singer 2639 sewing straight ahead
Also make sure that you pulled the buttonholer lever down and pushed it back (it's on the left side of the presser foot) ... the machine won't make the forward and backward motions to form the buttonhole without it.
Posted on Aug 06, 2009
  • 192 Answers
SOURCE: Singer Sewing Machine model 9224. Bobbin thread
If you turn the handwheel, can you see a metal ring rotating around the outer edge of the bobbin case? If not rotating, broken gear or timing belt off.
If that ring is turning, remove the needle plate and bobbin case. As this ring now rotates, you will a finger on the ring that will pass behind the needle from right to left and it should catch the thread from the eye of the needle. If this finger, the "hook" passes above the eye, you have a timing problem.
Let me know.
Posted on Feb 16, 2010
My needle will not pick up bobbin thread on my singer protege model 2639
Try installing a brand new needle.
If it still will not work, most likely the machine has been knocked out of time. Take it for service.
Jan 01, 2017 | Singer Sewing Machines
How do I thread a bobbin on a model #2639?
Consult the owner's manual or search for one on the internet:
Manufacturer + Model + the word "Manual"
or search YouTube videos for bobbin winding instructions.
Dec 24, 2015 | Singer Sewing Machines
Need to adjust feed dog height on a singer protoge #2639
there should be a small set screw under the cover where you feed the bottom bobbin at. if you turn it right, it will tighten, and should raise it.just remember how many times you have turned the screw.
Oct 17, 2013 | Singer 2639
I 've been using this 2639 Singer since 2006. It was working perfect until one day the bobbin case popped up away from the shuttle causing the needle to be blocked from moving. So, I removed the p
First change that needle. It's likely bent. A bent needle won't create a stitch.
Then double check your timing. It sounds like you have it ******** a bit... But that's hard to determine from a description. Before you start the timing process, make sure that your needle bar is in the correct position. (typically the upper timing mark on the needle bar is just below the lower needle bar guide when the needle is at its very lowest point) If necessary loosen the needle bar holder and make a correction. Once the needle bar is positioned correctly... then move on to the shuttle/needle timing.
Nov 03, 2012 | Singer Sewing Machines
How to install bobbin in singer 2639
Go to the singer website for a free manual
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example 2639) & click search
Jul 27, 2012 | Singer 2639
Model 2639 you can hear it working, but the needle does not move at all
Check your bobbin winder mechanism that it is disengaged. Go to singerco.com and go to customer support.
Aug 29, 2010 | Singer 2639
Bobbin problems
Definitely needs retiming, I can attach instructions if you email me. drivewithken@blueyonder.co.uk
Jun 26, 2010 | Singer 2639
The bobbin case keeps sliding and popping out in the middle of sewing something. I'm having to unscrew the bobbin cover plate and put it back in on an average of four times each time I sew.
This is a real bummer! check to be sure you have inserted the bobbin case fully and correctly. Make sure there is no lint hiding behind the bobbin case.
May 31, 2010 | Singer 2639
Jun 08, 2009 | Singer 2639
Buttonholer on Singer 2639 sewing straight ahead
set you machine for "zigzag" then: try your buttonholer again.
Also; the thread tension can be adjusted by a small screw in the side of the bobbin for the bottom loop of the stich or, the tensioner on the side of the machine head for the top loop
May 28, 2009 | Singer 2639
Singer 2639 Logo
67 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
