Question about 3100L 1way Security System
Disarm Remote won't disarm the alarm. What to do?
On 2004 chevy silverado
Take the positive lead off the battery. Touch the battery with the lead on and off for about five to seven times. This should reset the alarm. Reconnect the positive lead and using the remote control for the vehicle alarm arm and disarm the alarm once before operating as normal.
May 17, 2013 | Cars & Trucks
Car alarm goes off 30 seconds after disarm and open a door
Apparently the alarm is set to passive arming and, once you disarm it, it immediately begins the arming process and it is not registering the door being open. I'm going to go out on a limb and say that the alarm door trigger is wired to the dome light and the dome light is turned off; an issue that occurs with GM vehicles that have a dome light override switch. What's the year, make and model of the vehicle?
Sep 02, 2012 | AviStart 4400 2-Way Security / Remote...
I have 2004 chev tahoe w/ a viper remote starter system,but no key fob. I replaced the car battery & now the cars computer won't let it start. How do I reset the computer?
The car's computer wont let it start?
Well, if you changed the battery and the viper alarm is the issue; locate the push button valet/programming switch. Turn the ignition on, press and release the switch. The alarm will disarm and you can start the vehicle.
To put the alarm in valet, turn the ignition on then off, within 10 seconds press and release the valet switch. The LED will illuminate solid to show that the system is in valet.
Aug 20, 2012 | 5900 SST 2-Way Security System / Remote...
My security system won't disarm on my 1999 chevy blazer
Is this an aftermarket alarm? If so, first locate the valet switch. It should be a black push button. Next, turn the ignition on, press and release the valet switch. This should disarm you aftermarket alarm. This is the most common manual disarm procedure for Directed (avital, python, Automate, Viper) and Audiovox (prestige, pursuit, code).
If this is the factory alarm and, you don't have the remote. Unlock the vehicle using your key in the driver's door.
Aug 16, 2012 | Vehicle Parts & Accessories
How can I disarm the Alarm. I bought my 97 Cabrio used (it didn't come with the remote) The Door locks also don't work. I can't drive it because when I turn the key the alarm goes off and it...
If you don't have the remote then its pretty much useless. I have seen at Pep Boys where they sell replacements for the factory/dealer installed alarms. Or just remove the alarm completely and reconnect everything the way it was.
Without knowing what brand alarm it is a person cannot honestly answer how to disarm it as they all work differently.
If you know a brand and model you may be able to find downloadable instruction on the manufactures web site.
Sep 08, 2011 | 1997 Volkswagen Cabrio
When i try to start me 2008 sonata the alarm goes off and the engine will not turn over. what can i do?
Your Sonata is equipped with a "Keyless Entry & Burglar Alarm" system. When the Burglar Alarm is activated, it KILLS the starting system through the used of a relay called the "Burglar Alarm Relay". This mode prevents engine starting with the key.
Solution #1
Disarm the system with the Keyless Remote (key fob) If you don't have this remote (or its battery is dead) replace the battery & try disarming again.
Solution #2
Enter the vehicle & insert the key in the ignition and turn the ignition switch to 'RUN'. Wait 3 to 5 minutes until the alarm stops. You should then be able to start the engine.
Have a qualified/certified Hyundai Service Technician properly diagnose this issue.
Sep 07, 2011 | Hyundai Motor 2004 Sonata
2004 Hyundai Elantra won't start, emergency flashers keep blinking, can't shut off, lights dim, can't jump start, clicking from under dash from relays. What could it be?
The 'Keyless Entry & Burglar Alarm System" is activated. You must 'Disarm' the system using the Keyless Entry Remove (Key Fob) to "Reset" the system. The reason the engine won't start is due to the burglar alarm - it has a "Starter Kill" circuit which is activated when the alarm is activated. The alarm must be DEactivated to DEactivate the 'Starter Kill' circuit.
Another way to start the engine is to get in the car, put the key in the ignition and turn it to 'ON" and wait 3 to 5 minutes until the emergency flashers stop/turn off. Afterward, you should be able to start the engine. NOTE: This does NOT reset the burglar alarm. It will go off again when you enter the vehicle without using the remote/key fob.
Sep 06, 2011 | Hyundai Elantra Cars & Trucks
Lost my remote viper remote starter. Car alarm goes off when open and car won't start. What do i do to disarm the alarm since the car won't start?
Common issue.
Open doorAlarm will be going offLocate the antenna (should be on the windshield)Find the little black push button on the antenna.Turn key to the ON/IGN position (where all lights are on)WITHIN 5 SECONDS push the black button 1 time and release (unless your installer changed the number of pushes it should be 1)Within seconds the alarm will ceaseStart your vehicle.
If any other issues, send me a message.
Aug 25, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Why does the alarm in my car go off when I try to start it with the remote car starter?
If this is the vehicle's factory alarm that is being triggered then your factory alarm must be disarmed prior to the remote starter sequence. The Autopage unit has a factory disarm wire available for this purpose. When the alarm triggers again try turning the key in the driver's door to see if there is a factory disarm wire available in the vehicle or if the factory alarm is RF disarm only. If it is the after market alarm that is being triggered then you made need to decrease the sensitivity.
Nov 23, 2010 | C3RS727LCD 4Channel Alarm with Remote Car...
When use remote starter to start car, factory alarm goes off. How can I use the remote starter without this happening?
It sounds as if your vehicle's factory alarm is not disarming before the remote start sequence. You will have to disarm the factory alarm before start. On most vehicles there is a disarm wire, usually in the door that operates with the key cylinder. To test, probe the wire at the key cylinder while unlocking the door with the key. Some vehicles have the disarm wire in the driver's kick panel, but they operate the same way (with the key cylinder). Other vehicles can be disarmed with pulsing the key sense wire. Some vehicles do not have a factory alarm disarm wire,i.e. some Subaru and GM cars and trucks. They can only be disarmed through data modules. More information on the year/make/model of your vehicle will be needed to accurately solve your problem.
Nov 08, 2010 | Prestige Remote Start
3100L 1way Security System Logo
24 people viewed this question
Top Avital Vehicle Parts & Accessories Experts
D. E. Hev
baire
Billy Mac
Are you an Avital Vehicle Part and Accessory Expert? Answer questions, earn points and help others
