Question about Orbit Watermaster 6 Station Dual Program Sprinkler Timer 57196
I have "pwr off" how do I get to turn it on? the power cord is plugged in and I have set the timer on and it's not working...
Canon pixma mg5220 will not turn on
When you have sparks it toasts the chips even a good teck will ground themselves before opening a peice of equipment like that. I'm sorry to say but I doubt very seriously if either piece of equipment will work. I would also get rid of the surge protecter and have that outlet looked at.
Oct 14, 2015 | Canon PIXMA Office Equipment & Supplies
Tip
If your computer has a black screen and not booting to desktop
Normally if the computer has the black display then follow these steps:
1) disconnect the pwr cord form the back of the computer //
2) disconnect the printer and the internet cord//
3)hold the pwr button for 1 min and then release// this is called "pwr drain" when the pwr cord is disconnected//
4)connect the pwr cord and restart the computer and see if it boots or not.
5)if not then disconnect the pwr cord again and open the side pannel of the computer//
6)on the mother board you will find the RAM (MEMORY CARD) which will be approx 6 inch long", take out the card/s and plug the pwr cord and restart the computer//
7) if you get the beep sound then the mother board is ok and if you do not get the beep sound then the problem could be mother board//
8)if getting the beep sound then fix the RAM CARD properly and restsrt the computer// it shoul boot//
note** during all this process make sure that the pwr cord is pulled out when you put your hand inside the computer or else you can get power shock..
on Jun 10, 2010 | Computers & Internet
Stanly outdoor power center keeps turning off
Try unplugging timer.
Plug timer into different outlet.
Do not plug into extension cord.
1) Copy following link to identify timer:
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
2) Stanley power center, is made by Westinghouse and has robust 1 year limited warranty... but unknown who honors the warranty.
3) There is no reset protocol for this type timer.
4) F setting is permanently OFF.
If you can manage to get the timer to O, then plug yard stake into a cheap wall timer. Then use the cheap timer to replace yard stake timing.
5) Yard timers are made to last a couple seasons, and some do not work at all.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 19, 2012 | Hardware & Accessories
HP Pavilion Dv6000z will not turn on
Florida Bob,
Battery is part of the power/charging circuit. As you have found it needs to be in place; kaput or not.
Believe your problem to be Power MOSFET's.
This will explain why,
http://www.fixya.com/support/t15330613-hp_pavilion_dv8_not_starting_up
(The Mayohardware article)
Now you may know what is wrong, and where to get replacement parts, and how to replace.
This is the HP Support link to the free Service Manual,
Main Support page for the HP Pavilion dv6000z Notebook PC,
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&lc=en&dlc=en&product=3224052
Manuals download page,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lc=en&product=3224052&
In the list you want the blue -
HP Pavilion dv6000 Notebook PC - Maintenance and Service Guide
USE an ESD wrist strap.
Use a multi-compartment container for the various screws you will remove.
Label each compartment for the area the screw/s come out of.
SOME screws look VERY similar to other screws.
Advise DO NOT mix them up.
http://www.ebay.com/itm/65W-CHARGER-AC-ADAPTER-FOR-HP-Pavilion-dv1000-dv2000-dv5000-dv6000-146594-001-/221082152535?pt=Laptop_Adapters_Chargers&hash=item337985ee57
18.5 Volts (DC)
For additional questions please post in a Comment.
Regards,
joecoolvette
Dec 09, 2012 | HP Pavilion dv6000z Notebook
Compaq presario sr2020nx will not turn on
Just check the power suply behind computer case , or check your cable power.
May 24, 2010 | HP Compaq Presario SR2020NX PC Desktop
Cant get my linksys router to work
does your ISP use DHCP or PPPOE and what is the LAN IP address of their MODEM ,,, now IF they use DHCP and Lan ip is anything other than 192.168.1.1 then in back of linksys press reset button in back of linksys and hold it down (with power on to linksys) for 20 seconds then wait for 2 min and turn linksys off (unplug pwr cord) and your modem off for 3 to 5 min. turn your modem on first and wait for your dsl light and wait 2 min then turn pwr on to linksys (plug pwr back in) and wait another 2 min. IF ISP is PPPOE or if their mdm has same lan ip have your ISP bridge mdm if they have dhcp you won't have to do any thing else but pwr cyc as i said above if they use pppoe then have linksys on and type 192.168.1.1 in address bar and type "admin" in for password only (if that don't work use it for both then where it say internet connection type set it for pppoe and type in your email address and password in the username and password field and save and pwr cyc mdm and router again
Oct 25, 2009 | Linksys Wireless-G WRT54G Router
I have a malibu ML121RT timer that just stopped working. Outlet works, new lightbulbs, didn't nick power cords to outdoor lights. What could be the problem?
The PB912M10 timer clock motor is not sold separately. Aug 2010.
If power pack transformer still works: buy cheap plug-in timer, set power pack to override, and plug power pack into cheap timer.
If transformer no longer works, then it is not repairable.
With receipt, power pack might still be under warranty.
Open following link for power pack tips and resources:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Jun 16, 2009 | Intermatic Malibu 121W Power Pack...
No power. Replaced pwr. cord.
Check that the power cord has been properly attached and that no damage has occurred. Also try another outlet on a different circuit.
Jan 29, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Samsung DVD-SH855
Hi Thanks to all. Problem was solved by my son who suggested that I turn the unit off in standby mode. Samsung DVD-SH855 will not record via timer settings when the unit is left with pwr on. Only works if pwr switched off.
Had I known this prior to purchasing I would have purchased a brand that worked with pwr on.
See:
http://www.avforums.com/forums/archive/index.php/t-617483.html
Apr 30, 2008 | Televison & Video
View timer only lights
TV WILL NOT NOT TURN ON RED VIEW TIMER LIGHT FLASHES AND THEN I CAN'T TURN OFF TV
Mar 29, 2008 | Sharp 61RWP4H 61" Rear Projection...
Orbit Watermaster 6 Station Dual Program Sprinkler Timer 57196 Logo
35 people viewed this question
Top Orbit Video Cameras Experts
richie46
Tom Chichester
Tony Parsons
Tony Parsons
Are you an Orbit Video Camera Expert? Answer questions, earn points and help others
