Question about Drills
Error code 288 on a hilti pd 30 item 319550
I possess a HILTI PD 30 and the problem I have is this: how to fix Error 288
  • 152 Answers
SOURCE: hilti te 10 switch problem
You may research your area for a Hilti service center / dealer or order your part directly from
www.hilti.com
or call (866) 445-8827
Good luck
Aduz
Posted on Mar 15, 2009
rowdy45176
  • 2176 Answers
SOURCE: I cant seem to locate a Hilti TE5A battery charger
I would call Hilti direct at 1-800-879-8000 and speak with one of their customer service reps and they should be able to help. If not let me know and I will contact my local sales rep and see what I can do for you.
Posted on May 21, 2009
  • 123 Answers
SOURCE: hilti te-72 hammer failure
Do not put it in hammer mode and try to unscrew the chuck! This will break the housing internally. To remove the chuck you will have to put a chisel in the chuck. Lock that chisel in a big vice. You will then have to put a pipe wrench on the chuck to unscrew it. It is regular threads but there will be loctite on it. Once that is off your will have a spring and two roller bearings to remove before you can slide the bell off. You will then have 8 5MM screws to remove. This will remove the chuck. You will then have a snap ring to remove. After that you can remove the whole cylinder assy. More then likely your connecting rod is broken.
Posted on Oct 09, 2009
  • 123 Answers
SOURCE: Hilti TE 17 Rotary Hammer repair switch fix
If you are talking about the wire going from the switch to the stator it difficult to get to. You have to remove the motor end cap, cooling fan and handle holding the switch. this will get you to the brush holders. These can be brittle so you need to be carefull. Turn the motor over and tap the end of the armature on concrete checking the brush holders every couple of taps to see if they are coming out of the motor housing. after they clear they will just come out. If you havn't done so already remove the wires going to the brush holders. Your stator will simply slide out after your brush holder comes out. This will give you access to the wires to repair.
Hope this helps.
Posted on Oct 29, 2009
Testimonial: "worked well for me"
  • 61 Answers
SOURCE: I have a Hilti TE 905 AVR the service light came
If you have the old type TE905, which is the one with the square type handle at the back, the service light will come on for 2 reasons. Either there is a tight bearing which will increase the amount of current used to work the machine. Or more common the carbon brushes need replacing. To reset the light, simply cure the problem.
If you have the newer type TE905 with the large “D” Type handle at the back. It gets a bit more complicated. The service light will come on for the same reasons as mentioned above, but it will also come on after 200 hours of use. It will continue to work for another 50 hours with the light on, then it will shut down completely. This is to ensure that it gets regular service. Once serviced or repaired, it will require resetting. To do this you with need a Hilti optical interface, a PC, and Hilti ODA Software. This is not available to the general public. If your Hilti is less Than 2 years old, call Hilti. They will pick it up, repair it, and send it back to you in 3 working days FREE OF CHARGE. If it is older than 2 years there will be a charge for the repairs.
I hope this helped you. Please leave feedback
Posted on Dec 13, 2009
Hilti Pd 38 starts with an E 189
us.hilti.com/HiltiTools
Jun 11, 2014 | Hilti Pd32
Hilti pd 42 E112
Hello All
  1. When press ON/OFF button to switch ON and you get E with error code.
  2. Switch OFF again.
  3. Press ON button and start pressing plus button repeatedly until you get battery symbol in left corner, that's it all done.
  4. You may have to repeat step 3 few time to be successful and probably every time you want to use it. Hope it works for you because it works for me.
Jul 29, 2013 | Drills
Hilti pd 30/hilti pd 40
If anyone know I need one too for my pd 32
Jul 02, 2013 | Hilti Drills
GUIDE D UTULUSATION PD30
Tiens, mais c'est en englais
ou bien ici pour la version francisee
Aug 09, 2012 | Hilti 202415 PD 4 Laser Range Meter
The carbon brush gone i need a replacement
Here is a detail part list from Hilti.
Link HERE to open the drawing and part list.
Please bookmark this page for reference.
The item in question is carbon brush.
This is inter-grade inside item 2 (the electric motor).
Hilti has a life time warranty on labor and two year in parts.
This model was introduced around March 2009.
Check the model plate for production date.
Contact you local Hilti rep to send the unit for free repair.
Act now to avoid the labor charge (2 year FREE labor)
In most case you can use the manufacture t oprove the unit is under 2 years old.
A sales order or receipt of this Hilti SFH 18A will help speed up the repair process.
Additional references
Hilti, Inc.
5400 South 122nd East Avenue
Tulsa, OK 74146 Phone: (800) 879-8000 Fax: (800) 879-7000 Espa?ol: (800) 879-5000
Feb 01, 2011 | Hilti SFH 18A CPC Hammer DrillDriver
I need a rebuild kit for a Hilti SN114B staple gun. Any idea where I might get one?
Yea, just called Hilti and they no longer make a kit for it. Hilti said you'd have to go a gasket and o ring shop to purchase similar parts individually. they quit making them in 1996
Feb 03, 2010 | Air Tools & Compressors
How to mesure in feet instead of inches
Hold the POWER button down for a few seconds. Thats how you get into the settings. Cycle through options with the measure button. Use the power button to go to the next option (eg, beep on or off). Press and HOLD the power button to exit this mode.
Sep 16, 2009 | Hilti 202415 PD 4 Laser Range Meter
Hilti PD30 Laser distance meter
shut the unit off by using the power button then turn it back on holding down the power button unitl the menu is displayed allowing you to turn the beep on/off with the + key and change the units with the - key
Oct 14, 2007 | Optics
Drills Logo
219 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
