Question about Microwave Ovens
Nnsn960s Panasonic door has to be slammed
The microwave will not operate unless you slam the door very hardly. Sometimes it takes on the first slam, other times it takes several tries. Is it fixable or should we scrap it?
MicrowaveSvc
  • 9098 Answers
SOURCE: Have to Slam Door to get it to work - Advantium 120
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
This can be caused by slamming the door or by habitually opening the door while it's cooking without hitting the Stop pad first.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Posted on Nov 28, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: GE spacemaker Profile XL1800 vent fan will not shut off
It may be a bad door switch, a loose door switch mount, or a problem on the control panel, such as a sticky relay.
I would suspect a sticky relay first, but the door switches should be checked.
If you need your control panel assembly (smart board) repaired, we do that for $39.95 nationwide.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Posted on Dec 02, 2007
worldvet
  • 859 Answers
SOURCE: nEED TO REPLACE THE WHITE PLASTIC CATCH ON NEXT TO THE CONTROL PANEL AS IT SNAPPED OFF AS MY SON SLAMMED THE DOOR
By the nature of the oven main face plate and the locking latch being attached to the safety system the replacement cost is usually higher than a replacement microwave oven.
In your case replacing the microwave with another one is more sensible. Your oven is an obscure model as it is, I'd suggest a sharp brand.
Regards,
Worldvet
Posted on May 15, 2008
  • 4088 Answers
SOURCE: GE Profile Spacemaker XL JMV1460 Turns On by Itself
Sounds like there is a stray piece of wire or other metal floating around inside the case. Remove the cover and any breakables in the microwave (the power cord is unplugged for this), turn it upside down over a table and shake it, pound the bottom, and shake it some more--likely the offending piece will drop out onto the table. If so, put it back together and whack it to see if that fixed the problem (cord plugged back in). This process can be repeated.
Posted on Jul 17, 2009
  • 8909 Answers
SOURCE: have to slam door to get oven to operate
I would check the door switch settings before the door damages the switches. Removing the cover may be dangerous!
The door catches can be adjusted when the cover is removed and disconnected from any power.
Remove from any power source, remove the cover of the cabinet. Slacken off the clamp mechanism and ease the clamp over the guide to allow the door to open. When the door levers are in place, the door may be easily adjusted by slackening off the screws that clamp the door catch/actuators in place whilst holding the door closed and then tightening the screws. The rear of the door may be adjusted by slackening the lower door hinge screws and adjusting as required.
I hope that helps.
Posted on Mar 30, 2011
Microwave will not operate unless I slam the door shut then program to cook.
of course it is , most likely needs a new door switch .
Oct 21, 2015 | Microwave Ovens
I have to slam the door 5 times to get it to turn on
Have you tried leaving it after GENTLY closing the door once? Many have a timer so that the fan can remove condensation from the inside. If that doesn't work, you need to take it to the nearest Panasonic service centre to have the door microswitch adjusted or replaced. There are no self serviceable options with microwave ovens due to the disastrous damage operating one without the outer case can cause. The use special screws only the tech carry.
At least you have a good make, so worth having it fixed. I used Panasonic ovens in a restaurant setting.
Sep 19, 2015 | Panasonic Genius Prestige Inverter...
Door came off. Can it be repaired?
perhaps someone that welds could fix it . should have done something a year ago
Jun 11, 2015 | Panasonic NN-SD797S Microwave Oven
Intermittent starting. imer will count down and you can hear a clicking. sometimes if you bang the side or slam the door it may operate again. may be a bad switch 11 years old thanks
Nick,
Usual life span of a microwave is 7 to 10 years. Unless you are going to try to attempt a repair yourself, I would recommend getting a new microwave. You will at least then be covered by a new warranty as well.
Jun 03, 2015 | Amana ACM2160A Microwave Oven
Microwave power off, but will flicker when door shuts
Please inspect the plastic latches that should actuate the door switches. Sounds like you may have broken one when slamming the door too hard
Mar 20, 2014 | Samsung SMH9151 Microwave Oven
You must close the door hard or it will not start
The locking mechanism is not closing completely unless you slam the door because the plastic parts don't slide easily after a couple of years. We found that putting a small amount of vegetable oil on the 2 locking hooks in the door will allow the components to slide easily and close properly so the machine will function correctly.
Mar 02, 2014 | Panasonic Microwave Ovens
Our panasonic inverter microwave (3 years old) needs repeated hard slams to shut the door so that the light goes off and the microwave will work. How do we fix this problem as I'm afraid we are going to...
We have a Panasonic Inverter microwave. Door became difficult to close and had to slam it hard while holding themicrowave to keep it from moving. When opening the door did not pop open but did unlatch. I ordered a new door lever from Panasonic. When got part I removed case from microwave and lever was okay. I then removed the perimeter strip on the inside of the door. With a screwdriver I stretched the spring at the bottom that keeps the door latches pulled downward. Spring still worked just not as stiff. Put perimeter piece back on the door and replaced housing (which I didn't need to remove in the first place), and then put a small drop of vegetable oil on the cams where the door latches hit when closing door. Viola, door opens and closed as new. Problem solved. Diagnosis: over time the latch tension spring hardens and gets too stiff. P.S.: I had several similar springs as backup in case I screwed up the original one.
Jan 16, 2011 | Panasonic NN-SN657SMicrowave Oven
Door slammed and no microwave is dead
yep you got it in one, I must have advised about 10 people today about this. when the door is slammed the door protection circuit does not operate correctly and then takes out the mains fuse inside the unit. renove the case and locate the fuse, normally where the cable enters the unit. as long as the fuse is the correct amperage, lenght and diameter you have no problems. do not test the unit with the cover off and be careful as the capacitors can hold a lethal charge
Feb 19, 2009 | LG LMV2053 Microwave Oven
Microwave Ovens Logo
241 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
