Question about Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune Lid Lock Replacement
My Maytag Neptune TL washer is displaying an error of "od". After much research online, including this site, I realized that the lid lock part (#25001048) needs replacement. I ordered the part, not from Maytag but a parts website, and am much disappointed that it did not come with instructions. I have searched and searched online, and cannot find repair instructions. Im sure its just a matter of removing the panel or something, but I dont want to screw it up. Help!
  • 1 more comment
  • ktm1967 Jan 28, 2009
    Same problem. These locks gets corroted by clorox entering the lock on the right side, and it appears fabric softener on the left side. I may have these in reverse, but you get the point. It may be possible to simply epoxy the lock box. Thereby no water, clorox or fabric softener will enter the lock box and corrode the electrical parts. The box is constructed with a top part and a bottom part. I will run a bead of epoxy between the two halves to seal the box. Of course this will prevent future openings of the box. But I am sure this will 99% solve the problem. I don't believe this will over heat the electrical parts.
  • zmousetrap Jan 29, 2009
    My washer has the od on the on the error board The repairman left about 2 hrs ago It did two loads then same problem
  • Anonymous Mar 14, 2014
    i have a maytag bravos washer i want to remove the lid lock and still run the washer
    Habit-Forming:
  • 54 Answers
I have replaced my right lid lock twice and the second one just went bad. The left one does not matter, only the right one tells the washer the lid is locked. I think the bleach cup is the problem, bleach corodes the metal contacts in the lock. Try removing the plug and cleaning the contacts. I am going to bypass this lock I am not buying any more parts for this unit!
People have reported replacing this lock several times in unser two years.
Posted on Nov 06, 2007
  • 725 Answers
To open the top of the Washer ther are two spring clips catches in the front holding the top closed. Use a putty knife to depress the spring catches. Slip the putty knife into the seam between the cabinet and the top. The catch is located on the left and right edge of the lid, about five inches in from each side. Depress the catch and lift the washer top, then depress the second catch. the top will hinge to the back of the washing machine. I think that the maytag neptune Fav series has two of the lid lock. a left and right and two magnets. but you will see them when you get it open .. be sure to unplug the washer before you do any work on it.. good luck and let me know how you do.. krazytech
Posted on Sep 18, 2007
On the washer the od was flashing and in the Maytag book it says to open the lid. This was not the case for mine. I did open the top of washer and then disconect the two set of wires going to the lid closes. Then turn the power on and it will change to OP, Now turn the power off and plug in the lid connecter and it fixed my problem with the od. Mine was stuck in the flashing od mode and this was the only way I could slove the problem.
Posted on Feb 02, 2009
  • Scott Roose Feb 07, 2009
    I had the same problem as scott_roose had. It fixed the problem!
    Thanks,
    Steve Patae
  • Marcos Contreras Aug 02, 2013
    scott_rose thank you very much with this advice solved the problem with my washing machine
SOURCE:
Washer will not start , od code is showing on the panel
You have lost signaling from the Left Hand Lid lock.
The OD code is sent out from the Console main control board when a lid open is not sensed via the signaling from the Left Hand Lid lock for three completed wash cycles.
Google this sticky for help with your issue ""Neptune TL Washer FAV6800AWW"" start at the 5th post down. You will find a link to the service manual and help on troubleshooting your issue.
Sep 03, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Code of od on washer
The Control Board has not see a Washer Lid Open for 3 completed machine cycles.
If you want to DIY this is not the best forum. Google
""Neptune TL Washer FAV6800AWW"" you will find the Service Manual in post 5 of that sticky. I have troubleshooting support in that sticky for the FAV6800A and FAV9800A. I speak to troubleshooting the Left Hand Lid lock issues causing the OD error code as well as OP and FL.
Aug 23, 2011 | Maytag Neptune FAV6800AW Top Load Washer
OD signal goes on w/ neptune washer w/ lid closed. Technician said it needed control latch assembly ($105) and control board($221). Plus labor ($155). Are these easy to get and replace? Is all this...
OD error code is associated with the Left Hand Lid Lock.
If you want to troubleshoot and repair yourself Google this""
That is a repair sticky where I have DIY support for FAV6800A or FAV9800A Maytag TL's.
You do not need a lot of mechanical experience just some guidance if you wan to save your 1$K machine.
Aug 04, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytage Neptune TL gives od error code. Tried unplugging the machine. Tried many things, but nothing is working.
Could be loss of signaling thru the left hand Lid lock;
Google "Sticky Neptune TL Washer FAV6800AWW" for the Service Manual and support for troubleshooting the OD error code.
Mar 09, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My neptune displays the od error but the door will not open. HELP
Google this Neptune TL Washer FAV6800AWW
You will find FAV6800A or FAV8800A help. You have lost signaling thru the Left Hand Lid lock.
At rhe location above tou will find common Service Repair notes for issues with the machine.
If you are going to troubleshoot you need the Service Manual.
Mar 07, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Dryer will not spin
Maybe I can help with the Washer if it's a FA6800A/FAV9800A. Is it one of those and why do you feel you need a lid switch? Are you getting OP,OD,FL error codes to the LED display if the machine model is a FAV6800A.....Rich
Jun 21, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune tl code od
You have lost signaling from the Left Hand Lock. The washer has not see the lid go open thru the signaling with the magnetic reed relay in the Left Hand Lid Lock.
See if this post will help you Left Hand Lid Lock Troubleshooting
The p/n for the Left Hand Lid Lock is 25001048
Some other handy links. The Service Manual for reference. Sears Parts Direct for reference..........Rich
Jun 18, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune top loader model fav6800aww has an error code od
rlbishop720,
See this post Left Hand Lid Lock Troubleshooting . I discuss Left Hand Lid Lock troubleshooting for error codes OD,OP FL, FO all related to Left Hand Lid Lock issues. I also provide a link to purchase a replacement Left Hand Lid Lock if you don’t want to deal with a DIY fix.
Let me know if I can help…..Rich
Mar 27, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
1,081 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
