Question about Watches
Vitra 6676 cistern lid - Watches
How do I remove the back of the Kenneth Cole kc1518 watch to replace the battery?
look close at the entire rim (the back) it should have a indention to pry up lid.
Jun 22, 2013 | Watches
How do i replace the back cover.
basically a press fit but be carefull as there is a small spot on the lid that corresponds to the arm that comes out the side to set the time. i apologize for not having the correct name for that part.
Jan 12, 2011 | Skagen 105LTXN Wrist Watch
We have purchsed a Kenneth Cole watch KC 1639, which arrived without any instructions. How can we obtain a manual?
Are you sure the instructions aren't inside the lid? My instruction book was pretty well hidden inside the lid!
Dec 21, 2010 | Watches
I opened my back of the watch now it is not getting closed.what shall i do?
have a look at the lid. there should be a small notch in it which has to be lined up with the inner watch piece. make sure they are lined up properly. the lid is a press fit so some force will need to be used but carefully
Sep 27, 2010 | Timex Watches
I took out the back cover to replase the cell cant put back lid help watch #355less
You will probably need a watch press to get the back on. Call around at your local jewelers as they will have one if they carry watches.
Aug 20, 2010 | Skagen Watches
Change date on my invicta 6676
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all INVICTA watch manuals.Rate me, please.
Mar 18, 2010 | Invicta Diamond - DIAMOND LADY'S DOME...
I just need to replace the battery, how do I open the back, does it twist off or snap off.
Some are twist or snap off..We get so many that are pressure back cover.Sometimes it can be done with a knife and there is a small hindge where you can snap it off with a knife so easy but the problem will be putting it back on because you have to snap it back on with pressure and it can only be done with a machine.If it is a twist that should be easy,all you do is put both thumbs around the lid and press and twist to the right and it should open.This lid should close tight after you put the battery or the water will get into the watch and damage the watch mechanism.
Nov 30, 2009 | Callaway CY2060 Sport Series Watch
TOOK WATCH COVER OFF TO REPLACE BATTERY ON A ACQUA AND CANNOT GET COVER BACK ON
make sure the battery placement compliments the locking spring or wire allowing the back cover to go on. start by applying pressure to one side of the lid and gradually make your way around the perimeter applying steady pressure as you go. afew snapping sounds let you know progress is being made. good luck!
Sep 04, 2009 | Watches
How to replace the battery in a kenneth cole watch kc3346
I have not figured out how to open the casing lid to replace the battery, but the number for the battery you need should be engraved on the lid. Double check your own lid, but mine says that the battery is an SR621SW. I'm sure there are different brands that would match this number.
Jul 05, 2009 | Kenneth Cole Reaction Blue Marine Dial...
Seiko watch stuck crown
The crown maybe a screwdown type. Try unscrewing (like jar lid)them pulling out the crown.
May 02, 2007 | Seiko SNA553 Alarm Chronograph
Watches Logo
49 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
