Question about Craftsman Tools & Hardware - Others
Belt sander troubleshooting
My brand new 11726 belt sander is not venting the debris to the dust bag, all most of the dust is coming out the front of the sander.
mikeymiddles
  • 58 Answers
SOURCE: belt sander clogged dust collection
What have you been sanding?  Make sure the sander is unplugged. Remove the dust collector bag and use a flexible wire, like a coat hanger, to free the clogged material from the dust tube.  Replace bag and sand away!  Hope this solution works for you.  Michael Mittelsdorf
Posted on Jan 10, 2009
Editor925
  • 285 Answers
SOURCE: belt won't stay on belt sander
Check first that you have retensioned the belt... i.e. when you removed the other belt, you would have had to pull on a spring-loaded lever to remove the belt tension before you added the new one... make sure the tension lever is flipped back in to ensure the new belt is tensioned...
Next, and the likely problem you are having, is belt tracking... There should be an adjustment knob up near the front of the sander near the front roller, either on top of the front part of the sander, or to the side near the front roller... When you turn this knob, it makes the belt track either left or right over the sander's base. This knob will allow your belt to run square and true and not spin off to one side...You need to adjust the tracking using this knob while the belt sander is running and with the new belt tensioned and in place, so turn the sander upside down, and power it on with one hand, then turn the knob with the other hand whichever way is needed to have the belt track square and in the middle of the rollers. Make small adjustments on the tracking knob to begin with. They can be sensitive at times.
That should stop your belt spinning off to one side.
Posted on Mar 18, 2009
  • 384 Answers
SOURCE: Unable to remove dust bag
Get your wife to help you remove bag. Turn and pull.
Posted on Jul 22, 2009
rowdy45176
  • 2176 Answers
SOURCE: Bosch 3 x 21 Belt Sander
Remove the dust bag and unplug sander for now. Everywhere you see an access hole (fan area, dust port, back of sander blow thru the tool to remove lodged dust that clogged the system, Also look for broken belt pieces in the back of sander. Then while running (remove belt) blow again thru all the ports to try and reomve as much contamination as possible. When finished you can feel to see if air coming from dust bag port, it not you still have a clog that might need more work. If I have clarified your request would you please rate this response accordingly and thank you.
Posted on Sep 12, 2009
rowdy45176
  • 2176 Answers
SOURCE: I have a porter cable belt sander that shoots dust
the inside of the tool is full of dust not allowing it to get into the bag. I have had to completely disassemble and clean the track for the dust. You can try blowing thru every port with compressed air and see if that helps.
Posted on Nov 10, 2009
Testimonial: "I am going to try this. The sander does get very dusty with wood shavings"
Makita Belt Sander 9404 - dust collection bag not collecting the dust. Shooting dust out the front. What can be done to remedy this?
the tool needs cleaned thoroughly. there might be a section of a belt that has jammed the passageway. UNPLUG the tool and turn over to see on the backside if the clog is there, if not I would recommend using safety glasses and compressed air to blow thru the channels to dislodge the material. I havae also used a shop vac to help in this.
Jul 27, 2011 | Makita 9404 4'' x 24'' Belt Sander
My Porter Cable 4" Belt
I would check both rollers for debris on them, also check the plate on the bottom for unusual wear, be careful for sharp edges and make sure the front of the plate is not worn excessively. Then I would turn the front roller without the belt on it to make sure not out of round and moving smoothly. Lastly if you are using directional belts make sure installed properly with the arrow pointing to the front of the sander. Let me know if you need more help before voting and I will see what I can do.
Feb 13, 2011 | Porter Cable Cable 363 4" x 24" 1500 SPFM...
Dust blows out a top right vent and covers my face
Look for debris or sawdust buildup in the fan shroud. This is the part that looks like a semi-circle and connects to the dust bag. Also check the main housing of the unit.
Sawdust builds up over time and moisture and humidity turns it into something like a really loose stucco, you won't have any difficulty in cleaning it out just a rag will work. In the future you can throw some desiccant packs in the case or the drawer where it is stored and it will increase the time between needed cleanings.
Desiccant packs are those little packs you find in new product packaging that says 'Do not eat' all over it'. It just helps absorb excess moisture. I have a little box in my shop where i save these things when i buy something new. I toss a couple in pretty much every drawer of my toolbox and it's helped keep all of my tools in god shape.
Feb 24, 2010 | Bosch 1276D 4" x 24" Belt Sander with Dust...
After installing new belt, on Porter Belt Sander 352VS #6 the belt drifts of to one side until it comes completely off. How do I stop this?
There is a tracking adjustment knob on the side of the sander--adjust one way or the other until it tracks properly. This is something that will change by itself as the sander is being used--check periodically.
Feb 13, 2010 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
I have a porter cable belt sander that shoots dust out the front. It has a dust bag but the wood dust doesn't go in the bag. it used to. I have taped up some weak parts of the bag but I am not sure what...
Nov 09, 2009 | Porter Cable 3" x 21" Electronic Variable...
Sep 10, 2009 | Bosch 1274DVS 3" x 21" Belt Sander
Jul 22, 2009 | Makita 9924DB Electric Sanders & Polishers
Smells like wires buning
Motor may just need new brushes, Cooling vents may be clogged with dust. or bearings in the motor or front roller maybe bad. Causing excessive drag
blow it all out with compressed air or shopvac
look for external brush caps (2) oppsite from each other take them out to be sure they slide freely, sometimes one gets hug up and doesn't make good contact
Mar 12, 2009 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
Porter Cable belt sander
try to rig the nozzle of a shop vac to the part where the bag would normally connect and run the sander simultaneously with vac for a few minutes and see if that helps
Jan 11, 2009 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
Belt sander clogged dust collection
Jan 10, 2009 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
Tools & Hardware - Others Logo
23 people viewed this question
Top Craftsman Tools & Hardware - Others Experts
Dusty Ryan
Level 1 Expert
Mike
John Trevino
Are you a Craftsman Tool and Hardware - Other Expert? Answer questions, earn points and help others
