Question about Traxis DBS-2500 DTV Receiver
What kind of lnb goes with TRAXIS DBS 2500 - Traxis DBS-2500 DTV Receiver
4 Suggested Answers
SOURCE: Traxis DBS-1500 Remote code
There are no codes for that particular remote. Galaxy-Marketing.com should have some in stock in about a week or so. This is the only stock that will be available in the USA so you may want to call them up and plae a few on back order.
Posted on Oct 29, 2008
  • 56 Answers
SOURCE: Need to download the owners manuel please!
http://www.traxisinternational.com/manuals/DBS-2550-2500-1500-om.pdf
theres a link for the owners manual
Posted on Apr 07, 2009
Ironfist109
  • 3018 Answers
SOURCE: got a dbs traxis from
  • To reset the password you need to first restore this unit to factory defaults. Then you can use the default code "0000" or have the old code and change it to a different code entering the old code first.
  • To restore to factory defaults follow these steps -
  1. Use the ^ v arrows to select "erase all channels" or "factory default."
  2. Now press the OK button.
  3. There will be a warning display then just press "OK" again.
  4. The receiver is now restored to factory defaults.
Regards, Tony
Posted on Jun 14, 2011
HUMAX PVR9300T moved it to another TV, WHEN I TURN IT ON IT GOES FOR A MINUTE OR SO AND THEN GOES OFF AND STARTS TO RELOAD. iT DOES THIS CONTINUOUSLY
It's just searching for signal make sure that all the lnb inputs are securely fastened as you could have pulled it a bit just check on the pvr lnb in
Apr 05, 2017 | Humax Televison & Video
Got a dbs traxis from sister and need to reset password
Regards, Tony
Jun 14, 2011 | Traxis DBS-1500
I have an exisitng sat that works fine. I bought a 2nd receiver,a dual lnb and a multi switch.Where exactly is the dual lnb installed?
The Dual LNB goes at the Antenna, it "Replaces" the existing one. It Must be aligned EXACTLY right, NOTE the "OLD" ones Placement. the "Switch" wich is a sort of two in One, goes as close to that as practicable... to the Dual LNB, Then through software when setting up you select the "Switch" and then you can control access to either sat. It is a bit of a "Mission" sometimes.. You will have to be very methodical and check all connections etc. I include a link that will help you. http://www.satcure.co.uk/tech/lnb.htm
Nov 07, 2009 | Toshiba Satellite A215-S7422 Notebook
We have a satellite and wish to connect 1 Sky TV and 3 Freeview receivers. We have installed a 4 way splitter but it will only take 1 sky and 1 freeview. As soon as we plug in another freeview, the power...
No the 2 receiver must be set. The supply going to LNB must switched off letting only one Freeview receiver supply to LNB is "ON". Meaning the one that give supply to LNB is the master receiver if you sw. it OFF the remaining2 can't receive programme.
Jun 07, 2009 | Televison & Video
Password
contact directv at 800-531-5000 to have them reset your passcode. it can only be done through them. if you have access to your account by website, you may be able to unlock the passcode there. easiest is to call them to have it unlocked
Apr 02, 2009 | Traxis DBS-2500 DTV Receiver
Password for traxis dcs-2500
i forgot the parental
password
Nov 06, 2008 | Traxis DBS-2500 DTV Receiver
What i need is the program to load the channels
Sep 03, 2008 | Traxis DBS-1500
Level But not quality
If you only get level signal on the traxis 1500, it means that you may have a defective LM317 IC or a TIP42C. This part is mounted on a heatsink.
Try checking the LNB frecuency as well and make sure you have the same settings as your Pansat.
Good Luck.
Feb 25, 2008 | Televison & Video
RX-V902 TV/DBS source coming through all other sources...
This could be as simple as having input and output line audio reversed. Please check all sources for proper connection. You can do this at the receiver too, but not both receiver and sources.....accordianman
Oct 31, 2007 | Yamaha R-V902 Receiver
Televison & Video Logo
21 people viewed this question
Top Traxis Televison & Video Experts
Electro Med Services...
Are you a Traxis Televison and Video Expert? Answer questions, earn points and help others
