Question about Xerox 6R1238 6204 Wide Format Printer Toner
XEROX 6240 WIDE FORMAT I CANNOT SCAN UNTILL IT PRIT COMPLETLY
XEROX 6240 WIDE FORMAT I CANNOT SCAN SCAN UNTIL THE DRAWING PRINT COMPLETELY IN THE SCREEN IT SHOWS MEMORY FULL PLEASE HELP ME IN THE PROBLEM.
SOURCE: Xerox Phaser 3200mfp Memory Issue
I've reinstalled the firmware with no success. I have tried repeatedly to clear the memory via the LCD user interface (there is no software solution to this). The message I get when trying to clear the memory is "Function Impossible".
Posted on Aug 22, 2008
  • 2072 Answers
SOURCE: Xerox scan to network
What is the model number? That is not a fault on an M15 which this question is listed under. Have you checked your LDAP settings to see if something there has changed?
Posted on Mar 13, 2009
bschilz
  • 2049 Answers
SOURCE: I have a networked xerox phaser 4500. I am trying
This notification is actually controlled in Windows... In XP, follow these steps...
  1. From the Start menu, choose Printers and Faxes. Windows displays the Printers and Faxes window.
  2. Within the window, choose Server Properties from the File menu. Windows displays the Print Server Properties dialog box.
  3. Make sure the Advanced tab is displayed.
  4. Make sure the Show Informational Notifications for Local Printers check box is cleared.
  5. Make sure the Show Informational Notifications for Network Printers check box is cleared.
  6. Click OK.
  7. Close the Printers and Faxes window.
For Windows Vista, it is more complicated...
Important This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base:
322756 (http://support.microsoft.com/kb/322756/ ) How to back up and restore the registry in Windows To disable balloon tips in the notification area, follow these steps:
  1. Click Start, click Run, type regedit, and then press ENTER.
  2. Locate the following subkey: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced
  3. Right-click the right side pane, create a new DWORD value, and then name it EnableBalloonTips.
  4. Double-click EnableBalloonTips, and then give it a value of 0.
  5. Close Registry Editor.
  6. Log off Windows, and then log back on.
Posted on Sep 02, 2009
SOURCE: Xerox phaser 8550 prints garbled characters
This happens to mine occasionally after I have put it into standby a few times. If I reboot this always sorts it out.
Posted on Dec 10, 2009
  • 6 Answers
SOURCE: xerox 4150 workcenter says fuser module needs to warm up. This appears usually first thing in morning. I have to power off then on to stop this from showing on the screen. also, it wont print until af
1. Switch off the machine, then switch on the machine.
2. Enter dC330 code 10-100 to heat the fuser to 180 degrees. Enter codes 10-200 (centre
thermistor) and 10-210 (front thermistor) to verify the condition of the thermistors.
3. Enter code 10-300 to check power supply unit 2. If necessary, install a new power supply
unit 2, PL 1.10 Item 4.
4. Switch off the machine. Remove the fuser assembly. Check that the thermistors, PL 10.25
Item 9 are clean and in good contact with the fuser heat roller. Check the wiring to the
thermistors. Install new components as necessary, PL 10.25.
5. Check for continuity between the two pins on the fuser assembly connector, PL 10.25
Item 8.
NOTE: A cold fuser has a resistance of approximately 11.5 ohms (220V/240V) or 2 ohms
(110V).
6. Check that there is continuity through the fuser heater and across the over temperature
cut-out.
7. Check the wiring between the fuser connector, PL 4.15 Item 20 and CON3, CON8 and
CON9 on Power Supply Unit 2. If necessary, install a new fuser connector, PL 4.15 Item
20.
8. Check the wiring between CON4 on Power Supply Unit 2 and CN7 on the Main PWB.
9. Install new components as necessary:
• Fuser assembly, PL 10.25 Item 1.
• HVPS, PL 1.10 Item 2.
10. Perform the OF5 Main PWB Check RAP.
4250/4260 Checkout
NOTE: The main PWB has test points. The location of the test points is shown on the Main
PWB PJ location illustration.
Refer to Wiring Diagram 17, Wiring Diagram 18 and Wiring Diagram 21. Perform the following:
unit 2, PL 1.15 Item 4.
4. Switch off the machine. Remove the fuser assembly. Check that the thermistors, PL 10.28
thermistor assembly. Check the wiring to the NC thermistor, PL 10.28 Item 19. Install new
components as necessary, PL 10.28.
5. Check for continuity between the three pins on the fuser assembly connector, PL 10.28
Item 8.
(110V).
6. Check that there is continuity through the fuser heat lamps and across the over temperature
cut-out. Install new components as necessary, PL 10.28.
7. Check the wiring between the fuser connector, PL 4.15 Item 20 and CN5 on the Main
PWB. If necessary, install a new fuser connector, PL 4.15 Item 20.
8. Check the wiring between CON1 on Power Supply Unit 2 and CN7 on the Main PWB.
• Fuser assembly, PL 10.28 Item 1.
• Power supply unit 2, PL 1.15 Item 4.
Posted on May 02, 2013
HP PCS1402 keeps printing test sheet on start up
Have u recently changed ur ink cartridge ? If so the printer is printing an alignment page . Turn it off then on , so it prints the alignment page. load the alignment page on the scanner glass and press the "Scan" button to complete the alignment. Once the alignment has completed the alignment page will not be printed again until you change the next cartridge. See your user manual for details.
May 17, 2012 | HP PSC 2355 All-In-One InkJet Printer
Hi my printer will not print. it is saying printer spool error.
> spool error
S.P.O.O.L. == Simultaneous Peripheral Output On Line
The "spool" is a combination of disk-space on your 'C:' drive, and software to "accept" the print-image (as fast as MS Word can create the print-image), and save the print-image to disk-space,
so that MS Word can report "print completed", so that you can use MS Word, instead of waiting until the physical printing has completed.
Then, the printer-spooling software will read from the print-image file, and send it to the printer, only as fast as the printer will accept it.
Feb 05, 2011 | Xerox Office Equipment & Supplies
How to remove this message "If you have just installed a new print cartridge it is recommended that you align it. Click on "Align" to align your new print cartridge."
it cant be removed unless and untill you complete the preocess just print align test page and put the page in scanner glass and press the scan button to complete.
Have a nice day and do not forget to rate please...!
Jan 29, 2010 | HP OfficeJet 4255 All-In-One InkJet...
I have a xerox dc12 with error message please turn machine off and on again 9-363 have tried several times but no good! what else can I do?
That's a process problem with that machine.
May require a service call .ON and OFF is pretty much all a customer can do and wait for it to setup.
NOTE: The problem occurs because of the trickle development system in the machine, making extended lengths of black and white copies / prints does not allow the black developer housing to purge itself of excess waste Toner (Dry Ink) and Developer. There are two solutions for the problem:
  • Make 1,000 copies / prints of a black and white job, then make 150 copies / prints of full color. Continue making 1,000 copies / prints of the black and white job, then 150 full color, and so on, until the entire black and white job is complete.
  • Make extended jobs in groups of 100 by making 100 copies / prints of the black and white job, then allowing the machine to cycle down (return to 'Ready') and making the next 100 copies / prints. Continue in this pattern until the entire black and white job is complete.
Apr 28, 2008 | Xerox DocuColor 12 Printer
In starting 1 page print
I believe that after changing the ink cartridge you havent completed the alignment process.This Alignment test page will print everytime you turn the printer ON.To Complete the alignment follow my steps.
1.After turning the printer ON, wait untill the printer prints the Alignment test page.
2.Then place the alignment test paper on the scanner, facing down in a correct position.
3.Then press the Scan button(color) and wait untill the printer ON light stops flashing.
4.After the light stops flashing, take the paper out and the alignment process is completed.
Turn OFF and turn On the printer, it will not print the Test page again.try it and please let me know.Would really appreciate your rating for my solution.
Thanks
Riz.
Apr 15, 2008 | HP PSC 1315 All-In-One InkJet Printer
Error 9-363
NOTE: The above solutions are based on jobs using 8.5 x 11 inch paper, single sided, with no more than 28% coverage.
Feb 18, 2008 | Xerox DocuColor 12 Printer
MY test page always prints
I belive that after replacing the INk cartridges, you are experiancing this problem. The Alignment test sheet always prints everytime you turn on the printer, if u haven't completed the Alignment process.
To complete the Alignment process,
>>Once the printer finished printing the Alignmnet test sheet.
>> Place the Test sheet staright on the scanner glass facing down towards right hand corner.
>>Press the scan button(color), the Power ON light will start flashing, wait until it stops flashing.
>>Alignmnet process completed.
Thank You
Feb 09, 2008 | HP PSC 1315 All-In-One InkJet Printer
or
  1. Power OFF the machine.
  2. Wait 30 seconds.
  3. Power ON the machine.
Dec 04, 2007 | Xerox DocuColor 12 Printer
Xerox 6R1238 6204 Wide Format Printer Toner Logo
66 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
